BYC8X-600,127
BYC8X-600,127
    WEEN(瑞能)
    ITO220FP-2
    DIODE GEN PURP 600V 8A TO220F
BYC8X-600,127 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors BYC8X-600 Hyperfast rectifier diode, low switching loss Rev. 02 — 13 March 2009 Product data sheet 1. Product profile 1.1 General description Hyperfast epitaxial rectifier diode in a SOD113 (2-lead TO-220F) plastic package. 1.2 Features and benefits „ Low reverse recovery current and low thermal resistance „ Reduces switching losses in associated MOSFET 1.3 Applications „ Continuous Current Mode (CCM) Power Factor Correction (PFC) „ Half-bridge/full-bridge switched-mode power supplies „ Half-bridge lighting ballasts 1.4 Quick reference data Table 1. Quick reference Symbol Parameter VRRM repetitive peak reverse voltage IF(AV) average forward current Conditions Min Typ Max Unit - - 600 V square-wave pulse; δ = 0.5; Th = 59 °C; see Figure 1; see Figure 2 - - 8 A IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; see Figure 5 - 19 - ns IF = 8 A; Tj = 150 °C; see Figure 4 - 1.4 1.85 V Dynamic characteristics trr reverse recovery time Static characteristics VF forward voltage BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 K cathode 2 A anode mb n.c. mounting base; isolated Graphic symbol K mb A 001aaa020 1 2 SOD113 (TO-220F) 3. Ordering information Table 3. Ordering information Type number Package Name Description BYC8X-600 TO-220F plastic single-ended package; isolated heatsink mounted; 1 mounting hole; 2-lead TO-220 "full pack" Version SOD113 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VRRM repetitive peak reverse voltage Conditions - 600 V VRWM crest working reverse voltage - 600 V IF(AV) average forward current square-wave pulse; δ = 0.5; Th = 59 °C; see Figure 1; see Figure 2 - 8 A IFRM repetitive peak forward current square-wave pulse; δ = 0.5; tp = 25 µs; Th = 59 °C - 16 A IFSM non-repetitive peak forward current tp = 10 ms; sine-wave pulse; Tj(init) = 25 °C - 80 A tp = 8.3 ms; sine-wave pulse; Tj(init) = 25 °C - 88 A Tstg storage temperature -40 150 °C Tj junction temperature - 150 °C BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 2 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 003aab471 20 Ptot (W) a = 1.57 1.9 16 003aab472 30 Ptot (W) 25 δ =1 2.2 2.8 12 0.5 20 4.0 0.2 15 0.1 8 10 4 5 0 0 0 Fig 1. 2 4 6 IF(AV) (A) 8 0 Forward power dissipation as a function of average forward current; sinusoidal waveform; maximum values Fig 2. 4 8 IF(AV) (A) 12 Forward power dissipation as a function of average forward current; square waveform; maximum values 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Min Typ Max Unit Rth(j-h) thermal resistance from with heatsink compound; see Figure 3 junction to heatsink Conditions - - 4.8 K/W Rth(j-a) thermal resistance from junction to ambient free air - 55 - K/W 001aaf045 10 Zth(j-h) (K/W) 1 10−1 δ= P tp T 10−2 t tp 10−3 10−6 Fig 3. T 10−5 10−4 10−3 10−2 10−1 1 10 tp (s) Transient thermal impedance from junction to heatsink as a function of pulse width BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 3 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 6. Isolation characteristics Table 6. Isolation characteristics Symbol Parameter Conditions Min Typ Max Unit Visol(RMS) RMS isolation voltage f = 1 MHz; RH = 65 %; between all pins and external heatsink - - 2500 V Cisol isolation capacitance from cathode to external heatsink - 10 - pF Conditions Min Typ Max Unit IF = 8 A; Tj = 150 °C; see Figure 4 - 1.4 1.85 V 7. Characteristics Table 7. Symbol Characteristics Parameter Static characteristics VF IR forward voltage reverse current IF = 8 A; Tj = 25 °C - 2 2.9 V IF = 16 A; Tj = 150 °C - 1.7 2.3 V VR = 500 V; Tj = 100 °C - 1.1 3 mA VR = 600 V - 9 150 µA Dynamic characteristics Qr recovered charge IF = 1 A; dIF/dt = 100 A/µs - 12 - nC trr reverse recovery time IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 100 °C - 32 40 ns IF = 1 A; VR = 30 V; dIF/dt = 50 A/µs; Tj = 25 °C - 30 52 ns IF = 8 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 25 °C; see Figure 5 - 19 - ns IF = 10 A; VR = 400 V; dIF/dt = 500 A/µs; Tj = 100 °C - 9.5 12 A IF = 8 A; VR = 400 V; dIF/dt = 50 A/µs; Tj = 125 °C - 1.5 5.5 A IF = 10 A; dIF/dt = 100 A/µs; Tj = 25 °C; see Figure 6 - 8 10 V IRM VFR peak reverse recovery current forward recovery voltage BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 4 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 003aac976 20 dlF IF IF (A) dt 16 trr 12 time 25 % 8 (1) (2) (3) 100 % Qr 4 IRM IR 003aac562 0 0 Fig 4. 1 2 3 VF (V) 4 Fig 5. Reverse recovery definitions; ramp recovery Forward current as a function of forward voltage IF time VF VFRM VF time 001aab912 Fig 6. Forward recovery definitions BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 5 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 8. Package outline Plastic single-ended package; isolated heatsink mounted; 1 mounting hole; 2-lead TO-220 'full pack' SOD113 A A1 E z P q m T D HE L2 j L1(1) k Q L 1 b1 2 b w c M e 0 10 z(2) 20 mm scale 0.8 DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 c D E e HE max j k L L 1(1) L2 max m P Q q T w mm 4.6 4.0 2.9 2.5 0.9 0.7 1.1 0.9 0.7 0.4 15.8 15.2 10.3 9.7 5.08 19.0 2.7 1.7 0.6 0.4 14.4 13.5 3.3 2.8 0.5 6.5 6.3 3.2 3.0 2.6 2.3 2.6 2.55 0.4 Notes 1. Terminals are uncontrolled within zone L1. 2. z is depth of T. OUTLINE VERSION SOD113 Fig 7. REFERENCES IEC JEDEC JEITA 2-lead TO-220F EUROPEAN PROJECTION ISSUE DATE 02-04-09 07-06-18 Package outline SOD113 (TO-220F) BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 6 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 9. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes BYC8X-600_2 20090313 Product data sheet - BYC8X-600_1 Modifications: BYC8X-600_1 • • Forward voltage values updated in characteristics. Recovered charge parameter added in characteristics. 20070905 Product data sheet - BYC8X-600_2 Product data sheet - © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 7 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 10. Legal information 10.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 10.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 10.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 11. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BYC8X-600_2 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 02 — 13 March 2009 8 of 9 BYC8X-600 NXP Semiconductors Hyperfast rectifier diode, low switching loss 12. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 10.1 10.2 10.3 10.4 11 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .3 Isolation characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .6 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .7 Legal information. . . . . . . . . . . . . . . . . . . . . . . . .8 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . .8 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . .8 Contact information. . . . . . . . . . . . . . . . . . . . . . .8 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 13 March 2009 Document identifier: BYC8X-600_2
BYC8X-600,127 价格&库存
很抱歉,暂时无法提供与“BYC8X-600,127”相匹配的价格&库存,您可以联系我们找货
