BYC8-600,127
BYC8-600,127
    WEEN(瑞能)
    TO-220-2
    DIODE RECT 600V 8A SOT78
BYC8-600,127 数据手册
BYC8-600 Hyperfast power diode 9 August 2017 Product data sheet 1. General description Hyperfast power diode in a SOD59 (2-lead TO-220AC) plastic package. 2. Features and benefits • • Low reverse recovery current and low thermal resistance Reduces switching losses in associated MOSFET 3. Applications • • • Continuous Current Mode (CCM) Power Factor Correction (PFC) Half-bridge/full-bridge switched-mode power supplies Half-bridge lighting ballasts 4. Quick reference data Table 1. Quick reference data Symbol Parameter VRRM repetitive peak reverse voltage IF(AV) average forward current Conditions Min Typ Max Unit - - 600 V δ = 0.5 ; Tmb ≤ 109 °C; square-wave pulse; Fig. 1; Fig. 2 - - 8 A IF = 8 A; Tj = 150 °C; Fig. 4 - 1.4 1.85 V IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; Fig. 5 - 19 - ns Static characteristics VF forward voltage Dynamic characteristics trr reverse recovery time BYC8-600 WeEn Semiconductors Hyperfast power diode 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K Simplified outline cathode Graphic symbol mb K A 001aaa020 2 A anode mb mb mounting base; cathode 1 2 TO-220AC (SOD59) 6. Ordering information Table 3. Ordering information Type number BYC8-600 BYC8-600 Product data sheet Package Name Description Version TO-220AC plastic single-ended package; heatsink mounted; 1 mounting hole; 2-lead TO-220AC SOD59 All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 2 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM Conditions Min Max Unit repetitive peak reverse voltage - 600 V VRWM crest working reverse voltage - 600 V IF(AV) average forward current δ = 0.5 ; Tmb ≤ 109 °C; square-wave pulse; Fig. 1; Fig. 2 - 8 A IFRM repetitive peak forward current δ = 0.5 ; tp = 25 µs; Tmb ≤ 109 °C; square-wave pulse - 16 A IFSM non-repetitive peak forward current tp = 10 ms; Tj(init) = 25 °C; sine-wave pulse - 80 A tp = 8.3 ms; Tj(init) = 25 °C; sine-wave pulse - 88 A Tstg storage temperature -40 150 °C Tj junction temperature - 150 °C 003aab472 30 Ptot (W) 25 003aab471 20 Ptot (W) δ =1 a = 1.57 1.9 16 2.2 0.5 20 2.8 12 4.0 0.2 15 0.1 8 10 4 5 0 0 4 8 IF(AV) (A) 0 12 Fig. 1. Forward power dissipation as a function of average forward current; square waveform; maximum values BYC8-600 Product data sheet 0 2 4 6 IF(AV) (A) 8 Fig. 2. Forward power dissipation as a function of average forward current; sinusoidal waveform; maximum values All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 3 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode 8. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 3 - - 2.2 K/W Rth(j-a) thermal resistance from junction to ambient free air - 60 - K/W 003aac977 10 Zth(j-mb) (K/W) 1 10- 1 P δ= tp T 10- 2 tp 10- 3 10- 6 10- 5 10- 4 10- 3 10- 2 t T 10- 1 1 10 tp (s) Fig. 3. Transient thermal impedance from junction to mounting base as a function of pulse width BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 4 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit IF = 8 A; Tj = 25 °C - 2 2.9 V IF = 8 A; Tj = 150 °C; Fig. 4 - 1.4 1.85 V IF = 16 A; Tj = 150 °C - 1.7 2.3 V VR = 600 V; Tj = 25 °C - 9 150 µA VR = 600 V; Tj = 100 °C - 1.1 3 mA IF = 1 A; VR = 30 V; dIF/dt = 50 A/µs; Tj = 25 °C; Fig. 5 - 30 52 ns IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; Fig. 5 - 19 - ns IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 100 °C; Fig. 5 - 32 40 ns IF = 8 A; VR = 400 V; dIF/dt = 50 A/µs; Tj = 125 °C - 1.5 5.5 A IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 100 °C - 9.5 12 A Static characteristics VF forward voltage IR reverse current Dynamic characteristics trr reverse recovery time IRM peak reverse recovery current Qr recovered charge IF = 1 A; VR = 100 V; dIF/dt = 100 A/µs; Tj = 25 °C - 12 - nC VFR forward recovery voltage IF = 10 A; dIF/dt = 100 A/µs; Tj = 25 °C; Fig. 6 - 8 10 V 003aac976 20 IF (A) IF dlF dt 16 trr 12 time 25 % 8 (1) (2) (3) 100 % Qr 4 IR 0 IRM 003aac562 0 1 2 3 VF (V) 4 Fig. 5. Reverse recovery definitions; ramp recovery Fig. 4. Forward current as a function of forward voltage BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 5 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode IF time VF VFRM VF time 001aab912 Fig. 6. Forward recovery definitions BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 6 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode 10. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 2-lead TO-220AC SOD59 E A A1 P q D1 D H Q b1 L 1 2 c b e 0 5 Dimensions Unit mm max nom min 10 mm scale A A1 b b1(1) c D D1 E 4.7 1.40 0.95 1.7 0.65 15.8 6.8 10.30 4.3 1.15 0.70 1.3 0.45 15.6 6.4 9.65 e H 5.08 (REF) L P Q q 16.25 15.0 3.80 2.6 2.9 15.70 12.5 3.65 2.2 2.7 Note 1. Protruded dambar are included in the dimension. Outline version SOD59 sod059_po References IEC JEDEC JEITA European projection Issue date 09-08-25 12-11-27 2-lead TO-220AC Fig. 7. Package outline TO-220AC (SOD59) BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 7 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 11. Legal information Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. BYC8-600 Product data sheet Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 8 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 9 / 10 BYC8-600 WeEn Semiconductors Hyperfast power diode 12. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Limiting values............................................................. 3 8. Thermal characteristics............................................... 4 9. Characteristics..............................................................5 10. Package outline.......................................................... 7 11. Legal information....................................................... 8 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved For more information, please visit: http://www.ween-semi.com For sales office addresses, please send an email to: salesaddresses@ween-semi.com Date of release: 9 August 2017 BYC8-600 Product data sheet All information provided in this document is subject to legal disclaimers. 9 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 10 / 10
BYC8-600,127 价格&库存
很抱歉,暂时无法提供与“BYC8-600,127”相匹配的价格&库存,您可以联系我们找货
BYC8-600,127
  • 1+12.972181+1.68035
  • 10+8.2046910+1.06280
  • 100+5.45109100+0.70611
  • 500+4.27105500+0.55325
  • 1000+3.891091000+0.50404
  • 2000+3.736092000+0.48396
库存:3962
