P2500M A0G
P2500M A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-201AD
    DIODE GEN PURP 1000V 25A P2500
P2500M A0G 数据手册
P2500M Taiwan Semiconductor 25A, 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High current capability, Low VF High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 25 A VRRM 1000 V IFSM 650 A TJ MAX 175 °C Package P2500 Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: P2500 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.90g (approximately) P2500 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device P2500M UNIT P2500M Repetitive peak reverse voltage VRRM 1000 V Reverse voltage, total rms value VR(RMS) 700 V IF 25 A IFSM 650 A It 2 2100 As Junction temperature TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C Forward current Surge peak forward current 10ms single half sine wave superimposed on rated load Rating for fusing, t < 10ms 1 2 Version: C2103 P2500M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL Junction-to-lead thermal resistance TYP UNIT (1) °C/W (2) °C/W 0.8 RӨJL 6.0 Notes: 1. Thermal resistance from junction to lead/terminal at a distance 0 mm from case. 2. Mount on Heat sink size of 4in x 6in x 0.25in Al-Plate ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SYMBOL TYP MAX UNIT IF = 5A, TJ = 25°C VF - 0.87 V TJ = 25°C IR - 5 µA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING P2500M P2500 800 / Tape & Reel P2500M A0G P2500 500 / Ammo box P2500MH P2500 800 / Tape & Reel P2500MHA0G P2500 500 / Ammo box Notes: 1. “H” means ACE-Q101 qualified 2 Version: C2103 P2500M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 5 CAPACITANCE (pF) 4 3 2 100 1 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 0.1 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=125°C TJ=25°C 0.1 1 TJ=25°C 0.01 0.1 0.001 0.4 0.5 0.3 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.6 0.5 0.7 0.8 0.6 0.7 0.8 0.9 0.9 1.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 1000 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 0.01 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 6 10ms single half sine wave 100 10 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 P2500M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS P2500 MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: C2103 P2500M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
P2500M A0G 价格&库存
很抱歉,暂时无法提供与“P2500M A0G”相匹配的价格&库存,您可以联系我们找货
