BYV29X-500,127
BYV29X-500,127
    WEEN(瑞能)
    ITO220FP-2
    DIODE GEN PURP 500V 9A TO220F
BYV29X-500,127 数据手册
DISCRETE SEMICONDUCTORS DATA SHEET BYV29F, BYV29X series Rectifier diodes ultrafast Product specification October 2018 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series FEATURES SYMBOL QUICK REFERENCE DATA VR = 300 V/ 400 V/ 500 V • Low forward volt drop • Fast switching • Soft recovery characteristic • High thermal cycling performance • Isolated mounting tab K VF ≤ 1.03 V A 001aaa020 IF(AV) = 9 A trr ≤ 60 ns GENERAL DESCRIPTION Ultra-fast epitaxial rectifier diodes intended for use in switched mode power supply output rectification, electronic lighting ballasts and high frequency switching circuits in general. The BYV29F series is supplied in the SOD100 package. The BYV29X series is supplied in the SOD113 package. PINNING SOD100 PIN mb DESCRIPTION 1 cathode (k) 2 anode (a) tab SOD113 case isolated 1 1 2 SOD113 (2-lead TO-220F) 2 LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER VRRM VR Peak repetitive reverse voltage Continuous reverse voltage IF(AV) Average forward current2 IFSM Non-repetitive peak forward current Tstg Tj Storage temperature Operating junction temperature CONDITIONS MIN. BYV29F/BYV29X Ths ≤ 138˚C1 square wave; δ = 0.5; Ths ≤ 90 ˚C t = 10 ms t = 8.3 ms sinusoidal; with reapplied VRRM(max) - MAX. -300 300 300 -400 400 400 UNIT -500 500 500 V V - 9 A - 100 110 A A -40 - 150 150 ˚C ˚C 1 Ths de-rating for thermal stability. 2 Neglecting switching and reverse current losses October 2018 1 Rev 1.500 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series ISOLATION LIMITING VALUE & CHARACTERISTIC Ths = 25 ˚C unless otherwise specified SYMBOL PARAMETER CONDITIONS Visol Peak isolation voltage from all terminals to external heatsink SOD100 package; R.H. ≤ 65%; clean and dustfree MIN. Visol Cisol TYP. MAX. UNIT - - 1500 V R.M.S. isolation voltage from SOD113 package; f = 50-60 Hz; all terminals to external sinusoidal waveform; R.H. ≤ 65%; clean heatsink and dustfree - - 2500 V Capacitance from pin 2 to external heatsink - 10 - pF MIN. TYP. MAX. UNIT - 55 5.5 7.2 - K/W K/W K/W MIN. TYP. MAX. UNIT - 0.90 1.05 1.20 2.0 0.1 40 1.03 1.25 1.40 50 0.35 60 V V V µA mA nC - 50 60 ns - 4.0 5.5 A - 2.5 - V f = 1 MHz THERMAL RESISTANCES SYMBOL PARAMETER CONDITIONS Rth j-hs Thermal resistance junction to heatsink Thermal resistance junction to ambient with heatsink compound without heatsink compound in free air. Rth j-a ELECTRICAL CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS VF Forward voltage IR Reverse current Qs Reverse recovery charge trr Reverse recovery time Irrm Peak reverse recovery current Vfr Forward recovery voltage IF = 8 A; Tj = 150˚C IF = 8 A IF = 20 A VR = VRRM VR = VRRM; Tj = 100 ˚C IF = 2 A to VR ≥ 30 V; dIF/dt = 20 A/µs IF = 1 A to VR ≥ 30 V; dIF/dt = 100 A/µs IF = 10 A to VR ≥ 30 V; dIF/dt = 50 A/µs; Tj = 100˚C IF = 10 A; dIF/dt = 10 A/µs October 2018 2 Rev 1.500 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series I dI F 12 F dt Q I 95 1.9 2.2 rr 8 6 117 4 128 2 139 100% 10% s 106 2.8 4 rrm 0 Fig.1. Definition of trr, Qs and Irrm I 84 a = 1.57 10 time R Ths(max) / C Vo = 0.89V Rs = 0.019 Ohms t I BYV29 PF / W 0 2 4 IF(AV) / A 6 8 150 10 Fig.4. Maximum forward dissipation PF = f(IF(AV)); sinusoidal current waveform where a = form factor = IF(RMS) / IF(AV). trr / ns 1000 F IF=10 A 100 1A time VF 10 V Tj = 25 C Tj = 100C fr VF 1 time Ths(max) / C BYV29 PF / W Vo = 0.8900 V Rs = 0.0190 Ohms 100 10 dIF/dt (A/us) Fig.5. Maximum trr at Tj = 25˚C and 100˚C Fig.2. Definition of Vfr 15 1 10 67.5 Irrm / A D = 1.0 IF=10A 0.5 1 95 10 0.2 IF=1A 0.1 5 tp I D= T 0 0 5 IF(AV) / A 10 tp T 0.1 122.5 t 0.01 150 15 1 10 -dIF/dt (A/us) 100 Fig.6. Maximum Irrm at Tj = 25˚C and 100˚C. Fig.3. Maximum forward dissipation PF = f(IF(AV)); square wave where IF(AV) =IF(RMS) x √D. October 2018 Tj = 25 C Tj = 100C 3 Rev 1.500 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series BYW29 IF / A 30 10 Transient thermal impedance, Zth j-hs (K/W) Tj=150 C Tj=25 C 1 20 0.1 typ max 10 PD 0.01 0 0.5 0 1 VF / V 1.5 0.001 1us 2 Fig.7. Typical and maximum forward characteristic IF = f(VF); parameter Tj 1000 tp D= T 10us tp T t 100us 1ms 10ms 100ms 1s pulse width, tp (s) BYV29F 10s Fig.9. Transient thermal impedance Zth j-hs= f(tp) Qs / nC IF = 10 A 100 2A 10 1 1.0 10 -dIF/dt (A/us) 100 Fig.8. Maximum Qs at Tj = 25˚C October 2018 4 Rev 1.500 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series MECHANICAL DATA Dimensions in mm 10.2 max 5.7 max 3.2 3.0 Net Mass: 2 g 4.4 max 0.9 0.5 2.9 max 4.4 4.0 7.9 7.5 17 max seating plane 3.5 max not tinned 4.4 13.5 min k 0.4 a 0.9 0.7 M 0.55 max 1.3 5.08 top view Fig.10. SOD100; The seating plane is electrically isolated from all terminals. Notes 1. Refer to mounting instructions for F-pack envelopes. 2. Epoxy meets UL94 V0 at 1/8". October 2018 5 Rev 1.500 WeEn Semiconductors Product specification Rectifier diodes ultrafast BYV29F, BYV29X series MECHANICAL DATA Plastic single-ended package; isolated heatsink mounted; 1 mounting hole; 2-lead TO-220 `full pack' SOD113 A A1 E z(2) P q m T(4) D HE L2 j(3) L1(1) k(3) Q L 1 b1 2 b w c e 0 5 10 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 b b1 c D E e 4.6 2.9 0.9 1.1 0.7 15.8 10.3 4.0 2.5 0.7 0.9 0.4 15.2 9.7 HE max 5.08 19.0 L2 L1(1) max j(3) k(3) L 2.7 0.6 14.4 3.3 1.7 0.4 13.5 2.8 0.5 m P Q 6.5 3.2 2.6 6.3 3.0 2.3 Notes 1. Terminals are uncontrolled within zone L1. 2. z is depth of T. 3. Dot lines area designs may vary. 4. Eject pin mark is for reference only. Outline version SOD113 October 2018 T(4) w z(2) 2.6 2.55 0.4 0.8 sod113_po References IEC q JEDEC European projection JEITA Issue date 07-06-08 15-08-28 2-lead TO-220F 6 Rev 1.500 WeEn Semiconductors Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges whether or not such damages are based on tort (including negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. WeEn Semiconductors Translations — A non-English (translated version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: WeEn Semiconductors: BYV29X-500,127
BYV29X-500,127 价格&库存
很抱歉,暂时无法提供与“BYV29X-500,127”相匹配的价格&库存,您可以联系我们找货
