CFP2-1FC4-AW
CFP2-1FC4-AW
    NIDEC(尼得科)
    插件
    按动开关 3万次 弯插 单刀双掷 1.47N 28V -40℃~+85℃
CFP2-1FC4-AW 数据手册
CFP2 ■Terminal Pins: Straight ■Actuator Color: Gray Ultra-Miniature Pushbutton Switches Washable RoHS Compliant ■Features ■ Specifications 1. Ultra-miniature pushbutton switch for high density mounting. 2. Washable. Rating 3. Terminal pin pitch: 2.54 mm. Max. 0.4VA(28VDC max.) Min. 1μA 20mVDC Initial contact resistance 100m Ω max.  4. Independent detent mechanism ensures light operational feel. 5. Clip contact mechanism for long-term contact reliability. 6. Gold-plated contacts. 250VAC 1 minute Insulation resistance 500MΩ min.(250VDC) Electrical life 10,000 operations at max.rating, 30,000 operations at min.rating, Mechanical life 30,000 cycles Operating force 1.47±0.98N Operating temperature range Storage temperature range ■Part Numbering CFP2 2 Series Actuator Number of poles Code Type Fig. Number of poles P Pushbutton 1 1 pole 2 2 poles R R −40∼+85℃ ON -(ON) A Terminal style 1 pole 2 poles Switching function F −40∼+85℃ C4 Switching function (1.5mA 200μVAC) Dielectric strength Actuator shape Fig. Terminal style Code Actuator shape C P/C A Standard C4 Right angle W Packaging spec Code Packaging spec W Tray C6 Vertical mounting (ON) :Momentary. CFP2 SPDT PC Switching function Part No. 5-φ0.6~0.8 CFP2-1FC-AW ON (ON) Connecting terminals 5−6 5−4 ON 2−3 5−6 (ON) 2−1 5−4 CFP2-1FC4-AW ON (ON) Connecting terminals 5−6 5−4 ON 2−3 5−6 (ON) 2−1 5−4 (Top view) PC Hole Layouts Terminal numbers are not shown on the switch. DPDT PC Switching function Part No. ☆CFP2-2RC-AW 6-φ0.6~0.8 Terminal numbers are not shown on the switch. Connecting terminals (Top view) PC Hole Layouts SPDT R/A Switching function Part No. 5-φ0.6~0.8 (Top view) PC Hole Layouts Terminal numbers are not shown on the switch. DPDT R/A Switching function Part No. ☆CFP2-2RC4-AW 8-φ0.6~0.8 Connecting terminals (Top view) PC Hole Layouts Terminal numbers are not shown on the switch. ※ The above PC Hole Layouts are top view drawings. ■Optional Accessories Part Name Dimension Gloss finish Color Cap ABS resin :Optional Accessories. 《Sold separately》 Color Part Number White 140000481453 Red 140000481452 Black 140000481451 Gray 140000481450 The blue line shows the outline of the switch. ■Color Cap Mounting (ON) :Momentary. ☆:Semi-standard products. CFP2 SPDT V/M Switching function Part No. CFP2-1FC6-AW ON (ON) Connecting terminals 5−6 5−4 ON 2−3 5−6 (ON) 2−1 5−4 5-φ0.8 Terminal numbers are not shown on the switch. (Top view) PC Hole Layouts DPDT V/M Switching function Part No. ☆CFP2-2RC6-AW Connecting terminals 8-φ0.8 Terminal numbers are not shown on the switch. (Top view) PC Hole Layouts ※ The above pcb hole dimengion, it is a top view drawiing when we fix the switch. ■Handling Specifications(CFP2) 1. Soldering Specifications  ⑴Manual Soldering Device:Soldering iron 350° C, Max.; 3 seconds, Max. ⑵Auto Soldering Device:Jet wave type or dip type 260° C, Max.; 3-5 seconds, Max. (One time) Total dip time: Within 10 seconds ・Pre-heating should be done at temperatures from 80° C to 120° C and within 120 seconds ⑶When soldering two or more terminals to a common land, use solder resist to separate them 2. Flux Cleaning ⑴Solvents : Fluorine or Alcohol type ⑵Cleaning after soldering should be done after the PC board is exposed to room temperature (30℃ or below) for 1 to 2 hours. ⑶Do not use ultrasonic cleaning. ■Packaging Specifications Plastic Pack 100 pcs./pack U 15 OK SO IS JI FU J FU KU 231 The blue line shows the outline of the switch. (ON) :Momentary. 196 ☆:Semi-standard products.
CFP2-1FC4-AW 价格&库存
很抱歉,暂时无法提供与“CFP2-1FC4-AW”相匹配的价格&库存,您可以联系我们找货
CFP2-1FC4-AW
  • 1+14.44800
CFP2-1FC4-AW
    • 1+30.27240
    • 10+26.28720
    • 30+23.92200
    • 100+20.63880
    • 500+19.53720
    • 1000+19.04040
