9C-13.225625MAAK-T
9C-13.225625MAAK-T
    TXC(台晶)
    HC49S
    无源晶振 40Ω 20pF 13.225MHz ±30ppm HC49S -20℃~+70℃
9C-13.225625MAAK-T 数据手册
Quartz Crystals SMD HC-49S 9C SERIES Features > Surface mount type crystal units. Quartz Crystals > A great number of standard frequencies. > High frequency pullability and low equivalent series resistance. > Highly mass production capability. > The best choice of PC, STB, LCDM, and Cable Modem. > RoHS Compliant / Pb Free. Electrical Specifications Item / Type 9C 3.2 ~ 90 MHz Frequency Range Frequency Tolerance (at 25 ºC) Frequency Stability Over Operating Temperature Range Operating Temperature Range ± 30 ppm, or specify ± 30 ppm (-20 ~ +70 ºC), or specify - 40 ~ + 85 ºC 7 pF Max. Shunt Capacitance (C0) 1 ~ 500 μW (100 μW typical) Drive Level 18 pF, or specify Load Capacitance ± 3 ppm / year Max. Aging (at 25 ºC) Storage Temperature Range - 55 ~ + 125 ºC Equivalent Series Resistance(ESR) Fundamental 3rd Overtone 3.2 ~ 3.686 MHz 200 Ω Max. 27 ~ 30 MHz 100 Ω Max. 3.686 ~ 5 MHz 150 Ω Max. 30 ~ 50 MHz 80 Ω Max. 5 ~ 10 MHz 80 Ω Max 50 ~ 90 MHz 60 Ω Max. 10 ~ 14 MHz 40 Ω Max. 14 ~ 30 MHz 30 Ω Max. Dimensions Units:mm Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com 04
9C-13.225625MAAK-T
物料型号:14.3Fy01
器件简介:文档描述了TXC公司生产的表面贴装型石英晶体单元,适用于PC、STB、LCDM和Cable Modem等设备,符合RoHS标准,无铅。
引脚分配:文档未明确提供引脚分配信息。
参数特性: - 频率范围:3.2~90 MHz - 频率容差(25°C时):±30ppm或指定 - 工作温度范围内的频率稳定性:±30ppm(-20~+70°C)或指定 - 工作温度范围:-40~+85°C - 并联电容(C0):最大7pF - 驱动电平:1~500 mW(典型值100mW) - 负载电容:18pF或指定 - 老化(25°C时):最大±3ppm/年 - 存储温度范围:-55~+125°C
等效串联电阻(ESR): - 基频:3.2~3.686 MHz时最大200欧姆,3.686~5MHz时最大150欧姆,5~10MHz时最大80欧姆,10~14MHz时最大40欧姆,14~30 MHz时最大30欧姆 - 第三泛音:27~30 MHz时最大100欧姆,30~50MHz时最大80欧姆,50~90 MHz时最大60欧姆
功能详解:文档未提供详细的功能解释。
应用信息:文档指出该器件是PC、STB、LCDM和Cable Modem的最佳选择。
封装信息:文档提供了封装尺寸,但未提供封装类型的详细信息。
9C-13.225625MAAK-T 价格&库存
很抱歉,暂时无法提供与“9C-13.225625MAAK-T”相匹配的价格&库存,您可以联系我们找货
9C-13.225625MAAK-T
  • 1000+1.707231000+0.22115
