MBRF5100 C0G
MBRF5100 C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 100V 5A ITO220AC
MBRF5100 C0G 数据手册
MBRF5100 – MBRF5200 Taiwan Semiconductor 5A, 100V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for over-voltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 5 A VRRM 100 - 200 V IFSM 120 A TJ MAX 150 °C Package ITO-220AC Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.60g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak revers voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load (1) Peak repetitive reverse surge current Peak repetitive forward current (Rated VR, Square wave, 20KHz) Critical rate of rise of off-state voltage MBRF5100 MBRF5150 MBRF5200 UNIT MBRF5100 MBRF5150 MBRF5200 VRRM 100 150 200 V VR(RMS) 70 105 140 V IF 5 A IFSM 120 A IRRM 0.5 A IFRM 10 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +175 °C Notes: 1. tp = 2.0μs, 1.0KHz 1 Version: H2105 MBRF5100 – MBRF5200 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) MBRF5100 MBRF5150 IF = 5A, TJ = 25°C MBRF5200 MBRF5100 MBRF5150 IF = 5A, TJ = 125°C MBRF5200 TJ = 25°C TJ = 125°C SYMBOL VF IR TYP MAX UNIT - 0.90 V - 1.02 V - 0.80 V - 0.92 V - 100 µA - 5 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBRF5x ITO-220AC 50 / Tube MBRF5xH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 100V(MBRF5100) to 200V(MBRF5200) 2. “H” means AEC-Q101 qualified 2 Version: H2105 MBRF5100 – MBRF5200 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 5 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 6 4 3 2 1000 100 1 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) 0.1 TJ=75°C 0.01 0.001 TJ=25°C 0.0001 20 30 40 50 60 70 80 90 100 10 10 1 UF1DLW TJMBRF5100 =125°C TJ=25°C 10.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 100 Fig.4 Typical Forward Characteristics 10 MBRF5150 - 5200 0.01 Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.4 0.40.50.5 0.6 0.70.8 0.8 0.10.3 0.2 0.3 0.6 0.7 0.9 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10.9 1.1 11.2 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 140 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 1 10 REVERSE VOLTAGE (V) 120 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2105 1.2 MBRF5100 – MBRF5200 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: H2105 MBRF5100 – MBRF5200 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2105 MBRF5100 – MBRF5200 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2105
MBRF5100 C0G 价格&库存
很抱歉,暂时无法提供与“MBRF5100 C0G”相匹配的价格&库存,您可以联系我们找货
