BYC8B-600,118
BYC8B-600,118
    WEEN(瑞能)
    TO-263
    DIODE GEN PURP 500V 8A D2PAK
BYC8B-600,118 数据手册
DISCRETE SEMICONDUCTORS DATA SHEET BYC8B-600 Rectifier diode ultrafast, low switching loss Product specification March 2001 Product specification WeEn Semiconductors Rectifier diode ultrafast, low switching loss FEATURES BYC8B-600 SYMBOL • Extremely fast switching • Low reverse recovery current • Low thermal resistance • Reduces switching losses in associated MOSFET QUICK REFERENCE DATA VR = 600 V k tab VF ≤ 1.85 V a 3 IF(AV) = 8 A trr = 19 ns (typ) APPLICATIONS • Active power factor correction • Half-bridge lighting ballasts • Half-bridge/ full-bridge switched mode power supplies. The BYC8B-600 is supplied in the SOT404 surface mounting package. PINNING PIN SOT404 DESCRIPTION 1 no connection 2 cathode1 3 anode tab tab 2 1 cathode 3 D2PAK (SOT404) LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER VRRM VRWM VR IF(AV) Peak repetitive reverse voltage Crest working reverse voltage Continuous reverse voltage Average forward current IFRM IFSM Tstg Tj CONDITIONS Tmb ≤ 110 ˚C δ = 0.5; with reapplied VRRM(max); Tmb ≤ 82 ˚C Repetitive peak forward current δ = 0.5; with reapplied VRRM(max); Tmb ≤ 82 ˚C Non-repetitive peak forward t = 10 ms current. t = 8.3 ms sinusoidal; Tj = 150˚C prior to surge with reapplied VRWM(max) Storage temperature Operating junction temperature MIN. MAX. UNIT - 600 600 500 8 V V V A - 16 A - 55 60 A A -40 - 150 150 ˚C ˚C THERMAL RESISTANCES SYMBOL PARAMETER Rth j-mb Thermal resistance junction to mounting base Thermal resistance junction to ambient Rth j-a CONDITIONS minimum footprint, FR4 board MIN. TYP. MAX. UNIT - - 2.2 K/W - 50 - K/W 1 it is not possible to make connection to pin 2 of the SOT404 package March 2001 1 Rev 1.500 WeEn Semiconductors Product specification Rectifier diode ultrafast, low switching loss BYC8B-600 ELECTRICAL CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT VF Forward voltage IF = 8 A; Tj = 150˚C IF = 16 A; Tj = 150˚C IF = 8 A; VR = 600 V VR = 500 V; Tj = 100 ˚C - 1.4 1.7 2.0 9 1.1 1.85 2.3 2.9 150 3.0 V V V μA mA IR Reverse current trr trr Reverse recovery time Reverse recovery time IF = 1 A; VR = 30 V; dIF/dt = 50 A/μs IF = 8 A; VR = 400 V; dIF/dt = 500 A/μs IF = 8 A; VR = 400 V; dIF/dt = 500 A/μs; Tj = 100˚C - 30 19 52 - ns ns trr Reverse recovery time - 32 40 ns Irrm Peak reverse recovery current - 1.5 5.5 A Peak reverse recovery current IF = 8 A; VR = 400 V; dIF/dt = 50 A/μs; Tj = 125˚C IF = 8 A; VR = 400 V; dIF/dt = 500 A/μs; Tj = 125˚C Irrm - 9.5 12 A Vfr Forward recovery voltage IF = 10 A; dIF/dt = 100 A/μs - 8 10 V ID IL Vin Vin Vin = 400 V d.c. Vo = 400 V d.c. IR IF 150 uH typ OUTPUT DIODE inductive load IL 500 V MOSFET Fig.2. Typical application, freewheeling diode in half bridge converter. Continuous conduction mode, where each transistor turns on whilst forward current is still flowing in the other bridge leg diode. Fig.1. Typical application, output rectifier in boost converter power factor correction circuit. Continuous conduction, mode where the transistor turns on whilst forward current is still flowing in the diode. March 2001 2 Rev 1.500 WeEn Semiconductors Product specification Rectifier diode ultrafast, low switching loss 25 Forward dissipation, PF (W) BYC8-600 BYC8B-600 Tmb(max) C 95 D = 1.0 Vo = 1.4 V Rs = 0.05625 Ohms dIF/dt 20 ID = IL 106 0.5 losses due to diode reverse recovery 0.2 15 Irrm ID 117 0.1 time 10 I tp D= T tp VD 139 5 T 0 128 0 2 t 4 6 8 10 Average forward current, IF(AV) (A) 150 12 Fig.6. Origin of switching losses in transistor due to diode reverse recovery. Fig.3. Maximum forward dissipation as a function of average forward current; rectangular current waveform where IF(AV) =IF(RMS) x √D. 0.25 Diode reverse recovery switching losses, Pdsw (W) 100 f = 20 kHz Tj = 125 C 0.2 VR = 400 V 12 A 8A 16 A 0.15 BYC8-600 Reverse recovery time, trr (ns) 12 A IF = 5 A 16 A 0.1 IF = 8 A Tj = 125 C VR = 400 V 0.05 BYC8-600 0 100 Rate of change of current, dIF/dt (A/us) 10 100 1000 Transistor losses due to diode reverse recovery, Ptsw (W) f = 20 kHz Tj = 125 C 7 16 A VR = 400 V 6 12 A 5 8 100 10 8A 3 2 1000 1000 Fig.8. Typical peak reverse recovery current, Irrm as a function of rate of change of current dIF/dt. Fig.5. Typical switching losses in transistor due to reverse recovery of diode, as a function of of change of current dIF/dt. March 2001 BYC8-600 16 A Tj = 125 C VR = 400 V 1 100 Rate of change of current, dIF/dt (A/us) BYC8-600 Rate of change of current, dIF/dt (A/us) Peak reverse recovery current, Irrm (A) IF = 5 A IF = 5 A 1 0 100 1000 Fig.7. Typical reverse recovery time trr, as a function of rate of change of current dIF/dt. Fig.4. Typical reverse recovery switching losses in diode, as a function of rate of change of current dIF/dt. 4 Rate of change of current, dIF/dt (A/us) 3 Rev 1.500 WeEn Semiconductors Product specification Rectifier diode ultrafast, low switching loss I dI F BYC8B-600 dt t 15 rr typ time Q I I R 100% 10% s 5 rrm 0 Peak forward recovery voltage, Vfr (V) max 10 Fig.9. Definition of reverse recovery parameters trr, Irrm 20 BYC8-600 Forward current, IF (A) Tj = 25 C Tj = 150 C 20 F 0 1 2 Forward voltage, VF (V) 3 4 Fig.12. Typical and maximum forward characteristic IF = f(VF); Tj = 25˚C and 150˚C. BYC8-600 100mA BYC8-600 Reverse leakage current (A) Tj = 25 C IF = 10 A 10mA 15 Tj = 125 C typ 100 C 1mA 10 75 C 100uA 50 C 5 25 C 10uA 0 0 50 100 150 Rate of change of current, dIF/dt (A/ s) 1uA 200 Fig.10. Typical forward recovery voltage, Vfr as a function of rate of change of current dIF/dt. I 0 100 200 300 400 Reverse voltage (V) 500 600 Fig.13. Typical reverse leakage current as a function of reverse voltage. IR = f(VR); parameter Tj 10 F Transient thermal impedance, Zth j-mb (K/W) 1 time 0.1 VF PD 0.01 V D= tp T fr VF 0.001 1us time T 10us t 100us 1ms 10ms 100ms 1s pulse width, tp (s) BYC8 10s Fig.14. Maximum thermal impedance Zth j-mb as a function of pulse width. Fig.11. Definition of forward recovery voltage Vfr March 2001 tp 4 Rev 1.500 WeEn Semiconductors Product specification Rectifier diode ultrafast, low switching loss BYC8B-600 MECHANICAL DATA March 2001 5 Rev 1.500 WeEn Semiconductors Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges whether or not such damages are based on tort (including negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. WeEn Semiconductors Translations — A non-English (translated version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners.
BYC8B-600,118 价格&库存
很抱歉,暂时无法提供与“BYC8B-600,118”相匹配的价格&库存,您可以联系我们找货
