SF2L4GHA0G
SF2L4GHA0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 200V 2A DO204AC
SF2L4GHA0G 数据手册
SF2L4G – SF2L8G Taiwan Semiconductor 2A, 200V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 200 - 600 V IFSM 40, 50 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SF2L4G SF2L6G SF2L8G SF2L4G SF2L6G SF2L8G UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 2 IFSM TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 50 A 40 A Version: B2105 SF2L4G – SF2L8G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 17 °C/W Junction-to-ambient thermal resistance RӨJA 65 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL SF2L4G Forward voltage (1) SF2L6G IF = 2A, TJ = 25°C VF SF2L8G Reverse current @ rated VR TJ = 25°C (2) Junction capacitance Reverse recovery time IR TJ = 125°C SF2L4G SF2L6G 1MHz, VR = 4.0V SF2L8G IF = 0.5A, IR = 1.0A, Irr = 0.25A CJ trr TYP MAX UNIT - 0.95 V - 1.30 V - 1.70 V - 1 µA - 100 µA 40 - pF 20 - pF - 35 ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SF2LxG DO-204AC (DO-15) 3,500 / Tape & Reel SF2LxG A0G DO-204AC (DO-15) 1,500 / Ammo box SF2LxGH DO-204AC (DO-15) 3,500 / Tape & Reel SF2LxGHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 200V (SF2L4G) to 600V (SF2L8G) 2. “H” means AEC-Q101 qualified 2 Version: B2105 SF2L4G – SF2L8G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 SF2L4G CAPACITANCE (pF) 2 1 10 SF2L6G-SF2L8G f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 1 150 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 1 TJ=25°C 10 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1 SF2L4G TJ=125°C 1 0.1 TJ=25°C SF2L8G SF2L6G 0.01 0.1 0.001 0.5 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% 1% duty duty cycle cycle Pulse width 0.7 0.4 0.5 0.9 0.6 1.1 0.7 0.8 1.3 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 0.1 100 (A) AVERAGE FORWARD CURRENT (A) 3 8.3ms single half sine wave 50 40 30 SF2L4G-SF2L6G 20 SF2L8G 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: B2105 1.2 SF2L4G – SF2L8G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: B2105 SF2L4G – SF2L8G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2105 SF2L4G – SF2L8G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: B2105
SF2L4GHA0G 价格&库存
很抱歉,暂时无法提供与“SF2L4GHA0G”相匹配的价格&库存,您可以联系我们找货
