FP
■ Terminal Pins: Kinked
■ Actuator Color: Yellow
Ultra-Miniature
Pushbutton Switches
Washable
RoHS Compliant
■Features
■ Specification
1. Ultra-miniature pushbutton switch for high density mounting.
2. Washable.
Rating
3. Terminal pin pitch: 2.54 mm.
Initial contact resistance 100mΩmax.
4. Independent detent mechanism ensures light operational feel.
5. Clip contact mechanism for long-term contact reliability.
6. Gold-plated contacts.
Max.
0.4VA(28VDC max.)
Min.
1μA 20mVDC
250V AC 1 minute
Insulation resistance
500MΩ min. (250VDC)
Electrical life
10,000 operations at max.rating,
30,000 operations at min.rating,
Mechanical life
30,000 cycles
Operating force
1.47±0.98N
Operating
temperature range
Storage
temperature range
■Part Numbering
F
Series code
P
Actuator shape
2
F
Number of poles
Code
Type
Fig.
Number of poles
P
Pushbutton
1
1 pole
2
2 poles
2
Switching function
Code Switching function
F
ON -(ON)
(1.5mA 200μVAC)
Dielecteic strength
−40∼+85℃
−40∼+85℃
M
Terminal style
Z
Actuator shape
Fig.
Terminal style
Code
Actuator shape
2
P/C
M
Standard
5
Right angle
4
Vertical mounting
FP
SPDT
Switching
function
PC
Part No.
5-φ0.8~1.0
FP1F−2M−Z
ON
(ON)
Connecting terminals
2−3
2−1
プリント基板孔あけ寸法図(Top view)
PC Hole Layouts
Terminal numbers are not shown on the switch.
DPDT
PC
Switching
function
Part No.
★FP2F−2M−Z
6-φ0.8~1.0
ON
2−3
5−6
(ON)
2−1
5−4
PC Hole Layouts
SPDT
R/A
Switching
function
Part No.
5-φ0.8~1.0
FP1F−5M−Z
ON
(ON)
2−3
2−1
ON
2−3
5−6
(ON)
2−1
5−4
Top view)
PC Hole Layouts
DPDT
R/A
Switching
function
Part No.
★FP2F−5M−Z
8-φ0.8~1.0
PC Hole Layouts
■Optional Accessories
Part Name
Dimension
Gloss finish
Color Cap
ABS resin
:Optional Accessories.
《Sold separately》
Color
Part Number
White
140000481453
Red
140000481452
Black
140000481451
Gray
140000481450
The blue line shows the outline of the switch.
■Color Cap Mounting
(ON)
:Momentary.
★:Made to order products.
FP
SPDT
Switching
function
V/M
Part No.
FP1F−4M−Z
ON
(ON)
2−3
2−1
ON
2−3
5−6
(ON)
2−1
5−4
5-φ0.8~1.0
(Top view)
PC Hole Layouts
DPDT
V/M
Switching
function
Part No.
★FP2F−4M−Z
8-φ0.8~1.0
(Top view)
PC Hole Layouts
■Handling Precautions(FP, FT, FL)
1. Soldering Specifications
⑴Manual Soldering
Device:Soldering iron
380°
C, Max.; 3 seconds, Max.
⑵Auto soldering
Device:Jet wave type or dip type
275°
C, Max.; 6 seconds, Max.
・Pre-heating should be done at temperatures from
80 to 120°
C and within 120 seconds.
⑶When soldering two or more terminals to the
common land, use solder resist to solder them
independently.
2. Flux Cleaning
⑴Solvents :Fluorine or Alcohol type
⑵ Cleaning after soldering should be done after the PC
board is exposed to room temperature (30℃ or below)
for 1 to 2 hours.
⑶Do not use ultrasonic cleaning.
■Packaging Specifications
Plastic Pack
100 pcs./pack
U
15
OK
SO
IS
JI
FU
J
FU
KU
231
(ON)
:Momentary.
196
很抱歉,暂时无法提供与“FP1F-2M-Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.972321+5.83814
- 10+38.8181610+5.03923
- 25+36.6095625+4.75252
- 50+35.0166950+4.54574
- 100+33.49236100+4.34786
- 300+31.20721300+4.05121
- 500+30.19612500+3.91995
- 1000+28.874481000+3.74838
- 国内价格
- 1+30.52080
- 10+26.29800
- 50+23.79240
