MUR440S R7G
MUR440S R7G
    TAIWANSEMICONDUCTOR(台半)
    DO214AB
    DIODE GEN PURP 400V 4A DO214AB
MUR440S R7G 数据手册
MUR420S – MUR460S Taiwan Semiconductor 4A, 200V - 600V Ultra Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Ultra Fast recovery time for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 4 A VRRM 200 - 600 V IFSM 75 A TJ MAX 175 °C APPLICATIONS ● High frequency rectification ● Freewheeling application ● Switching mode converters and inverters in computer, and telecommunication Package DO-214AB (SMC) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.250g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MUR420S MUR440S MUR460S MUR420S MUR440S MUR460S UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 4 A IFSM 75 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: F2102 MUR420S – MUR460S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 45 °C/W Junction-to-case thermal resistance RӨJC 8.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current@ rated VR (2) MUR420S MUR440S MUR460S MUR420S MUR440S MUR460S MUR420S MUR440S MUR460S MUR420S MUR440S MUR460S Junction capacitance Reverse recovery time MUR420S MUR440S MUR460S SYMBOL IF = 4A, TJ = 25°C VF IF = 4A, TJ = 150°C VF TJ = 25°C IR TJ = 150°C IR 1MHz, VR = 4.0V CJ IF = 0.5A, IR = 1.0A Irr = 0.25A trr TYP MAX UNIT - 0.875 V - 1.250 V - 0.710 V - 1.050 V - 5 μA - 10 μA - 150 μA - 250 μA 65 - pF - 25 ns - 50 ns Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING MUR4xS DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(MUR420S) to 600V(MUR460S) 2 Version: F2102 MUR420S – MUR460S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 4 CAPACITANCE (pF) 3 2 10 1 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 150 0.1 175 1 Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 10 TJ=150°C 0.1 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 MUR460S UF1DLW 1 TJ=150°C TJ=125°C TJ=25°C 1 0.1 TJ=25°C 0.01 0.1 0.001 0.3 0.5 0.3 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.7 0.5 0.9 1.1 0.6 0.7 0.8 1.3 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 100 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 0.01 100 REVERSE VOLTAGE (V) CASE TEMPERATURE (°C) 1 10 (A) AVERAGE FORWARD CURRENT (A) 5 8.3ms single half sine wave 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: F2102 1.2 MUR420S – MUR460S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: F2102 MUR420S – MUR460S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: F2102 MUR420S – MUR460S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F2102
MUR440S R7G 价格&库存
很抱歉,暂时无法提供与“MUR440S R7G”相匹配的价格&库存,您可以联系我们找货
