HER1608G C0G
HER1608G C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 16A TO220AB
HER1608G C0G 数据手册
HER1601G – HER1608G Taiwan Semiconductor 16A, 50V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 50 - 1000 V IFSM 125 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies ● DC to DC converters ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) HER HER HER HER HER HER HER HER PARAMETER SYMBOL UNIT 1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G Marking code on the HER HER HER HER HER HER HER HER device 1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G Repetitive peak VRRM 50 100 200 300 400 600 800 1000 V reverse voltage Reverse voltage, total VR(RMS) 35 70 140 210 280 420 560 700 V rms value Forward current IF 16 A Surge peak forward current, 8.3ms single half sine wave IFSM 125 A superimposed on rated load Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 1 °C Version: J2104 HER1601G – HER1608G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) HER1601G HER1602G HER1603G HER1604G HER1605G HER1606G HER1607G HER1608G Reverse current @ rated VR per diode Junction capacitance per diode Reverse recovery time (2) IF = 8A, TJ = 25°C TJ = 25°C TJ = 125°C HER1601G HER1602G HER1603G HER1604G 1MHz, VR = 4.0V HER1605G HER1606G HER1607G HER1608G HER1601G HER1602G HER1603G HER1604G IF = 0.5A, IR = 1.0A, HER1605G Irr = 0.25A HER1606G HER1607G HER1608G SYMBOL VF IR TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 10 µA - 400 µA 80 - pF 50 - pF - 50 ns - 80 ns CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING HER16xG TO-220AB 50 / Tube HER16xGH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 50V(HER1601G) to 1000V(HER1608G) 2. “H” means AEC-Q101 qualified 2 Version: J2104 HER1601G – HER1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 20 200 16 160 CAPACITANCE (pF) 12 8 4 HER1601G-1605G 120 HER1606G-1608G 80 40 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 0 150 1 10 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 TJ=25°C 1 10 20 30 40 50 60 70 80 1000 Fig.4 Typical Forward Characteristics 1000 90 100 100 10 HER1601G-1604G 10 1 UF1DLW HER1605G TJ=125°C TJ=25°C 0.1 1 HER1606G-1608G 0.01 0.1 0.001 0.4 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.6 0.8 1.0 0.4 0.5 0.6 1.2 0.7 1.4 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 100 100 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve 125 8.3ms single half sine wave 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: J2104 1.2 HER1601G – HER1608G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: J2104 HER1601G – HER1608G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2104 HER1601G – HER1608G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2104
HER1608G C0G 价格&库存
很抱歉,暂时无法提供与“HER1608G C0G”相匹配的价格&库存,您可以联系我们找货
