S1DFS – S1MFS
Taiwan Semiconductor
1A, 200V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placeme
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
200 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
SOD-128
Configuration
Single die
MECHANICAL DATA
Case: SOD-128
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.027g (approximately)
SOD-128
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S1DFS
S1GFS
S1JFS
S1KFS
S1MFS UNIT
S1DFS
S1GFS
S1JFS
S1KFS
S1MFS
Repetitive peak reverse voltage
VRRM
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
560
700
V
Forward current
Surge peak forward current, 8.3 ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: C2103
S1DFS – S1MFS
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
29
°C/W
Junction-to-ambient thermal resistance
RӨJA
82
°C/W
Junction-to-case thermal resistance
RӨJC
30
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 0.5A, TJ = 25°C
Forward voltage
IF = 1.0A, TJ = 25°C
(1)
IF = 0.5A, TJ = 125°C
VF
IF = 1.0A, TJ = 125°C
Reverse current @ rated VR
(2)
Junction capacitance
TJ = 25°C
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
TYP
MAX
UNIT
0.91
1.0
V
0.99
1.1
V
0.78
0.87
V
0.85
0.95
V
1
µA
50
µA
9
pF
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S1xFS
SOD-128
14,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(S1DFS) to 1000V(S1MFS)
2
Version: C2103
S1DFS – S1MFS
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
1
1
f=1.0MHz
Vsig=50mVp-p
0.1
50
75
100
125
1
150
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
10
TJ=125°C
1
0.1
0.01
TJ=25°C
0.001
10
10
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
10
40
50
60
70
80
90
10 10
TJ=125°C
TJ=125°C
1
TJ=25°C
0.1
TJ=25°C
0.01
Pulse width
0.001
0.3
0.1
0.6
100
UF1DLW
1
(A)
AVERAGE FORWARD CURRENT (A)
2
0.7
0.4
0.8
0.5
0.6
0.9
1
0.7
1.1
Pulse width 300μs
1% duty
0.8
0.9 cycle
1
1.1
1.2
1.3
1.4
1.5
1.6
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
3
Version: C2103
1.2
S1DFS – S1MFS
PACKAGE OUTLINE DIMENSIONS
SOD-128
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N = Marking Code
YW
= Date Code
F
= Factory Code
4
Version: C2103
S1DFS – S1MFS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2103
很抱歉,暂时无法提供与“S1MFS MWG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 14000+0.6878714000+0.08862
