CRFS-2302
CRFS-2302
    NIDEC(尼得科)
    插件
    滑动开关 插件 双刀三掷 1万次 直插
CRFS-2302 数据手册
CRFS SLIDE SWITCHES RoHS compliant INTERNAL STRUCTURE ① ② ③ ④ ⑧ ⑤ ⑩ ⑦ ⑨ Part name ⑥ Material Flammability ■ FEATURES ① Cover Steel (SPCC), Tin-plated — ● RoHS compliant ● Covering the DC  1 GHz frequency spectrum ● Gold-plated contact provides excellent reliability ② Slider Polyamide UL94V-0 ③ Slider plate ❈1 Polyester ④ Click spring SWP ⑤ Click ball SUS ⑥ Slider contact ⑦ Fixed contact ⑧ Housing ⑨ Terminal pin Copper alloy, Gold-plated ⑩ Ground terminal Steel (SPCC), Tin-plated ■ APPLICATIONS ● Communication devices ● Broadcast equipment ● FA equipment — Copper alloy, Gold-plated (Polyphenylenesulphide) UL94V-0 ❈1 : 2 poles 3 contacts only ■ PART NUMBER DESIGNATION CRFS - 2 2 0 2 W Series name Form of packaging No. of poles W:Tray packaging Blank:Bulk in plastic bag 2:2 poles No. of contacts Knob length 2:2 contacts 3:3 contacts 2: 5 mm 4:10 mm Setting position 0:Top setting ※ Please refer to the LIST OF PART NUMBERS when placing orders. — CRFS SLIDE SWITCHES ■ LIST OF PART NUMBERS Setting position Shape of terminals Knob length 5 mm Top setting Through hole pins 10 mm Tray packaging Bulk in plastic bag Tray packaging Bulk in plastic bag ■ STANDARD SPECIFICATIONS Operating temp. range Storage temp. range Sealing 3 CRFS-2202W CRFS-2302W 50 pcs./tray CRFS-2202 CRFS-2302 25 pcs./pack CRFS-2204W CRFS-2304W 50 pcs./tray CRFS-2204 CRFS-2304 25 pcs./pack ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching : DC50 V 100 mA Switching : DC12 V 100 mA Minimum : DC20 mV 1μ A Non- Washable Contact timing Non-shorting 70 m Ω maximum Contact resistance 100 M Ω minimum (DC500 V) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS No. of positions 2, 3 Stroke CFRS-22 □□ ※ 1 A ↔ B : 2.5 ± 1.5 N {0.255 ± 0.153 kgf} CFRS-23 □□ ※ 2 A → B / C → B : 1.5 ± 1 N {0.153 ± 0.102 kgf} B → A / B → C : 2.5 ± 1.5 N {0.255 ± 0.153 kgf} AC500 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS Vibration 2 mm Operating force Pieces in package 2 − 40 ~ 85 °C Approx. 1.4 g (CRFS-2202) Approx. 1.5 g (CRFS-2204) Approx. 1.9 g (CRFS-2302) Approx. 2.0 g (CRFS-2304) Net weight No. of contacts Form of packaging Shock Load life Humidity (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 10 cycles each 490 m/s2, 11 ms, sinusoidal wave half cycle, 6 directions for 3 times each Continuous load 10000 cycles, DC12 ± 0.5 V, 100 ± 10 mA 40 °C, Relative humidity 90 ~ 95 %, 240 h, No load Stop strength 30 N {3.06 kgf} 15 s High temp. exposure 85 °C, 96 h, No load Solderability 245 ± 3 °C Low temp. exposure − 40 °C, 96 h, No load 2~3s Flow : 260 ± 3 °C, 5 ~ 6 s, 2 times maximum Soldering heat − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles Manual soldering : 380 ± 10 °C, 3 ~ 4 s { } : Reference only ※1 Thermal shock A B ※2 ■ HIGH FREQUENCY CHARACTERISTICS CRFS-22 □□ A B C Isolation between terminals Isolation between circuits Insertion loss VSWR Impedance CRFS-22□□ CRFS-23□□ 770 MHz 28 dB minimum 30 dB minimum 0.15 dB maximum 1.2 maximum 1.0 GHz 26 dB minimum 28 dB minimum 0.23 dB maximum 1.3 maximum CRFS-23 □□ 770 MHz 28 dB minimum 31 dB minimum 0.13 dB maximum 1.3 maximum 75 Ω 1.0 GHz 26 dB minimum 29 dB minimum 0.17 dB maximum 1.3 maximum CRFS SLIDE SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CRFS-22 □□ ● CRFS-23 □□ 13.8 10 C ① ② ③ C ② ③ ④ 6 6.5 ① ⑤ ④ ⑤ ⑥ C Schematic Travel:2 2 Travel : 2 3 4 Production date code ⑥ ⑦ ⑧ C Schematic Travel : 2 3 3.5 3 3.5 3 0.5 8.5 Terminal No.5 8.5 Terminal No.4 L L Production date code 0.8 0.3 0.5 2.4 5.5 2 2 9.2 Model number 0.5 0.3 0.8 4 2 12 0.5 2 2.5 6 L (mm) Model number L (mm) CRFS-2202 5 CRFS-2302 5 CRFS-2204 10 CRFS-2304 10 ■ SIZE OF P.C.B. PROCESSING 2 2 9.2 2 1. – 2 4 6 2.5 5.5 2.4 8 – φ 4 φ 1 – ● CRFS-23 □□ φ 4 6 – 1 φ 1. 2 ● CRFS-22 □□ (Unit : mm) 2 12 ■ PACKAGING SPECIFICATIONS ● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk in a plastic bag is 25 pcs. per pack. Orders will be accepted for unit of minimum 25 pcs., i.e., 25, 50, 75 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box.
CRFS-2302 价格&库存
很抱歉,暂时无法提供与“CRFS-2302”相匹配的价格&库存,您可以联系我们找货
CRFS-2302
    • 1+46.80720
    • 200+18.68400
    • 500+18.05760
