FT
■ Terminal Pins : Kinked
■ Actuator Color : Yellow
Washable
Ultra-Miniature Toggle Switch
RoHS Compliant
■Features
■ Specifications
1. Ultra-miniature toggle switch for high density
mounting.
2. Washable.
3. Terminal pin pitch : 2.54 mm.
4. Independent detent mechanism ensures light
operational feel.
5. Clip contact mechanism for long-term contact
reliability.
6. Gold-plated contacts.
Rating
Max.
28VDC 0.4VA max.
Min.
1μ A 20mVDC
(1.5mA 200μ VAC)
Initial contact resistance
100mΩ max.
Dielectric strength
250VAC 1 minute
Insulation resistance
500MΩ min.
Electrical life
10,000 cycles at max. rating
50,000 cycles at min. rating
(D,E type)
30,000 cycles at min. rating
(F,G type)
Operating
temperature range
Storage
temperature range
(250VDC)
−40℃∼+85℃
−40℃∼+85℃
■Part Numbering
F T 2 D - 2 M - Z
Series code
Actuator shape
Number of poles
Code
Type
Fig.
Number
of poles
T
Toggle type
1
1 pole
2
2 poles
Code Switching function
D
E
F
G
Terminal style of「2」(Style:PC Terminal)
(ON)
:Momentary.
Switching function
ON
ー
ON
ONーOFF ー ON
ON
ー (ON)
(ON)ーOFFー(ON)
Actuator shape
Terminal style
Code Actuator shape
Fig.
Terminal style
2
PC Straight
5
Right angle
4
Vertical mounting
Terminal style of「4」(Style:V/M Terminal)
M
Standard
Terminal style of「5」(Style:R/A Terminal)
FT
SPDT
4.5
φ4
Switching
function
Part number marking side
3
0.5
φ1.9
PC Straight
(13.8)
5.4
1.6
3.8
(1)
2.54
30゚
2.54
7
Part No.
(2)
(3)
Key Way
0.5
MARKING
2.54
2.54
2.54
(1)
Terminal numbers are not shown on the switch.
DPDT
1.6
3.8
(13.8)
5.4
0.5
2.54
2.54
(1)
(4)
(2)
(5)
(3)
(6)
Part No.
FT2D-2M-Z
☆FT2E-2M-Z
★FT2F-2M-Z
★FT2G-2M-Z
MARKING
2.54
2.54
(2)
(3)
(4)
(5)
(6)
Connecting terminals
4.5
φ4
3.8
(11.8)
1.6
5.4
φ1.9
2.54
(2)
2.54
30゚
7
(3)
ON
ON
ON
(ON)
2−3
5−6
OFF
OFF
ON
ON
(ON)
(ON)
2−1
5−4
ON
ON
OFF
ON
ON
2−1
2−3
ON
ON
2−1
5−4
OFF
ON
ON
2−3
5−6
(3)
2.54
(2)
2.54
0.5
5-φ1
(1)
(13.85)
5.4
Key Way
Switching
function
(3)
(5)
(2)
(4)
(1)
Part No.
2.54
(6)
0.5
☆FT2D-5M-Z
★FT2E-5M-Z
2.54
1.6
30゚
MARKING
t=0.3
0.3
(2.45)
0.5
5.08
2.54
8-φ1
(3)
(6)
2 .54
0.5
5.08
(2)
(5)
2 .54
φ1.9
7
2−1
(Topview)
PC hole Layouts
3.8
0.3
0.5
5.08
Right Angle Terminal
FT1D-5M-Z
FT1E-5M-Z
MARKING
t=0.3
4.5
φ4
Part No.
(1)
Key Way
(2.45)
3.5
3
2−3
Switching
function
5.08
DPDT
ON
ON
(ON)
(ON)
(Topview)
PC hole Layouts
0.5
(1)
2.54
2.54
0.3
6-φ1
3.5
3
OFF
OFF
Switching
function
φ1.9
Key Way
0.5
SPDT
3
30゚
7
(3)
ON
ON
ON
(ON)
(Topview)
PC hole Layouts
4.5
φ4
PC Straight
(2)
2.54
0.3
5-φ1
FT1D-2M-Z
☆FT1E-2M-Z
☆FT1F-2M-Z
★FT1G-2M-Z
(1)
(4)
0.3
2.54
(Topview)
PC hole Layouts
(ON)
:Momentary.
☆:Semi-standard products. ★:Made to order products.
FT
SPDT
Switching
function
キー溝
Key Way
5.6
4.5
Vertical mounting terminal
3.8
5.4
1.6
形名表示側
0.5
Part No.
☆FT1D-4M-Z
★FT1E-4M-Z
(2)
(1)
φ1.9
7
φ4
30゚
(3)
3
0.4
2.54
(2.5)
0.3
5.08
ON
ON
OFF
ON
ON
2−3
2−1
ON
ON
2−3
5−6
OFF
ON
ON
2−1
5−4
0.5
2.54
2.54
2.54
2.54
5-φ1
0.3
5.08
(2)
(3)
2.54
(1)
(Topview)
PC hole Layouts
Switching
function
キー溝
Key Way
DPDT
5.6
4.5
3.8
1.6
5.4
形名表示側
φ1.9
30゚
7
φ4
0.5
(6)
(3)
(5)
(2)
(4)
(1)
Part No.
FT2D-4M-Z
★FT2E-4M-Z
3
0.4
(2.5)
0.5
2.54
2.54
0.3
2.54
0.3
5.08
2.54
2.54
8-φ1
■Soldering Specifications
⑴Manual Soldering
Device:Soldering iron
380℃, Max.; 3 seconds, Max.
⑵Auto Soldering
Device:Jet wave type or dip type
275℃, Max.; 6 seconds, Max.
・Pre-heating should be done at temperatures from
80 to 120℃ and within 120 sec.
(1)
(2)
(3)
(4)
(5)
(6)
2.54
2.54
5.08
(Topview)
PC hole Layouts
■ Flux Cleaning
⑴Solvent : Fluorine or Alcohol type.
⑵Cleaning after soldering should be done after the
PC board is exposed to room temperature (30℃ or
below) for 1 to 2 hours.
⑶Do not use ultrasonic cleaning.
275
■Packaging Specifications
100 pcs./pack
15
KU
FU
231
☆:Semi-standard products. (ON)
:Momentary.
JI
SO
SO
⑶When soldering two or more terminals to a common
land, use solder resist to separate them.
Plastick Pack
JI
S
6
120
Pre-heating soldering
FU
120
80
KU
196
很抱歉,暂时无法提供与“FT1D-2M-Z 01”相匹配的价格&库存,您可以联系我们找货
