31DF4 – 31DF6
Taiwan Semiconductor
3A, 400V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
High efficiency, Low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
400 - 600
V
IFSM
45
A
TJ MAX
150
°C
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
Package
DO-201AD
Configuration
Single die
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 1.20g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
31DF4
31DF6
31DF4
31DF6
UNIT
Repetitive peak reverse voltage
VRRM
400
600
V
Reverse voltage, total rms value
VR(RMS)
280
420
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Junction temperature
IF
3
A
IFSM
45
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: G2105
31DF4 – 31DF6
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
80
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 3A, TJ = 25°C
(2)
Reverse recovery time
TJ = 25°C
TJ = 125°C
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
1.7
V
µA
100
µA
35
ns
VF
IR
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
31DFx
DO-201AD
1,250 / Tape & Reel
31DFx A0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 400V (31DF4) to 600V (31DF6)
2
Version: G2105
31DF4 – 31DF6
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
3
CAPACITANCE (pF)
2
1
100
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
TJ=25°C
0.1
40
50
60
70
80
90
100
1010
UF1DLW
1
TJ=125°C
TJ=25°C
10.1
0.01
0.1
0.001
1.40.3
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
0.4 1.5 0.5
0.61.6 0.7
1.7 0.9
0.8
1.8
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
45
30
15
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2105
1.2
31DF4 – 31DF6
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: G2105
31DF4 – 31DF6
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2105
31DF4 – 31DF6
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: G2105
很抱歉,暂时无法提供与“31DF4 A0G”相匹配的价格&库存,您可以联系我们找货
