S5A - S5M
Taiwan Semiconductor
5A, 50V - 1000V Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High current capability
High surge current capability
Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF(AV)
5
A
VRRM
50 - 1000
V
IFSM
100
A
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound
(halogen-free)
● Moisture sensitivity level: level 1, per J-STD-020
● Terminal: Matte tin plated leads, solderable per J-STD-002
DO-214AB (SMC)
● Meet JESD 201 class 2 whisker test
● Polarity: As marked
● Weight: 0.21 g (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S5A
S5B
S5D
S5G
S5J
S5K S5M
S5A
S5B
S5D
S5G
S5J
S5K
S5M
UNIT
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Forward current
Surge peak forward current, 8.3 ms
single half sine-wave superimposed
on rated load per diode
Junction temperature
IF(AV)
5
A
IFSM
100
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version:E1903
S5A - S5M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance per diode
RӨJL
13
°C/W
Junction-to-ambient thermal resistance per diode
RӨJA
47
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage per diode
(1)
IF = 5A, TJ = 25°C
Reverse current @ rated VR per diode
(2)
TJ = 25°C
1 MHz, VR=4.0V
IF=0.5A , IR=1.0A
Reverse recovery time
TYP.
MAX.
UNIT
VF
1.15
V
10
µA
250
µA
CJ
60
pF
trr
1500
ns
IR
TJ = 125°C
Junction capacitance
SYMBOL
IRR=0.25A
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PART NO.
SUFFIX
S5x
(Note 1,2)
PACKING
CODE
SUFFIX
PACKING
CODE
PACKAGE
PACKING
R7
SMC
850 / 7" Plastic reel
R6
SMC
3,000 / 13" Paper reel
SMC
3,000 / 13" Plastic reel
V7
Matrix SMC
V6
Matrix SMC
M6
H
G
Note :
1. "x" defines voltage from 50V (S5A) to 1000V (S5M)
2. Only V6 and V7 are all green compound (halogen free)
EXAMPLE
EXAMPLE P/N
PART NO.
PART NO.
SUFFIX
PACKING
CODE
PACKING CODE
SUFFIX
DESCRIPTION
S5AHR7G
S5A
H
R7
G
AEC-Q101 qualified
Green compound
2
Version:E1903
S5A - S5M
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
5
JUNCTION CAPACITANCE.(pF)
AVERAGE FORWARD CURRENT (A)
6
4
3
2
1
RESISTIVE OR
INDUCTIVE LOAD
10
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
1
10
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
10
TJ=125°C
1
TJ=25°C
0.1
60
80
100
120
140
100
10
10
TJ=125°C
TJ=25°C
0.1
1
0.01
0.001
0.3
0.1
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
0.7
0.4
0.8
0.5
0.9
0.6
1
0.7
1.1
Pulse width
Pules width=300μs
1% duty cycle
0.8
0.9
1
1.1
1.2
1.3
1.4
1.5
1.6
FORWARD VOLTAGE (V)
3
Version:E1903
1.2
S5A - S5M
PEAK FORWARD SURGE CURRENT (A)
Fig.5 Maximum Non-repetitive Forward Surge Current
100
8.3ms Single Half Sine Wave
10
1
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram
4
Version:E1903
S5A - S5M
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
Unit (mm)
DIM.
Unit (inch)
Min.
Max.
Min.
Max.
A
2.90
3.20
0.114
0.126
B
6.60
7.11
0.260
0.280
C
5.59
6.22
0.220
0.245
D
2.00
2.62
0.079
0.103
E
1.00
1.60
0.039
0.063
F
7.75
8.13
0.305
0.320
G
0.10
0.20
0.004
0.008
H
0.15
0.31
0.006
0.012
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
3.30
0.130
B
2.50
0.098
C
6.80
0.268
D
4.40
0.173
E
9.40
0.370
MARKING DIAGRAM
Matrix SMC
SMC
P/N
=Marking Code
G
=Green Compound
YW
=Date Code
F
=Factory Code
5
Version:E1903
S5A - S5M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:E1903
很抱歉,暂时无法提供与“S5M V6G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.48619
- 50+1.16986
- 150+1.03432
