BYC10X-600,127
BYC10X-600,127
    WEEN(瑞能)
    ITO220FP-2
    Diode Standard 500V 10A Through Hole TO-220F
BYC10X-600,127 数据手册
Discrete Semiconductors Selection Guide 2011 Diodes, protection and signal conditioning devices, bipolar transistors, MOSFETs, thyristors SOD323 (SC-76) SOD323 (SC-76) SOD882D / SOD882 SOD882D / SOD882 SOD123F SOD123F SOD80C SOD80C SOT883 (SC-101)  Very high ESD protection levels and low capacitances (p. 22 ff) SOT665 4-6 pins 4-6 pins SOT666 SOT666 SOT1118 SOT1118 SOT891 (XSON6) SOT891 (XSON6) SOT886 (XSON6) SOT886 (XSON6) SOT363 (SC-88) SOT363 (SC-88) SOT457 (SC-74) SOT457 (SC-74) 1 mm 1 mm 2 mm 2 mm 3 mm 3 mm 4 mm 4 mm 5 mm 5 mm SOT1157 (HXSON8) SOT1157 (HXSON8) SOT505 (TSSOP8) SOT505 (TSSOP8) SOT552 (TSSOP10) SOT1178 (XSON9) SOT1176 (XSON10) SOT1176 (XSON10) 12 pins and more 12 pins and more 8 - 10 pins SOT1156 (HXSON12) SOT1156 (HXSON12) SOT1158 (HXSON12) SOT1158 (HXSON12) 8 - 10 pins New verySOT1178 small package for very (XSON9) fast data lines with 0.4 mm pitch, enables pass through routing New very small package for very - ESD protection (p. 30 ff) fast data lines with 0.4 mm pitch, enables pass through routing - ESD protection (p. 30 ff) SOT873 (HVSON8) SOT552 (TSSOP10) SOT96 (SO8) SOT873 (HVSON8) SOT617 (HVQFN32) New RF-optimized package for very fast data lines with 0.5 mm pitch, enables pass through routing New RF-optimized package for very - ESD protection (p. 30 ff) fast data lines with 0.5 mm pitch, enables pass through routing - ESD protection (p. 30 ff) SOT617 (HVQFN32) SOT96 (SO8) SOT337 (SSOP14) 10 mm 10 mm 15 mm 15 mm 20 mm 20 mm 25 mm 25 mm 30 mm 6 mm SOT337 (SSOP14) 30 mm 6 mm body length 2 pins 2 pins SOD113 SOD113 SOD59 SOD59 SOT404 SOT404 3 pins SOT428 3 pins SOT428 SOT54 SOT54 SOT82 SOT82 SOT186A SOT186A SOT533 SOT533 SOT226A SOT226A 38 pins 38 pins SOT510 (TSSOP38) SOT510 (TSSOP38) SOT78 SOT78 total length SOT1194 SOT1194  LDOs , 150 mA (p. 96) SOT665 SOT353 (SC-88A) SOT353 (SC-88A) Industry’s smallest  LDOs , 150 mA (p. 96) plastic package for Industry’s smallest plastic package for SOT143B SOT143B With exposed heatMOSFET-Schottky sink for excellent (p. 76)  P-Ch. MOSFET, thermal conductivity  MOSFET-low VCEsat BISS transistor combination (p. 67)  P-Ch. MOSFET, MOSFET-Schottky (p. 76)  MOSFET-low VCEsat BISS transistor combination (p. 67) With exposed heat sink for excellent thermal conductivity body length 3 pins 3 pins SOT883 (SC-101) SOT663 SOT663 SOT1061 (HUSON3) SOT1061 (HUSON3) 0603 inch footprint, only  Verymm high/ 0201 ESD protection levels and 0.3 mm high low capacitances (p. 22 ff) 0603 mm / 0201 inch footprint, only 0.3 mm high SOT416 (SC-75) SOT416 (SC-75) SOT323 (SC-70) SOT323 (SC-70)  Low VCEsat transistors (p. 60 ff)  Schottky rectifiers (p. 11, 12) SOT223 (SC-73) Power-SO8 (LFPAK) Through-hole and SMD packages with total length of + 9 mm Through-hole and SMD packages with total length of + 9 mm total length SOD962 SOD962 SOD523 (SC-79) SOD523 (SC-79) SOD323F (SC-90) SOD323F (SC-90) SOD123W SOT23 SOT23 With heat sink(p. for60 ff)  Lowexposed VCEsat transistors excellent conductivity  Schottkythermal rectifiers (p. 11, 12) With exposed heat sink for excellent thermal conductivity SOT89 (SC-62) SOT89 (SC-62) SOT223 (SC-73) Power-SO8 (LFPAK) Small SMD packages with 8 pins and more Small SMD packages with 8 pins and more  ESD protection (p. 22 ff)  Schottky (p. 11) and switching (p.17) diodes 2 pins First leadless package  ESD protection (p. 22with ff) tin-plated solderable side11) pads, 0.37 mm high  Schottky (p. and only switching (p.17) diodes 2 pins SOD128 SOD128 SOD123W  400 / 600 W TVS diodes (p. 48, 49)  1 - 5 A Schottky rectifiers (p. 10) FlatPower clip diodes bond for  400 / 600with W TVS (p.highest 48, 49) power ratings in a rectifiers small SMD 1-5A Schottky (p.package 10) FlatPower with clip bond for highest power ratings in a small SMD package First leadless package with tin-plated solderable side pads, only 0.37 mm high 1.0 mm 1.0 mm 1.6 mm 1.6 mm 2.0 mm 2.0 mm 2.9 mm 2.9 mm 3.5 mm 3.5 mm 4.5 mm 4.5 mm 6.5 mm 6.5 mm body length Small SMD packages with 2 - 6 pins Small SMD packages with 2 - 6 pins body length Discrete Semiconductors packages – portfolio and highlights Discrete Semiconductors packages – portfolio and highlights Diodes The first leadless package with solderable side pads Solderable (Tin-plated) exposed side pads  Easy visible inspection of solder pads  Very high mechanical robustness  Post-soldering stability Page 7 Protection and signal conditioning Discrete Semiconductors Selection Guide 2011 Page 21 Bipolar transistors Page 51 Full thermal, electrical, mounting and footprint compatibility to leadless 1006 mm packages (inch: 0402)  Height only 0.37 mm MOSFETs Page 69 Built for a range of functions  Protection, Switching and Schottky diodes  Ideal for small and thin devices Thyristors Page 85 Standard & advanced linear products Page 91 Get ready to improve your ultra-flat PCB design with our SOD882D package. Packages Page 99 http://standardproducts.nxp.com Benefit from interactive features in the online edition of this selection guide : A click on a product type takes you to the corresponding product information page on the NXP website. There you’ll find data sheets and other design-support documents. To access the online selection guide, go to www.nxp.com/discrete_selection_guide Index Page 122 Table of Contents Support tools 6 Diodes 7 Schottky barrier diodes and rectifiers General purpose Schottky diodes ≤ 250 mA Low capacitance Schottky diodes Medium power low VF Schottky rectifiers single ≥ 200 mA Medium power low VF Schottky rectifiers dual ≥ 200 mA Improved forward characteristics of (MEGA) Schottky rectifiers in new packages Zener diodes General purpose Zener diodes Zener diodes specifications Switching diodes General purpose switching diodes ≤ 100 V General purpose switching diodes > 100 V Controlled avalanche switching diodes Low leakage current switching diodes Power diodes 14 15 16 16 18 19 19 Standard ESD protection devices 22 Low capacitance ESD protection devices 24 ESD protection for very high speed interfaces (< 2 pF) 28 Application-specific ESD and ESD/EMI solutions 32 General purpose bipolar transistors Single transistors NPN Single transistors PNP Double transistors Single and double switching transistors Medium power general purpose transistors High voltage transistors Low noise transistors Matched pair transistors Darlington transistors Schmitt trigger MOSFET driver Medium frequency transistors High voltage power bipolar transistors High voltage bipolar transistors for lighting, SMPS and industrial applications MOSFETs Small-signal Small-signal Small-signal Small-signal Small-signal Small-signal 32 32 36 42 42 43 47 48 48 48 49 58 58 59 59 59 60 60 62 64 65 66 66 67 67 68 68 69 Small-signal MOSFETs 20 21 Bipolar transistors Low VCEsat (BISS) transistors single NPN Low VCEsat (BISS) transistors single PNP Low VCEsat (BISS) double transistors Low VCEsat (BISS) load switches High voltage low VCEsat (BISS) transistors Low VCEsat (BISS) RETs Low VCEsat (BISS) transistor PNP – N-channel MOSFET combination Advantages of low VCEsat (BISS) technology 14 Protection and signal conditioning TVS diodes, 24 W / 40 W TVS diodes, 400 W TVS diodes, 600 W Low VCEsat (BISS) transistors 8 9 10 12 13 20 20 TVS diodes RETs 100 mA single RETs 100 mA double RETs 500 mA Low VCEsat (BISS) RETs 8 Ultrafast recovery power diodes Hyperfast power diodes Audio interfaces Video interfaces Multichannel EMI filters, ESD protection for LCD and camera SD-, SIM-card and MMC Battery and charger protection USB, SATA, LAN Automotive LIN/CAN/FlexRay 4 Resistor-equipped transistors (RETs) MOSFETs single (N-channel) < 50 V MOSFETs single (N-channel) ≥ 50 V MOSFETs dual (N-channel) MOSFETs single (P-Channel) MOSFET – Schottky combination MOSFETs dual (P-channel) Power MOSFETs 12 V - 25 V N-channel MOSFETs 30 V N-channel MOSFETs 40 V - 55 V N-channel MOSFETs 60 V - 80 V N-channel MOSFETs 100 V - 110 V N-channel MOSFETs 150 V - 300 V N-channel MOSFETs P-channel MOSFETs Multi-chip MOSFETs Thyristors 70 70 72 74 74 76 76 77 77 78 79 80 81 82 83 83 85 4-Quadrant Triacs 86 3-Quadrant Triacs 88 AC Thyristors 89 Silicon Controlled Rectifiers 89 Standard & advanced linear products 91 Adjustable shunt voltage regulator TL431 92 52 Adjustable shunt voltage regulator TLVH431 93 52 52 53 53 Discrete voltage regulator / Constant current source 94 Low-dropout regulator 95 Advanced linear ultra low-dropout voltage regulators 96 51 54 54 54 55 56 56 57 57 Packages 99 Package cross reference 100 Packing methods 102 Minimized outline drawings and reflow soldering footprint 108 Index 122 5 Support tools Check the NXP Standard Products Portal www.standardproducts.nxp.com Your first stop for NXP‘s wide range of diodes, bipolar transistors, MOSFETs, thyristors and ESD protection products. The gateway focuses on: - Product and application information - Recently launched products - News items and related documents - Design hints, with simple solutions to some of today‘s common design challenges, incl. energy efficiency, integration, packaging, and protection Diodes Direct links to popular design support tools and items: Datasheets http://standardproducts.nxp.com/all_datasheets Find cross references of industry type numbers and download X-Reference offline tool http://www.nxp.com/search/advanced Application notes http://standardproducts.nxp.com/all_appnotes Sales literature http://standardproducts.nxp.com/all_literature Selection Guide (download pdf file) http://www.nxp.com/discrete_selection_guide Models and test data http://www.nxp.com/models Schottky barrier diodes and rectifiers General purpose Schottky diodes ≤ 250 mA Low capacitance Schottky diodes Medium power low VF Schottky rectifiers single ≥ 200 mA Medium power low VF Schottky rectifiers dual ≥ 200 mA Improved forward characteristics of (MEGA) Schottky rectifiers in new packages Zener diodes General purpose Zener diodes Zener diodes specification Switching diodes General purpose switching diodes ≤ 100 V General purpose switching diodes > 100 V Controlled avalanche switching diodes Low leakage current switching diodes Power diodes Ultrafast recovery power diodes Hyperfast power diodes 8 8 9 10 12 13 14 14 15 16 16 18 19 19 20 20 20 Technical support portal http://www.nxp.com/technical_support FAQ (Frequently Asked Questions) Discretes http://www.nxp.com/faq_discretes Direct support needed? Find complete contact information to your regional NXP sales offices and distributors http://www.nxp.com/profile/sales 6 7 Schottky barrier diodes and rectifiers Diodes Schottky barrier diodes and rectifiers General purpose Schottky diodes ≤ 250 mA types in bold represent new products SOD80C (MiniMelf) SOD68 (DO-34) SOT23 SOT143B SOT323 (SC-70) SOD123F SOT363 (SC-88) SOD323F (SC-90) SOD323 (SC-76) SOT416 (SC-75) SOT666 SOD523 (SC-79) SOD882/ SOT883 (SC-101) 70 750 10 0.1 BOTTOM VIEW M3D088 @ VR (V) IR max (μA) @ IF (mA) VF max (mV) VR max (V) 70 M3D050 IF max (mA) Package 50 Size (mm) 3.5 x 1.5 x 1.5 3.04 x 1.6 x 0.55 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.6 x 0.8 x 0.77 1.2 x 0.8 x 0.6 Ptot (mW) 300 500 250 250 830 250 300 550 400 300 150 500 250 BAS70H BAS70W 1PS79SB70 BAS70L RB751V40 RB751S40 RB751CS40 1PS76SB40 1PS79SB40 BAS40L single BAS70 dual series BAS70-04 BAS70-04W dual c.c. BAS70-05 BAS70-05W dual c.a. BAS70-06 dual isolated 1PS76SB70 BAS70-06W BAS70-07 BAS70-07S BAS70-07V triple isolated BAS70VV quad 2x series 370 120 40 500 1 0.5 10 1 30 BAS70XY single 30 single BAS40 dual series BAS40-04 BAS40-04W dual c.c. BAS40-05 BAS40-05W dual c.a. BAS40-06 BAS40-06W dual isolated 300 10 30 10 10 2 BAS40H BAS40W 1PS75SB45 BAS40-07 BAS40-07V quad c.c./c.c. 1PS88SB48 quad 2x series BAS40XY 1PS79SB31 25 BAT754 dual series BAT754S dual c.c. BAT754C dual c.a. BAT754A triple isolated BAT754L single 30 400 10 2 BAS40-05V single single 340 25 BAS85 BAT85 BAT54 BAT54H BAT54W BAT54J dual series BAT54S BAT54SW dual c.c. BAT54C BAT54CW dual c.a. BAT54A BAT54AW dual isolated 1PS76SB10 BAT54T BAT74 BAT74S BAT74V quad c.c./c.c. BAT54CV BAT54XY 500 200 30 10 single RB521S30 RB521CS30L 600 200 1 10 single RB520S30 RB520CS30L single 300 10 15 30 360 10 0.5 25 BAT721 dual series BAT721S dual c.c. BAT721C dual c.a. BAT721A 1PS76SB21 single 1PS79SB30 single BAT854W dual series BAT854SW dual c.c. BAT854CW 420 30 0.5 25 50 450 10 5 40 single 100 850 250 4 75 single dual c.a. 250 single dual series dual c.c. dual c.a. BAT854AW BAS86 BAT86 BAT46WH dual isolated triple isolated quad c.c./c.c. quad 2x series BAT46WJ Low capacitance Schottky diodes brb127 brb129 brb130 brb131 4 6 6 6 5 4 1 1 2 5 5 1 21, 2 5, 6 3 1, 2 5, 6 3, 4 3 SOT323 (SC-70) SOT363 (SC-88) SOD323 (SC-76) SOT666 SOD523 (SC-79) SOD882 Package M3D088 Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.2 x 0.8 x 0.6 1.0 x 0.6 x 0.5 Ptot (mW) 250 250 300 400 300 500 250 single BAT17 1PS76SB17 triple isolated dual series single 15 3, 4 mhc634 1) 340 1 1 1PS79SB17 1PS66SB17 PMBD353 PMBD354 1) 1PS70SB82 triple isolated 3, 4 mhc634 mhc634 8 3 1 30 1, 2 5, 6 2 1 brb128 4 4 450 @ VR = 0 V brb126 Cd max (pF) brb125 VF max (mV) brb124 @ IF (mA) brb122 VR max (V) IF max (mA) SOT23 brb123 BAT54L BAT54VV quad 2x series 40 1PS79SB10 BAT54CM triple isolated 200 1.0 x 0.6 x 0.5 1PS10SB82 1PS88SB82 dual series 1PS70SB84 dual c.c. 1PS70SB85 dual c.a. 1PS70SB86 1PS66SB82 Diodes have matched capacitance 9 Schottky barrier diodes and rectifiers Diodes Schottky barrier diodes and rectifiers Medium power low VF Schottky rectifiers single ≥ 200 mA types in bold represent new products SOD128 SOT457 (SC-74) SOT23 Size (mm) 3.8 x 2.5 x 1.0 2.9 x 1.5 x 1.0 Ptot (mW) @ 1 cm² 1050 540 SOD123W SOD123F SOT1061 SOT323 (SC-70) SOD323F (SC-90) SOD323 (SC-76) SOT666 SOD523 (SC-79) SOD882 SOD882D 2.9 x 1.3 x 1.0 2.6 x 1.7 x 1.0 2.6 x 1.6 x 1.1 2.0 x 2.0 x 0.65 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.2 x 0.8 x 0.6 1.0 x 0.6 x 0.5 1.0 x 0.6 x 0.37 420 950 830 1000 250 830 570 570 450 250 250 IR max (mA) 480 0.04 low VF PMEG3002EJ PMEG3002AEB PMEG3002AEL PMEG3002AELD 600 0.01 low IR PMEG4002EJ PMEG4002EB PMEG4002EL PMEG4002ELD 60 600 0.1 low VF PMEG6002EJ PMEG6002EB PMEG2005AEL PMEG2005AELD PMEG2005EL PMEG2005ELD PMEG3005EL PMEG3005ELD 0.5 30 40 20 1.0 30 40 0.2 low VF 1.5 low VF 480 0.01 low IR 500 0.03 low IR 430 0.15 low VF 500 0.5 low VF 470 0.1 550 340 PMEG2005ET PMEG2005EH PMEG2005EJ PMEG2005AEA PMEG3005ET PMEG3005EH PMEG3005EJ PMEG3005AEA PMEG3005AEV low VF PMEG4005ET PMEG4005EH PMEG4005EJ PMEG4005AEA PMEG4005AEV 0.1 low VF BAT720 1 low VF 375 1.9 low VF 430 0.2 low VF 450 0.05 low IR 500 0.2 low VF PMEG2010EJ PMEG2010BEA PMEG2010BEV PMEG2010EA PMEG2010EV BAT760 BAT960 550 0.07 low IR 620 1.5 low VF 450 1.0 low VF PMEG3005EB 1PS70SB20 PMEG2010ER PMEG2010EPA PMEG2010AET PMEG2010AEH PMEG2010BER PMEG2010ET PMEG2010EH PMEG2010AEJ PMEG2010AEB 1PS74SB23 360 1.5 low VF PMEG3010EP PMEG3010ER 450 0.05 low IR PMEG3010BEP PMEG3010BER 520 0.05 low IR 560 0.15 low VF 680 0.5 low VF 490 0.05 low VF 640 0.1 low VF 570 0.05 low IR PMEG3010ET PMEG3010CEH PMEG3010CEJ PMEG3010EH PMEG3010EJ PMEG3010BEA PMEG4010ER PMEG4010ET PMEG6010EP PMEG4010EH PMEG4010EJ PMEG4010CEH PMEG4010CEJ PMEG4010BEA PMEG4010BEV PMEG2015EA PMEG2015EV PMEG6010ER 0.06 low VF 0.35 low VF 660 0.05 low IR PMEG6010CEH PMEG6010CEJ 20 660 0.07 low IR PMEG2015EH PMEG2015EJ 30 550 1.0 low VF PMEG3015EH PMEG3015EJ 10 460 3.0 low VF PMEG1020EH PMEG1020EJ PMEG1020EA 420 1.9 low VF PMEG2020EJ PMEG2020AEA 60 10 30 3.0 40 60 30 40 PMEG6010AED 525 0.2 low VF 3.0 low VF PMEG3020EP 420 1.5 low VF PMEG3020CEP 450 0.1 low IR PMEG3020BEP 470 2.5 low VF 520 0.05 low IR 620 1.0 low VF 0.1 low VF 535 0.1 low VF 530 0.15 low VF 575 0.25 low VF PMEG3015EV PMEG1020EV PMEG2020EPA 360 490 PMEG3010BEV PMEG3010EB PMEG4010EP 530 30 PMEG2005AEV PMEG2005EB 650 40 5.0 390 440 60 20 2.0 Optimization PMEG2020EH PMEG3020ER PMEG3020EPA PMEG3020dEP PMEG3020BER PMEG4020EP PMEG4020ER PMEG6020EP PMEG6020ER PMEG3020EH PMEG3020EJ PMEG4020EPA PMEG6020EPA PMEG1030EH 530 3.0 low VF 360 5.0 low VF PMEG3030EP 450 0.15 low IR PMEG3030BEP PMEG4030EP 490 0.2 low VF 540 0.1 low IR 530 0.2 low VF 360 8.0 low VF PMEG3050EP 450 0.25 low IR PMEG3050BEP 490 0.3 low VF PMEG4050EP PMEG4030ER PMEG6030EP PMEG1030EJ In the Spotlight 1.5 @ VR max VR max (V) 30 40 @ IF max IF max (A) M3D088 0.2 20 10 VF max (mV) Package Low VF (MEGA) Schottky rectifiers in new leadless SOD882D Ultra low package height of only 0.37 mm typ Tin-plated solderable side pads Ultra small dimensions 1.0 x 0.6 mm Portfolio of five low VF (MEGA) Schottky diodes (IF up to 0.5 A) AEC-Q101 qualified 11 Schottky barrier diodes and rectifiers Medium power low VF Schottky rectifiers dual ≥ 200 mA Optimization @ VR max IR max (mA) VF max (mV) @ IF max VR max (V) IF max (A) SOT223 (SC-73) 30 480 0.03 low VF 60 600 0.1 low VF 20 390 0.2 low VF 30 430 0.15 low VF types in bold represent new products SOT23 SOT1061 Improved forward characteristics of (MEGA)1 Schottky rectifiers in new packages Forward Characteristics : IF versus VF (typical curves @ 25 °C) SOT666 Package 2.0 M3D088 Size (mm) 6.5 x 3.5 x 1.65 2.9 x 1.3 x 1.0 2.0 x 2.0 x 0.65 1.6 x 1.2 x 0.55 Ptot (mW) 1500 250 1000 300 dual isolated 40 470 0.1 PMEG6002TV PMEG2005CT low VF PMEG4005CT Improved performance 1.0 0.8 dual series 0.6 BAT120S low VF Equivalent wire-bond SMD type 30 V/2 A 1.2 PMEG3005CT brb125 PMEG3020EPA 1.4 IF [A] 0.5 PMEG3020ER 1.6 0.2 brb127 PMEG3020EP 1.8 PMEG3002TV dual c.c. Diodes Schottky barrier diodes and rectifiers brb148 0.4 dual c.c. 25 450 1.0 BAT120C low VF 0.2 brb149 dual c.a. 0 BAT120A low VF 0 0.1 0.2 0.3 0.4 0.5 0.6 brb150 VF [V] dual c.c. 40 500 0.05 PMEG4010CPA low VF 1) Maximum Efficiency General Application brb125 1.0 dual c.c. 0.06 PMEG6010CPA low VF In the Spotlight 540 brb125 dual series low VF BAT160S brb148 60 dual c.c. 650 0.35 BAT160C low VF brb125 dual c.a. 3 and 5 A low VF (MEGA) Schottky rectifiers in SOD123W and SOD128 Small FlatPower packages SOD123W/128, only 1 mm high Very low forward voltage drop VF down to 340 mV Low reverse current IR down to 0.05 mA High power capability due to clip-bonding technology and optimized die design AEC-Q101 qualified BAT160A low VF brb150 dual c.c. 20 420 1.0 PMEG2020CPA low VF brb125 2.0 Nomenclature of low VF (MEGA) Schottky rectifiers dual c.c. 30 440 2.0 PMEG 20 10 A E V PMEG3020CPA low VF brb125 NXP MEGA Schottky rectifier In the Spotlight Max. reverse voltage in V e.g. 20 = 20 V 12 Medium power single and dual Schottky rectifiers in SOT1061 Small (2 x 2 x 0.65 mm) leadless medium power package SOT1061 Exposed heat sink for excellent thermal and electrical performance (Ptot > 1 W) High forward-current capability (IF up to 2 A) with low forward voltage drop High reverse voltage (VF up to 60 V) AEC-Q101 qualified Cont. foward current in A e.g. 10 = 1.0 A Variant number (optional) Internal configuration: E = single A = CA C = CC S = series P = double, parallel R = triple, anti-parallel V = triple Z = 2 x CA Y = 2 x CC X = 2 x series W = CA and CC Package Indicator: A = SOD323 B = SOD523 D = SOT457 H = SOD123 J = SOD323F T = SOT23 V = SOT666 L = SOD882 P = SOD128 PA = SOT1061 R = SOD123W LD = SOD882D 13 Zener diodes - Japanese spec (PZU, PDZ) y= Configuration Series 1N47xxA series C Zener diodes specifications Differences in Zener specifications 3.3~24 500 60 types in bold represent new products Package Size (mm) Note VZ tolerance VZ nom (V) PZSM (W) IF max (mA) General purpose Zener diodes Diodes Zener diodes Eur SOD66 (DO-41) single 4.8 x 2.6 x 0.81 3.6~75 brb118 1000 BZV85 series M3D130 - 2.4~36 about 2% special 40 2.4~75 B, C Eur 250 NZX series SOD27 (DO-35) single 4.25 x 1.85 x 0.56 brb118 400 BZX79 series M3D176 400 40 2.4~75 C Eur SOT223 (SC-73) 3 1 single BZV90 series 6.5 x 3.5 x 1.65 1500 2, 4 006aab234 SOT89 (SC-62) 250 40 2.4~75 C Eur single 1 3 BZV49 series 4.5 x 2.5 x 1.5 1000 2 sym096 M3D109 SOD80C (MiniMelf) 250 40 2.4~75 B, C Eur single BZV55 series 3.5 x 1.5 x 1.5 300 brb118 200 40 2.4~75 B, C Eur A, B, C 0.2 V 250 30 5~6.8 Ave dual c.a. BZB84 series SOT23 brb120 BZX84 series single brb119 2.9 x 1.3 x 1.0 PLVA600A series 250 M3D088 0.2 V Ave dual c.a. PLVA2600A series brb120 - 3.0~30 about 2.5% special 40 2.4~75 B, C Eur 250 NZH series 2.6 x 1.6 x 1.1 brb118 5 200 SOD123F single 40 2.7~24 B2 Jap dual isolated SOT353 (SC-88A) 2.0 x 1.25 x 0.95 2 300 3 006aab219 SOT323 (SC-70) 200 40 2.4~15 C Eur dual c.a. BZB784 series 2.0 x 1.25 x 0.95 350 brb120 30 100 C Eur 40 2.4~36 B2 Jap 250 40 2.4~75 B, C Eur 200 40 2.4~36 B, B1, B2, B3 Jap 200 60 100 C Eur 200 40 2.4~36 B, B1, B2, B3 Jap 200 250 back-to-back 40 2.4~75 B, C Eur 40 2.4~15 C Eur 2.4~75 B, C Eur 200 B, C Eur 2.4~36 B, B2 Jap 40 180 C Eur 2.8 - 3.05 2.95 - 3.2 - PZU3.3y 3.1 - 3.5 3.1 - 3.35 3.25 - 3.5 - PZU3.6y 3.4 - 3.8 3.4 - 3.65 3.55 - 3.8 - PZU3.9y 3.7 - 4.1 3.7 - 3.97 3.87 - 4.1 - PZU4.3y 4.01 - 4.48 4.01 - 4.21 4.15 - 4.34 4.28 - 4.48 PZU4.7y 4.42 - 4.9 4.42 - 4.61 4.55 - 4.75 4.69 - 4.9 PZU5.1y 4.84 - 5.37 4.84 - 5.04 4.98 - 5.2 5.14 - 5.37 PZU5.6y 5.31 - 5.92 5.31 - 5.55 5.49 - 5.73 5.67 - 5.92 PZU6.2y 5.86 - 6.53 5.86 - 6.12 6.06 - 6.33 6.26 - 6.53 PZU6.8y 6.47 - 7.14 6.47 - 6.73 6.65 - 6.93 6.86 - 7.14 PZU7.5y 7.06 - 7.84 7.06 - 7.36 7.28 - 7.6 7.52 - 7.84 PZU8.2y 7.76 - 8.64 7.76 - 8.1 8.02 - 8.36 8.28 - 8.64 PZU9.1y 8.56 - 9.55 8.56 - 8.93 8.85 - 9.23 9.15 - 9.55 PZU10y 9.45 - 10.55 9.45 - 9.87 9.77 - 10.21 10.11 - 10.55 PZU11y 10.44 - 11.56 10.44 - 10.88 10.76 - 11.22 11.1 - 11.56 PZU12y 11.42 - 12.6 11.42 - 11.9 11.74 - 12.24 12.08 - 12.6 PZU13y 12.47 - 13.96 12.47 - 13.03 12.91 - 13.49 13.37 - 13.96 PZU14y - - 13.7 - 14.3 - PZU15y 13.84 - 15.52 13.84 - 14.46 14.34 - 14.98 14.85 - 15.52 PZU16y 15.37 - 17.09 15.37 - 16.01 15.85 - 16.51 16.35 - 17.09 PZU18y 16.94 - 19.03 16.94 - 17.7 17.56 - 18.35 18.21 - 19.03 PZU20y 18.86 - 21.08 18.86 - 19.7 19.52 - 20.39 20.21 - 21.08 PZU22y 20.88 - 23.17 20.88 - 21.77 21.54 - 22.47 22.23 - 23.17 PZU24y 22.93 - 25.57 22.93 - 23.96 23.72 - 24.78 24.54 - 25.57 PZU27y 25.1 - 28.9 - - - PZU30y 28 - 32 - - - PZU33y 31 - 35 - - - PZU36y 34 - 38 - - - BZX84-y2V4 C-series B-series ± 5% ± 2% A-series ± 1% VZ (V) VZ (V) VZ (V) 2.2 - 2.6 2.35 - 2.45 2.37 - 2.43 NZX-series in SOD27 VZ (V) NZX2V4A 2.3 - 2.5 VZ (V) VZ (V) NZX6V2D 6.1 - 6.4 NZX14B 13.5 - 14 BZX84-y2V7 2.5 - 2.9 2.65 - 2.75 2.67 - 2.73 NZX2V4B 2.4 - 2.6 NZX6V2E 6.3 - 6.6 NZX14C 13.8 - 14.3 BZX84-y3V0 2.8 - 3.2 2.94 - 3.06 2.97 - 3.03 NZX2V7A 2.5 - 2.7 NZX6V8A 6.4 - 6.7 NZX15A 14.1 - 14.7 BZX84-y3V3 3.1 - 3.5 3.23 - 3.37 3.26 - 3.34 NZX2V7B 2.6 - 2.8 NZX6V8B 6.6 - 6.9 NZX15B 14.5 - 15.1 BZX84-y3V6 3.4 - 3.8 3.53 - 3.67 3.56 - 3.64 NZX2V7C 2.7 - 2.9 NZX6V8C 6.7 - 7 NZX15C 14.9 - 15.5 BZX84-y3V9 3.7 - 4.1 3.82 - 3.98 3.86 - 3.94 NZX3V0A 2.8 - 3 NZX6V8D 6.9 - 7.2 NZX15X 14.35 - 15.09 7 - 7.3 NZX16A 15.3 - 15.9 7.2 - 7.6 NZX16B 15.7 - 16.5 BZX84-y5V1 4.8 - 5.4 5 - 5.2 5.04 - 5.16 NZX3V3A 3.1 - 3.3 NZX7V5C 7.3 - 7.7 NZX16C 16.3 - 17.1 BZX84-y5V6 5.2 - 6 5.49 - 5.71 5.54 - 5.66 NZX3V3B 3.2 - 3.4 NZX7V5D 7.5 - 7.9 NZX18A 16.9 - 17.7 BZX384 series BZX84-y6V2 5.8 - 6.6 6.08 - 6.32 6.13 - 6.27 NZX3V3C 3.3 - 3.5 NZX7V5X 7.07 - 7.45 NZX18B 17.5 - 18.3 PZUxBA series BZX84-y6V8 6.4 - 7.2 6.66 - 6.94 6.73 - 6.87 NZX3V6A 3.4 - 3.6 NZX8V2A 7.7 - 8.1 NZX18C 18.1 - 19 BZX84-y7V5 7 - 7.9 7.35 - 7.65 7.42 - 7.58 NZX3V6B 3.5 - 3.7 NZX8V2B 7.9 - 8.3 NZX20A 18.8 - 19.7 1.7 x 1.25 x 0.95 300 SOD323F (SC-90) 1.7 x 1.25 x 0.7 550 BZX84J series 1.6 x 1.2 x 0.55 1.2 x 0.8 x 0.6 350 300 SOD882 1.0 x 0.6 x 0.5 250 PZUxBL series TDZ5V6J brb118 14 2.8 - 3.2 NZX7V5B BZX884 series single - PZU3.0y NZX7V5A single 5.6 - 2.65 - 2.9 3 - 3.2 SOD323F 250 - 2.5 - 2.75 2.9 - 3.1 BZX585 series brb118 - 2.5 - 2.9 NZX3V0B brb118 2.4~75 2.3 - 2.6 PZU2.7y NZX3V0C BZB984 series single PZU2.4y 4.25 - 4.35 SOD523 (SC-79) 40 VZ (V) 4.65 - 4.75 brb120 200 VZ (V) 4.21 - 4.39 PZUxB series dual c.a. VZ (V) 4.61 - 4.79 SOT663 200 ± 2% VZ (V) 4 - 4.6 BZX100A brb118 B3-series 4.4 - 5 PDZ-B series single ± 2% BZX84-y4V3 SOD323 (SC-76) mse211 brb118 B2-series ± 2% BZX84-y4V7 BZB100A single B1-series ± 5% European spec (BZV, BZX, BZB, 1N47) y= PZUxDB2 series 1 830 BZT52H series 4 B-series Ptot (mW) Notes: Jap: B selection: app. 5% Vz tolerance, B1, B2, B3 selections: app. 2% Vz tolerance in sequential intervals Eur: A selection: app. 1% Vz tolerance, B selection: app. 2% Vz tolerance, C selection: app. 5% Vz tolerance; the selections are in overlapping intervals Ave: low voltage avalanche regulator diodes dual c.a.: dual common anode 1.7 x 1.25 x 0.7 500 BZX84-y8V2 7.7 - 8.7 8.04 - 8.36 8.11 - 8.29 NZX3V6C 3.6 - 3.8 NZX8V2C 8.1 - 8.5 NZX20B 19.5 - 20.4 BZX84-y9V1 8.5 - 9.6 8.92 - 9.28 9 - 9.2 NZX3V9A 3.7 - 3.9 NZX8V2D 8.3 - 8.7 NZX20C 20.2 - 21.2 BZX84-y10 9.4 - 10.6 9.8 - 10.2 9.9 - 10.1 NZX3V9B 3.8 - 4 NZX9V1A 8.5 - 8.9 NZX22A 20.9 - 21.9 BZX84-y11 10.4 - 11.6 10.8 - 11.2 10.8 - 11.11 NZX3V9C 3.9 - 4.1 NZX9V1B 8.7 - 9.1 NZX22B 21.6 - 22.6 BZX84-y12 11.4 - 12.7 11.8 - 12.2 11.88 - 12.12 NZX4V3A 4 - 4.2 NZX9V1C 8.9 - 9.3 NZX22C 22.3 - 23.3 BZX84-y13 12.4 - 14.1 12.7 - 13.3 12.87 - 13.13 NZX4V3B 4.1 - 4.3 NZX9V1D 9.1 - 9.5 NZX24A 22.9 - 24 BZX84-y15 13.8 - 15.6 14.7 - 15.3 14.85 - 15.15 NZX4V3C 4.2 - 4.4 NZX9V1E 9.3 - 9.7 NZX24B 23.6 - 24.7 BZX84-y16 15.3 - 17.1 15.7 - 16.3 15.84 - 16.16 NZX4V3D 4.3 - 4.5 NZX10A 9.5 - 9.9 NZX24C 24.3 - 25.5 BZX84-y18 16.8 - 19.1 17.6 - 18.4 17.82 - 18.18 NZX4V7A 4.4 - 4.6 NZX10B 9.7 - 10.1 NZX24X 22.61 - 23.77 BZX84-y20 18.8 - 21.2 19.6 - 20.4 19.8 - 20.2 NZX4V7B 4.5 - 4.7 NZX10C 9.9 - 10.3 NZX27A 25.2 - 26.6 BZX84-y22 20.8 - 23.3 21.6 - 22.4 21.78 - 22.22 NZX4V7C 4.6 - 4.8 NZX10D 10.2 - 10.6 NZX27B 26.2 - 27.6 BZX84-y24 22.8 - 25.6 23.5 - 24.5 23.76 - 24.24 NZX4V7D 4.7 - 4.9 NZX11A 10.4 - 10.8 NZX27C 27.2 - 28.6 BZX84-y27 25.1 - 28.9 26.5 - 27.5 26.73 - 27.27 NZX5V1A 4.8 - 5 NZX11B 10.7 - 11.1 NZX27X 26.99 - 28.39 BZX84-y30 28 - 32 29.4 - 30.6 29.70 - 30.30 NZX5V1B 4.9 - 5.1 NZX11C 10.9 - 11.3 NZX30A 28.2 - 29.6 BZX84-y33 31 - 35 32.3 - 33.7 32.67 - 33.33 NZX5V1C 5 - 5.2 NZX11D 11.1 - 11.6 NZX30B 29.2 - 30.6 BZX84-y36 34 - 38 35.3 - 36.7 35.64 - 36.36 NZX5V1D 5.1 - 5.3 NZX12A 11.4 - 11.9 NZX30C 30.2 - 31.6 BZX84-y39 37 - 41 38.2 - 39.8 38.61 - 39.39 NZX5V6A 5.2 - 5.5 NZX12B 11.6 - 12.1 NZX30X 29.02 - 30.51 BZX84-y43 40 - 46 42.1 - 43.9 42.57 - 43.43 NZX5V6B 5.3 - 5.6 NZX12C 11.9 - 12.4 NZX33A 31.2 - 32.6 BZX84-y47 44 - 50 46.1 - 47.9 - NZX5V6C 5.4 - 5.7 NZX12D 12.2 - 12.7 NZX33B 32.2 - 33.6 BZX84-y51 48 - 54 50 - 52 50.49 - 51.51 NZX5V6D 5.5 - 5.8 NZX12X 11.44 - 12.03 NZX33C 33.2 - 34.5 BZX84-y56 52 - 60 54.9 - 57.1 - NZX5V6E 5.6 - 5.9 NZX13A 12.4 - 12.9 NZX36A 34.2 - 35.7 BZX84-y62 58 - 66 60.8 - 63.2 - NZX6V2A 5.7 - 6 NZX13B 12.6 - 13.1 NZX36B 35.3 - 36.8 BZX84-y68 64 - 72 66.6 - 69.4 - NZX6V2B 5.8 - 6.1 NZX13C 12.9 - 13.4 NZX36C 36.4 - 38 BZX84-y75 70 - 79 73.5 - 76.5 74.25 - 75.75 NZX6V2C 6 - 6.3 NZX14A 13.2 - 13.7 NZX36X 35.36 - 37.19 15 Switching diodes Diodes Switching diodes General purpose switching diodes ≤ 100 V types in bold represent new products SOD27 (DO-35) SOD68 (DO-34) SOD80C (MiniMelf) SOT23 SOT143B SOD123F SOT323 (SC-70) SOT363 (SC-88) SOD323 (SC-76) SOD323F (SC-90) SOT666 SOT416 (SC-75) SOD523 (SC-79) SOD882 SOT883 (SC-101) SOD882D trr max (ns) @ VR (V) IR max (nA) @ IF (mA) VF max (V) M3D050 M3D176 VR max (V) Package M3D088 BOTTOM VIEW Size (mm) 4.25 x 1.85 x 0.56 3.04 x 1.6 x 0.55 3.5 x 1.5 x 1.5 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.6 x 1.2 x 0.55 1.6 x 0.8 x 0.77 1.2 x 0.8 x 0.6 1.0 x 0.6 x 0.5 1.0 x 0.6 x 0.5 1.0 x 0.6 x 0.37 Ptot (mW) 500 500 500 250 250 830 200 300 400 550 180 170 500 250 250 250 BAL74 50 1 50 100 50 4 BAV74 bra046 70 1 50 1000 70 4 10 25 20 4 BAL99 1N4531 bra036 75 1 50 1000 75 4 BAS28 bra037 100 5000 75 4 BAS32L bra036 BAW56 BAW56W BAW56T BAW56M bra143 90 1 50 500 80 4 BAW56S BAV756S 10 25 20 4 1N4148 bra036 BAS16H bra036 BAS16 BAS316 BAS16J BAS16W BAS16T bra048 BAS516 BAS16LD BAS16L bra036 100 1 BAS16VY BAS16VV bra038 50 500 80 4 BAV70 BAV70W BAV70T BAV70M bra046 BAV70S BAV99 BAV99W bra041 BAV99S 16 17 Switching diodes General purpose switching diodes > 100 V Controlled avalanche switching diodes SOD27 SOD80C SOT457 (DO-35) (MiniMelf) (SC-74) SOT23 SOT143B SOD123F SOT323 (SC-70) SOT363 (SC-88) SOD323 SOD323F SOD523 (SC-76) (SC-90) (SC-79) SOT23 100 150 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.2 x 0.8 x 0.6 Ptot (mW) 500 300 500 250 250 830 350 300 400 550 500 trr max (ns) 2.6 x 1.6 x 1.1 Cd max (pF) 2.9 x 1.3 x 1.0 IFRM max (mA) 2.9 x 1.3 x 1.0 IFSM max (A) 2.9 x 1.5 x 1.0 IR max (nA) @ VR max 3.5 x 1.5 x 1.5 @ IF (mA) 4.25 x 1.85 x 0.56 VF max (V) trr max (ns) @ VR (V) IR max (nA) VF max (V) VR max (V) @ IF (mA) 100 Size (mm) VR max (V) M3D176 M3D088 1 60 1 200 100 9 600 2.5 6 M3D088 Size (mm) 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 Ptot (mW) 250 250 BAS56 bra037 BAV20 50 SOT143B Package Package 150 Diodes Switching diodes bra036 BAS29 bra048 150 BAV21 50 BAV103 BAS21H BAS321 bra036 90 1 200 100 10 600 35 50 BAS31 bra041 BAS21 BAS21W BAS35 bra048 bra143 BAV23 bra037 Low leakage current switching diodes ≥ 200 1 100 100 200 BAV23A 50 BAS21AW bra143 SOD80C (MiniMelf) BAV23C SOD68 (DO-34) SOT23 SOD123F SOT323 (SC-70) SOD323 (SC-76) SOT416 (SC-75) SOD523 (SC-79) Package trr max (μs) IR max (nA) @ VR max @ IF (mA) VF max (V) BAS21SW bra041 M3D050 BAV23S VR max (V) bra046 M3D088 Size (mm) 3.5 x 1.5 x 1.5 3.04 x 1.6 x 0.55 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.6 x 0.8 x 0.77 1.2 x 0.8 x 0.6 Ptot (mW) 300 500 250 830 250 400 170 500 BAS21VD bra038 BAS116H BAS416 BAS716 bra036 BAS21J BAS521 bra036 BAS116 BAS101 BAS116T bra048 bra048 300 1.1 100 150 250 BAS101S 50 75 bra041 1 10 5 3 BAV199 BAV199W bra041 BAW101 bra037 BAW156 BAW101S bra143 BAV170 bra046 125 1 100 1 1.5 typ BAS45AL BAS45A bra036 18 19 Power diodes 100 150 200 300 400 500 600 800 types in bold represent new products SOD113 (2-pin SOT186A) SOD59 (TO220AC) trr (typ) @ 25C (ns) @ IF (A) VF (typ) @ 150C (V) IF(AV) (A) VRRM (V) Ultrafast recovery power diodes SOT78 (TO220AB) SOT186A (isolated TO220AB) SOT223 SOT226 (I2PAK) SOT404 (D2PAK) SOT428 (DPAK) 8 0.8 8 20 2 x 10 0.72 8 20 2 x 0.75 0.5 0.5 10 8 0.8 8 20 2 x 10 0.72 8 20 2 x 15 0.78 15 20 8 0.8 8 20 2x5 0.8 5 15 14 0.83 14 20 2x8 0.84 8 20 BYQ30E-200 2 x 10 0.72 8 20 BYV32E-200 BYV32G-200 BYV32EB-200 2 x 15 0.78 15 20 BYV42E-200 BYV42G-200 BYV42EB-200 2x5 0.95 5 50 BYT28-300 9 0.9 8 50 2 x 10 0.87 10 50 9 0.9 8 50 2x5 0.95 5 50 15 0.9 15 50 2 x 10 0.87 10 50 2 x 15 0.95 15 50 5 0.97 5 50 BYW29E-100 BYV32E-100 BYV40E-150 BYW29E-150 BYV32E-150 BYV42E-150 BYW29E-200 BYW29EX-200 BYW29ED-200 BYQ28E-200 BYV34-400 BYV29-500 BYV29X-500 BYV29B-500 BYT28-500 BYT79-500 BYV34-500 BYV44-500 BYV25X-600 BYV25G-600 1.07 8 60 BYR29-600 BYR29X-600 0.97 8 50 BYV29-600 BYV29X-600 15 1 15 50 BYT79-600 BYT79X-600 2 x 10 0.92 10 50 5 1.1 5 17.5 BYV25FX-600 BYV25F-600 BYV29FX-600 BYV29F-600 1.25 8 17.5 1.3 10 20 8 1.07 8 60 Protection and signal conditioning BYV29-400 8 9 BYQ28ED-200 BYV79E-200 9 2 x 10 BYQ28X-200 BYV29G-600 BYV34-600 BYV410-600 BYR29-800 BYV34X-600 BYV25D-600 BYV29B-600 BYV34G-600 BYV25FB-600 BYV25FD-600 BYV29FB-600 BYV29FD-600 BYV410X-600 BYR29X-800 Standard ESD protection devices 22 Low capacitance ESD protection devices 24 ESD protection for very high speed interfaces (< 2 pF) 28 Application specific ESD and ESD/EMI solutions 32 Audio interfaces Video interfaces Multichannel EMI filters, ESD protection for LCD and camera SD-, SIM-card and MMC Battery and charger protection USB, SATA, LAN Automotive LIN/CAN/FlexRay 32 32 36 42 42 43 47 TVS diodes 20 VF (typ) @ 150C (V) @ IF (A) trr (typ) @ 25C (ns) 600 types in bold represent new products IF(AV) (A) VRRM (V) Hyperfast power diodes 5 1.4 5 19 BYC5-600 BYC5X-600 BYC5B-600 8 1.4 8 19 BYC8-600 BYC8X-600 BYC8B-600 8 1.4 8 19 BYC8D-600 BYC8DX-600 8 2 8 12.5 SOD59 (TO220AC) SOD113 (2-pin SOT186A) SOT78 (TO220AB) TVS diodes, 24 W / 40 W TVS diodes, 400 W TVS diodes, 600 W 48 48 48 49 SOT404 (D2PAK) BYC58X-600 10 1.4 10 19 2x5 1.4 5 19 BYC10-600 BYC10X-600 15 1.4 15 19 BYC15-600 BYC15X-600 20 1.4 20 19 BYC20-600 BYC20X-600 BYC10B-600 BYC10-600CT 21 Standard ESD protection devices 32 70 150 30 0.05 PESD15VS1UL 23 50 150 23 0.05 PESD24VS1UL 5 152 200 150 30 1 PESD5V0S1ULD 12 38 75 150 30 0.05 PESD12VS1ULD 15 32 70 150 30 0.05 PESD15VS1ULD 24 23 50 150 23 0.05 PESD24VS1ULD 3.3 207 300 330 30 2 PESD3V3S1UB 5 152 200 260 30 1 PESD5V0S1UB SOD882D 1.0 x 0.6 x 0.37 2 1 SOD523 (SC-79) [2] 275 150 23 3 PESD3V3S2UQ SOT663 150 215 150 30 0.3 PESD5V0S2UQ 12 38 100 150 30 0.03 PESD12VS2UQ 15 32 70 150 30 0.05 PESD15VS2UQ PESD24VS2UQ 24 23 50 150 23 0.05 3.3 207 300 330 30 2 PESD3V3S2UT 5.2 152 200 260 30 1 PESD5V2S2UT 12 38 75 180 30 1 PESD12VS2UT 15 32 70 160 30 1 PESD15VS2UT 24 23 50 160 23 1 PESD24VS2UT 36 17 35 160 30 1 (@ 30 V) PESD36VS2UT 3.3 207 300 330 30 2 PESD3V3S2UAT 1.6 x 1.2 x 0.55 SOT23 2.9 x 1.3 x 1.0 12 38 75 180 30 0.05 PESD12VS1UB 5 152 200 260 30 1 15 32 70 160 30 0.05 PESD15VS1UB 12 38 75 180 30 0.05 24 23 50 160 23 0.05 PESD24VS1UB 15 32 70 160 30 0.05 PESD5V0S1UA 24 23 50 160 23 0.05 PESD24VS2UAT 5.5 45 60 - 15 0.1 IP4342CX5/LF CSP5, staggered compressed 1.06 x 0.76 x 0.61 5.5 30 40 - 15 0.1 IP4042CX5/LF CSP5, staggered compressed 1.28 x 0.91 x 0.65 3.3 110 300 110 30 1 (@ 3 V) 1.2 x 0.8 x 0.6 Protection and signal conditioning Size (mm) PPP 15 24 1.0 x 0.6 x 0.5 Package PESD12VS1UL Type 0.05 Configuration 30 IR max (µA) @ VRWM 150 ESD rating 75 max (W) 38 200 5 [1] 12 types in bold represent new products 3.3 PPP SOD882 PESD5V0S1UL Cline max (pF) PESD3V3S1UL 1 Cline typ (pF) 2 30 VRWM (V) 30 150 Bidirectional 150 200 Unidirectional 300 152 Size (mm) Package 207 5 [1] Type Configuration ESD rating [2] max (W) Cline max (pF) Cline typ (pF) Standard ESD protection devices Number of protected lines 3.3 VRWM (V) Bidirectional Unidirectional Number of protected lines types in bold represent new products IR max (µA) @ VRWM max (kV) Standard ESD protection devices max (kV) Standard ESD protection devices PESD5V0S2UAT 1 PESD12VS2UAT 3 2 PESD15VS2UAT bra004 1 0 5 480 530 890 30 4 12 160 180 600 30 0.1 24 23 50 160 23 0.05 1 2 mse209 SOD323 (SC-76) PESD12VS1UA 1.7 x 1.25 x 0.95 - PESD24VS1UA 5 480 530 890 30 4 PESD5V0S1UJ 12 160 180 600 30 0.1 PESD12VS1UJ 2.5 229 300 260 30 6 PESD5Z2.5 3.3 172 200 260 30 0.05 5 89 150 180 30 6 78 150 180 30 7 69 150 180 12 35 75 200 SOD323F (SC-90) 1.7 x 1.25 x 0.7 5 68 75 150 62 70 35 45 0.1 (@ 4.3 V) PESD5Z3.3 3 107 125 - 8 1 BZA956A 0.05 PESD5Z5.0 4 90 105 - 8 0.5 BZA962A 0.01 PESD5Z6.0 4.3 78 90 - 8 0.1 BZA968A 30 0.01 PESD5Z7.0 3 200 240 - 8 2 BZA856A 30 0.01 PESD5Z12 3 107 125 - 8 1 BZA856AL 4 165 200 - 8 0.7 BZA862A 1 SOD523 (SC-79) 30 1.2 x 0.8 x 0.6 4 3 PESD9X7.0L 0.1 35 45 130 30 PESD5V0S1BL PESD5V0S1BLD 0.1 1.0 x 0.6 x 0.37 SOD523 (SC-79) 0 1 5 35 45 130 30 0.1 PESD5V0S1BB 1.2 x 0.8 x 0.6 mse211 5 SOD323 (SC-76) 5 35 45 130 30 0.1 PESD5V0S1BA PESD5V0S4UF 006aaa156 PESD9X5.0L 1 SOT886 (XSON6) 1.45 x 1.0 x 0.5 30 SOD882D 5 4 110 30 130 3 PESD3V3S4UF 220 1.0 x 0.6 x 0.5 5 5 85 30 150 6 2 5 SOD882 7 1 4 1.7 x 1.25 x 0.95 4 90 105 - 8 0.5 BZA862AL 4.3 145 180 - 8 0.2 BZA868A 4.3 78 90 - 8 0.1 BZA868AL 15 37 50 - 8 0.1 BZA820A 3 200 240 - 8 2 BZA456A 4 165 200 - 15 0.7 BZA462A 14 37 48 - 8 0.075 15 37 48 - 8 0.1 1 6 3.3 215 300 200 30 0.8 2 5 3 4 5 165 220 200 30 0.2 12 73 100 200 30 0.015 15 60 90 200 30 0.015 SOD962 4 1.6 x 1.2 x 0.55 SOT353 (SC-88A) 2.0 x 1.25 x 0.95 BZA418A BZA420A PESD3V3S4UD PESD5V0S4UD PESD12VS4UD mse214 SOT457 (SC-74) PESD15VS4UD 24 40 70 200 23 0.015 PESD24VS4UD 3.3 215 300 200 30 0.8 PESD3V3S5UD 5 165 220 200 30 0.2 PESD5V0S5UD 12 73 100 200 30 0.015 PESD12VS5UD 15 60 90 200 30 0.015 PESD15VS5UD 24 45 70 200 23 0.015 PESD24VS5UD 5 45 75 - 15 0.1 2.9 x 1.5 x 1.0 6 1 0 SOT665 2 BZA408B 5 4 3 mse216 5.5 35 45 100 30 0.1 PESD5V0S1BSF 0.6 x 0.3 x 0.3 20 18 17 5.2 100 120 - 8 19 18 17 16 15 14 13 12 BZA100 1 2 3 4 5 6 7 8 9 22 8/20 µs surge pulse acc. to IEC 61000-4-5 [2] acc. to IEC 61000-4-2 (contact discharge) [1] 8/20 µs surge pulse acc. to IEC 61000-4-5 [2] 12.8 x 7.5 x 2.65 10 mse208 [1] SOT163 (SO20) 11 2 M3D184 acc. to IEC 61000-4-2 (contact discharge) 23 Low capacitance ESD protection devices 42 26 0.1 PESD5V0L1UL 5 25 30 42 26 0.1 PESD5V0L1ULD 3.3 34 40 45 30 0.3 PESD3V3L1UB - 10 0.1 PESD5V0U1BL 1.0 x 0.6 x 0.37 5 2.9 3.5 - 10 0.1 PESD5V0U1BLD 1.2 x 0.8 x 0.6 5 2.9 3.5 - 10 0.1 PESD5V0U1BB 1.7 x 1.25 x 0.95 5 2.9 3.5 - 10 0.1 PESD5V0U1BA 3.3 22 28 30 15 0.3 Type [2] [1] SOD882 SOD882D SOD882D 0 1 0 5 25 30 42 26 0.1 3.3 34 40 45 30 0.3 1 2 PESD3V3L1UA 1 SOD523 (SC-79) 30 42 26 0.1 PESD5V0L1UA 3.3 2.6 3.1 - 9 0.1 (@ 3 V) PESD3V3U1UL - 9 1.2 x 0.8 x 0.6 SOD323 (SC-76) SOD882 1.0 x 0.6 x 0.5 2.6 SOD523 (SC-79) mse211 SOD323 (SC-76) mse209 25 2 1.0 x 0.6 x 0.37 PESD5V0L1UB 5 5 1.0 x 0.6 x 0.5 Protection and signal conditioning 3.5 Size (mm) 2.9 Package 5 Configuration 1.0 x 0.6 x 0.5 max (W) IR max (µA) @ VRWM 30 ESD rating 25 PPP 5 Cline max (pF) SOD882 Cline typ (pF) [2] [1] PESD3V3L1UL types in bold represent new products VRWM (V) 0.3 Bidirectional IR max (µA) @ VRWM 30 Unidirectional ESD rating 45 Size (mm) PPP 40 Package Cline max (pF) 34 Low capacitance ESD protection devices Number of protected lines Type Cline typ (pF) 3.3 max (W) VRWM (V) Bidirectional Unidirectional Number of protected lines types in bold represent new products Configuration max (kV) Low capacitance ESD protection devices max (kV) Low capacitance ESD protection devices 0.1 PESD5V0U1UL 5 16 19 30 0.025 15 PESD3V3L2UM 1 1.7 x 1.25 x 0.95 SOT883 (SC-101) 1.0 x 0.6 x 0.5 3 2 PESD5V0L2UM brb051 BOTTOM VIEW 3.3 2.6 3.1 - 9 0.1 (@ 3 V) PESD3V3U1UB 2 SOD523 (SC-79) 1 5 38 46 70 30 0.09 (@ 4 V) PESD5V0L2UU 6 34 40 60 30 0.018 (@ 4.3 V) PESD6V0L2UU 3.3 101 - 350 30 2 PESD3V3L2BT SOT323 (SC-70) 1.2 x 0.8 x 0.6 2.6 9 0.1 - 9 0.1 (@ 3 V) PESD3V3U1UA - 9 0.1 PESD5V0U1UA 30 2 PESD3V3L1BA 5 2 - 3.3 2.6 3.1 5 2 2.6 3.3 101 - 500 5 75 - 500 30 1 PESD5V0L1BA 12 19 - 200 30 0.05 PESD12VL1BA 15 16 - 200 30 2.0 x 1.25 x 0.95 PESD5V0U1UB 0.05 SOD323 (SC-76) 1.7 x 1.25 x 0.95 PESD15VL1BA 24 11 - 200 23 0.05 PESD24VL1BA 5.5 12 15.4 35 30 0.1 PESD5V0L1BSF SOD962 0 2 5 75 - 350 30 1 PESD5V0L2BT 12 19 - 200 30 0.05 PESD12VL2BT 15 16 - 200 30 0.05 24 11 - 200 23 0.05 5 35 45 130 30 0.1 5 2.9 3.5 - 10 0.1 0.6 x 0.3 x 0.3 5 11 13 45 30 0.01 PESD5V0V1BL 3 2.9 3.5 - 10 SOT23 PESD15VL2BT 2.9 x 1.3 x 1.0 PESD24VL2BT 2 PESD5V0S2BT mse213 PESD5V0U2BT SOT883 (SC-101) 1 3 0.1 SOD882 5 1 PESD5V0U2BM 1.0 x 0.6 x 0.5 2 1.0 x 0.6 x 0.5 brb178 BOTTOM VIEW CSP4 SOD882D 0 1 5 11 13 45 30 PESD5V0V1BLD 0.01 15 1.0 x 0.6 x 0.37 13 15 - 15 0.1 - IP4303CX4/P A1 A2 B1 B2 0.76 x 0.76 x 0.40 mse211 SOD523 (SC-79) 5 11 13 45 30 0.01 PESD5V0V1BB 5 11 13 45 30 0.01 PESD5V0V1BA [1] 1.2 x 0.8 x 0.6 8/20 µs surge pulse acc. to IEC 61000-4-5 [2] acc. to IEC 61000-4-2 (contact discharge) 1.7 x 1.25 x 0.95 SOD962 5.5 15 [1] 24 3.5 8 4.5 10 8/20 µs surge pulse acc. to IEC 61000-4-5 8 15 - 15 [2] 0.1 0.1 PESD5V0V1BSF IP4302CX2/A 0.6 x 0.3 x 0.3 CSP2 0.7 x 0.52 x 0.40 In the Spotlight SOD323 (SC-76) New innovative ultra-small package SOD882D Ultra-low package height of only 0.37 mm typ. Tin plated solderable side pads Fully compatible with standard 0402 inch / 1006 mm packages AEC-Q101 qualified Portfolio of 10 ESD diodes covering all applications and segments acc. to IEC 61000-4-2 (contact discharge) 25 Low capacitance ESD protection devices SOT886 (XSON6) 3 0 5.5 3 4 - 15 0.1 IP4059CX5/LF - CSP5, staggered compressed 1.34 x 0.96 x 0.65 5 2.9 3.5 - 10 0.1 1 6 2 5 3 4 Protection and signal conditioning Size (mm) Package Type Configuration ESD rating [2] max (W) [1] PPP Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Size (mm) Package Type IR max (µA) @ VRWM Low capacitance ESD protection devices Number of protected lines Configuration ESD rating [2] max (W) [1] PPP Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines types in bold represent new products IR max (µA) @ VRWM max (kV) Low capacitance ESD protection devices max (kV) Low capacitance ESD protection devices 1.45 x 1.0 x 0.5 PESD5V0U4BF brb179 3.3 5 22 16 28 19 30 20 30 20 0.3 0.025 1 6 2 5 3 4 006aaa156 PESD3V3L4UF 0 SOT886 (XSON6) 4 SOT665 5 1 1.45 x 1.0 x 0.5 5 PESD5V0L4UF 2.9 3.5 - 10 0.1 2 PESD5V0U4BW 3 1.6 x 1.2 x 0.55 4 brb155 3.3 22 28 30 20 0.3 PESD3V3L4UW SOT665 1.6 x 1.2 x 0.55 5 3.3 16 22 19 28 30 20 30 20 0.025 3.3 5 9 4 16 13 12 6.5 19 17 15 10 30 20 25 10 25 15 28 8 5 15 12 18 15 16 12 0.3 PESD3V3L4UG 0.025 16 12 PESD3V3V4UK 0.3 1 6 2 5 3 4 15 2 PESD3V3L5UK 5 18.5 22 30 20 0.5 PESD5V0L5UK SOT353 (SC-88A) SOT891 (XSON6) 1 6 2 5 3 4 3.3 22 28 25 20 0.3 5 16 19 25 20 0.025 PESD5V0L5UF 3.3 22 28 25 20 0.3 PESD3V3L5UV 5 16 19 25 20 0.025 PESD5V0L5UV 3.3 22 28 25 20 0.3 PESD3V3L5UY 006aaa159 PESD3V3L5UF SOT886 (XSON6) 1.45 x 1.0 x 0.5 SOT891 (XSON6) 5 PESD5V0V4UK 006aab474 0.1 0.025 28 PESD5V0L4UG 1 0.3 24 1.0 x 1.0 x 0.5 4 1.0 x 1.0 x 0.5 SOT666 PESD9V0V4UK 1.6 x 1.2 x 0.55 3 3.3 20 PESD5V0L4UW 2.0 x 1.25 x 0.95 5 3.3 1 6 2 5 3 4 006aaa156 PESD3V3V4UF SOT886 (XSON6) 1.45 x 1.0 x 0.5 PESD5V0V4UF SOT363 (SC-88) 2.0 x 1.25 x 0.95 3.3 15 18 16 12 0.3 PESD3V3V4UW SOT665 5 16 19 25 20 0.025 PESD5V0L5UY 1.6 x 1.2 x 0.55 5 12 15 16 12 0.025 PESD5V0V4UW 3.3 15 18 16 12 0.3 PESD3V3V4UG SOT886 (XSON6) 1 5 SOT353 (SC-88A) 12 15 16 12 0.025 18 20 - 15 0 18 20 - 15 0.1 0.1 10 0.1 2 5 4 3 PESD5V0U5BF IP4142CX5/LF - A1 A3 IP4343CX5/LF 1.45 x 1.0 x 0.5 5 SOT666 5 ball CSP, staggered compressed 5 ball CSP 2.9 3.5 - 10 0.1 1 6 2 5 3 4 PESD5V0U5BV 1.6 x 1.2 x 0.55 brb133 1.28 x 0.91 x 0.65 6 5.5 - PESD5V0V4UG 5 5.5 3.5 brb180 2.0 x 1.25 x 0.95 5 2.9 6 5 5 16 19 35 20 0.025 PESD5V0L6US SOT96 (SO8) 1.06 x 0.76 x 0.61 4.9 x 3.9 x 1.75 0 4 M3D315 B2 5.5 18 20 - 15 0.1 C1 C3 bra986 IP4043CX5/LF 5 ball CSP 0 1.12 x 1.12 x 0.65 7 5 8 10 35 10 0.025 1 8 2 7 3 6 PESD5V0L7BS 5 4 mse219 [1] 26 8/20 µs surge pulse acc. to IEC 61000-4-5 [2] acc. to IEC 61000-4-2 (contact discharge) [1] 8/20 µs surge pulse acc. to IEC 61000-4-5 [2] acc. to IEC 61000-4-2 (contact discharge) 27 ESD protection for very high-speed interfaces (< 2 pF) 1.55 PESD5V0X1ULD 15 ESD protection for very high-speed interfaces (< 2 pF) Size (mm) Package Type [1] ESD rating Cline max (pF) 1.75 types in bold represent new products SOD882D Ultra low clamping ESD protection diodes in SOD523 Protection and signal conditioning 5 Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines Configuration max (kV) ESD protection for very high-speed interfaces (< 2 pF) In the Spotlight ESD protection for very high-speed interfaces (< 2 pF) Ultra-low clamping voltage of VCL= 10 V Ultra-low capacitance of Cd= 0.95 / 1.8 pF (high robustness version) Ultra-low dynamical resistance rdyn= 0.25 / 0.15 Ω IEC 61000-4-2; level 4 (ESD) AEC-Q101 qualified 1.0 x 0.6 x 0.37 5 1.55 1.75 15 types in bold represent new products 1.2 x 0.8 x 0.6 2 Number of protected lines PESD5V0X1UAB mse209 1 0 16 0.83 0.98 8 PESD16VX1UL 1 1.5 1.0 x 0.6 x 0.5 SOT23 3 5.5 8 2 2.9 x 1.3 x 1.0 006aab111 0.6 0.75 30 3 1 PRTR5V0U1T 1 80 Unidirectional SOD882 5.5 2 - 15 5 6 R NUP1301 3 SOT457 (SC-74) 4 IP4234CZ6 R 2 SOT886 (XSON6) SOT323 1 80 0.6 0.75 2 006aaa763 30 NUP1301U 2.0 x 1.25 x 0.95 2 0 5.5 0.7 - 2.9 x 1.5 x 1.0 001aaj950 2 1 Size (mm) 1 SOD523 (SC-79) Package PESD5V0X1UB Type 8 Configuration 1.15 max (kV) 0.95 [1] 5 ESD rating PESD5V0X1UALD Cline max (pF) 8 Cline typ (pF) 1.15 VRWM (V) 0.95 Bidirectional 5 8 IP4282CZ6 1.45 x 1.0 x 0.5 3, 4 001aaj776 0 1 5.5 0.4 0.55 10 PESD5V0F1BL 16 0.5 0.65 8 PESD16VF1BL 3.3 1.3 1.6 9 PESD3V3X1BL 5 0.9 1.3 9 PESD5V0X1BL 0.25 0.3 1.0 x 0.6 x 0.5 1.3 - 15 IP4359CX4/LF CSP4 PESD5V0F1BSF 28 5.5 SOD962 mse211 5.5 SOD882 0.6 x 0.3 x 0.3 3 2 5.5 1.4 1.5 15 - IP4356CX4 5.5 1.4 1.5 15 - IP4319CX10 A1 A2 B1 B2 0.76 x 0.76 x 0.61 SOT663 5 0.9 1.3 9 PESD5V0X1BQ 1.6 x 1.2 x 0.55 1 3 1 SOT23 2 5 0.9 1.3 9 001aaa490 PESD5V0X1BT 2.9 x 1.3 x 1.0 5.5 5.5 1 1.5 8 PRTR5V0U2X 1 - 2 1.8 - 12 1.5 8 PRTR5V0U2K I/O1 1 1 1.5 8 2 3 IP4220CZ6 6 5 4 1 2 3 SOT886 (XSON6) GND 2 5 VBUS I/O2 3 4 I/O2 5.5 1 - 8 IP4221CZ6-S PRTR5V0U2D 5.5 1 - 8 IP4221CZ6-XS 1.5 8 SOT363 (SC-88) PRTR5V0U2F 5.5 28 acc. to IEC 61000-4-2 (contact discharge) 1 1.45 x 1.0 x 0.5 - 8 1 6 2 5 3 4 IP4233CZ6 2.0 x 1.25 x 0.95 001aaj811 [1] [1] 1.0 x 1.0 x 0.5 2.9 x 1.5 x 1.0 SOT886 (XSON6) 1 1.45 x 1.0 x 0.5 SOT891 (XSON6) brb182 5.5 2.9 x 1.5 x 1.0 001aag273 SOT457 (SC-74) 6 I/O1 0 1.0 x 1.0 x 0.5 0 5.5 1 SOT457 (SC-74) PRTR5V0U2AX 4 1 4 1.56 x 1.05 x 0.61 001aac379 SOT891 (XSON6) 5.5 5 8 SOT143B 2.9 x 1.3 x 1.0 5.5 6 CSP10, staggered compressed acc. to IEC 61000-4-2 (contact discharge) 29 ESD protection for very high-speed interfaces (< 2 pF) 5.5 1 - 8 PRTR5V0U4D 2 1 4 2.9 x 1.5 x 1.0 0 5.5 0.5 - 8 4 5 Size (mm) Package IP4292CZ10-TBR 3, 8 6 SOT1176 (XSON10) 5 1.0 x 2.5 x 0.5 Protection and signal conditioning SOT457 (SC-74) types in bold represent new products Type Configuration Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Size (mm) Package Type Configuration [1] IR max (µA) @ VRWM max (kV) ESD protection for very high-speed interfaces (< 2 pF) Number of protected lines ESD rating Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines types in bold represent new products [1] max (kV) ESD protection for very high-speed interfaces (< 2 pF) ESD rating ESD protection for very high-speed interfaces (< 2 pF) 001aai619 4 CSP SOT363 (SC-88) 1 5.5 1 - 2 5 3 001aag273 8 PRTR5V0U4Y 0 5.5 1.3 - 15 IP4358CX6 - 2.0 x 1.25 x 0.95 A1 A2 B1 B2 C1 C2 0.76 x 1.16 x 0.61 CSP 1 2 4 SOT1178 (XSON9) 5 5.5 5.5 0.8 - IP4285CZ9-TBB 12 3, 8 9 5.5 0.7 - 8 15 IP4309CX9 - 8 0 SOT552 (TSSOP10) 6 IP4280CZ10 3 - 1.0 x 2.1 x 0.5 001aai619 8 1 1.3 5.5 3.0 x 3.0 x 1.1 1 - 8 - 1 10 2 9 3 8 4 7 sym122 - ML_1A 8 11 1.0 x 2.5 x 0.5 IP4283CZ10-TBA 0 5.5 0.7 - 8 - ML_0B BIAS_CAP BIAS_CAP 5.5 0.6 - 8 5.5 0.6 - 2 4 SOT552 (TSSOP10) 5 8 IP4283CZ10-TT 3, 8 C2 C3 1.16 x 1.16 x 0.61 3.0 x 3.0 x 1.1 ML_2A SOT510 (TSSOP38) ML_3A BIAS_CAP ML_2B ML_3B IP4790CZ38 9.7 x 4.4 x 1.1 BIAS_CAP AUX_B GND GND 001aai165 acc. to IEC 61000-4-2 (contact discharge) 1.0 x 2.5 x 0.5 IP4283CZ10-TBR 1 [1] GND ML_1B AUX_A GND SOT1176 (XSON10) 0 C1 PRTR5V0U8S VBIAS HOT_PLUG 4 B3 001aah386 ML_0A 0.6 A3 B2 SOT552 (TSSOP10) SOT1165 (XSON10) 5.5 A2 B1 6 5 4 A1 3.0 x 3.0 x 1.1 001aai619 NXP Wafer-Level Chip Scale Package (WL-CSP)  Smallest possible solution for ESD and EMI circuits, saving maximum of space  Lowest parasitic inductance to GND contact, ensures best performance  High mechanical robustness bra263 SOT1176 (XSON10) 5.5 0.5 - IP4284CZ10-TBR 8 1.0 x 2.5 x 0.5 SOT552 (TSSOP10) 5.5 0.5 - IP4284CZ10-TT 8 3.0 x 3.0 x 1.1 SOT886 (XSON6) 5.5 0.6 - IP4286CZ6-TBF 8 6 5 1.45 x 1.0 x 0.5 4 SOT363 (SC-88) 1 5.5 [1] 30 0.6 - 8 2 3 001aaj836 IP4286CZ6-TTY 2.0 x 1.25 x 0.95 acc. to IEC 61000-4-2 (contact discharge) 31 Application-specific ESD and ESD/EMI solutions Audio interfaces Number Baseband of interface protected lines types in bold represent new products Line small-signal equivalents Rline Cline (pF) 0.9 Ω 290 Digital interface clock speed (MHz) Remark Type Package Size (mm) - Low-ohmic speaker (< ~8 Ω) IP4047CX6/LF 6 ball CSP 1.56 x 1.01 x 0.65 5 ball CSP 0.91 x 1.28 x 0.65 10 Ω 200 - Low-ohmic speaker (> ~8 Ω) IP4048CX5/LF 110 - Single-ended or differential microphone IP4049CX5/LF 470 Ω 35 - Single-ended or differential microphone IP4055CX6/LF 470 Ω 20 - Single-ended or differential microphone IP4355CX6/LF 50 Ω / 2.2 kΩ 2000 - Single-ended to quasi-differential microphone channel with integrated biasing network IP5002CX8/LF 8 ball CSP 1.67 x 1.67 x 0.65 0.25 Ω, 3 nH - - Inductive, low-ohmic differntial channel LC filter IP3047CX6 6 ball CSP 1.60 x 1.15 x 0.65 0.25 Ω, 3 nH - - Inductive, low-ohmic differntial channel LC filter IP3048CX5 5 ball CSP 1.51 x 1.15 x 0.65 - Fully integrated audio interface protection for differential microphone and differential speaker, including EMI filtering and pull up resistors IP4027CX20/LF 20 ball CSP 1.91 x 2.52 x 0.65 Audio 6 Baseband interface 68 Ω 2 40 Ω / 1450 Ω / 10 Ω 50 / 20 / 200 Video interfaces Number of protected lines types in bold represent new products Cline (pF) Remark Type 2 0.7 ESD protection for ultra high-speed interfaces IP4282CZ6 SOT552 (TSSOP10) 6 ball CSP 1.56 x 1.03 x 0.65 0.7 1.16 x 0.76 x 0.65 ESD protection for ultra high-speed interfaces IP4280CZ10 3.0 x 3.0 x 1.1 SOT1165 (XSON10) 0.6 0.6 types in bold represent new products Cline (pF) 1.45 x 1.0 x 0.5 ESD protection for ultra high-speed interfaces IP4283CZ10-TBA 1.0 x 2.5 x 0.5 SOT1176 (XSON10) Video interfaces Number of protected lines Size (mm) SOT886 (XSON6) ESD protection acc. to IEC 61000-4-2 (level 4) Baseband interface Package Protection and signal conditioning Application-specific ESD and ESD/EMI solutions Remark Type Package ESD protection for ultra high-speed interfaces IP4283CZ10-TBR Size (mm) 1.0 x 2.5 x 0.5 SOT552 (TSSOP10) SOT1176 (XSON10) 0.6 HDMI 0.6 ESD protection for ultra high-speed interfaces IP4283CZ10-TBR ESD protection for ultra high-speed interfaces IP4283CZ10-TT 4 SOT886 (XSON6) SOT552 (TSSOP10) 0.6 ESD protection for ultra high-speed interfaces 3.0 x 3.0 x 1.1 1.0 x 2.5 x 0.5 IP4283CZ10-TT 3.0 x 3.0 x 1.1 0.6 ESD protection for ultra high-speed interfaces IP4286CZ6-TBF 1.45 x 1.0 x 0.5 SOT1176 (XSON10) SOT363 (SC-88) 0.5 ESD protection for ultra high-speed interfaces IP4284CZ10-TBR 1.0 x 2.5 x 0.5 0.6 ESD protection for ultra high-speed interfaces IP4286CZ6-TTY 2.0 x 1.25 x 0.95 SOT552 (TSSOP10) 0.5 ESD protection for ultra high-speed interfaces IP4284CZ10-TT 3.0 x 3.0 x 1.1 SOT1176 (XSON10) 4 0.5 SOT1176 (XSON10) Display port 0.5 ESD protection for ultra high-speed interfaces IP4292CZ10-TBR ESD protection for ultra high-speed interfaces IP4284CZ10-TBR 1.0 x 2.5 x 0.5 1.0 x 2.5 x 0.5 SOT1178 (XSON10) SOT1178 (XSON9) 0.8 ESD protection for ultra high-speed interfaces IP4285CZ9-TBB 1.0 x 2.1 x 0.5 0.8 ESD protection for ultra high-speed interfaces IP4285CZ9-TBB 1.0 x 2.1 x 0.5 SOT886 (XSON6) IP4286CZ6-TBF 0.6 1.45 x 1.0 x 0.5 SOT363 (SC-88) ESD protection for ultra high-speed interfaces IP4286CZ6-TTY 2.0 x 1.25 x 0.95 SOT510 (TSSOP38) 11 0.7 ESD protection for display port IP4790CZ38 9.7 x 4.4 x 1.1 ESD protection acc. to IEC 61000-4-2 (level 4) In the Spotlight ESD protection for ultra high-speed interfaces HDMI: High-speed 4 channel ESD protection – IP4283CZ10-TBR Low capacitance 4 channel ESD protection array: IP4283CZ10-TBR Optimized for high level ESD protection of HDMI ports Straight through routing ➞ best signal integrity 10 pin QFN package with exposed leads (SOT1176) ESD protection acc. to IEC 61000-4-2 (level 4) 32 33 Application-specific ESD and ESD/EMI solutions Video interfaces Baseband interface Number of protected lines types in bold represent new products Buffer Level shifter Cline (pF) Resistor (Ω) Remark Type Package Size (mm) Video interfaces Baseband interface Number of protected lines types in bold represent new products Buffer Level shifter Cline (pF) Resistor (Ω) Remark Type yes yes 5 55 H&V sync buffer, DDC level shifter IP4770CZ16 Package Size (mm) Protection and signal conditioning Application-specific ESD and ESD/EMI solutions SOT552 (TSSOP10) - - 0.5 - ESD protection for ultra high-speed interfaces IP4284CZ10-TT 3.0 x 3.0 x 1.1 SOT519 (SSOP16) 4 SOT1176 (XSON10) - - 0.5 - ESD protection for ultra high-speed interfaces 1.75 k, 100 k HDMI, DDC, CEC, hot plug ESD protection and biasing IP4292CZ10-TBR 1.0 x 2.5 x 0.5 yes yes 5 65 H&V sync buffer, DDC level shifter IP4771CZ16 yes yes 5 10 H&V sync buffer, DDC level shifter IP4772CZ16 yes no 4 10 VGA receivers and transmitters, H&V sync buffer IP4773CZ14 4.9 x 3.9 x 1.73 8 ball CSP - - 10 IP4310CX8/P 5 A1 A2 B1 B2 C1 C2 A3 1.16 x 1.16 x 0.61 C3 SOT1156 yes yes - internal Fully integrated solution for HDMI low-speed signals, buffer and level shifter for DDC, CEC, HP VGA IP4791CZ12 7 2.5 x 2.1 x 0.5 9 ball CSP HDMI 8 - - 1.3 - HDMI, TMDS line ESD protection IP4309CX9 A1 A2 A3 B1 B2 B3 C1 C2 C3 6.2 x 5.3 x 2.0 1.16 x 1.16 x 0.61 yes - 12 yes yes yes yes yes 0.7 0.7 0.7 ESD protection and level shifting for a complete HDMI port IP4776CZ38 - ESD protection, DDC buffering, noise reduction and hot plug application for a complete HDMI source port IP4777CZ38 - ESD protection, DDC buffering, noise reduction and hot plug application for a complete HDMI sink port IP4778CZ38 internal Fully integrated HDMI solution with current limiter, buffer and level shifter for DDC, CEC, HP IP4786CZ32 - SOT337 (SSOP14) no 4 10 VGA receivers and transmitters, H sync buffer IP4774CZ14 SOT402-1 (TSSOP14) SOT510 (TSSOP38) 9.7 x 4.4 x 1.1 no yes 4 1.3 - 2.4 VGA receivers and transmitters, DDC level shifter IP4769CZ14 5.0 x 4.4 x 1.1 ESD protection acc. to IEC 61000-4-2 (level 4) Please find more ESD protection diodes for ultra high-speed interfaces on pages 28 - 31 Transmitter HDMI companion chip IP4786CZ32 SOT617 13 yes yes 100 Ω differential impedance 2 - - 30 10 EMI filter with ESD protection for MIPI or MDDI IP3348CX5 CSP5, staggered 0.76 x 1.06 x 0.61 compressed 4 - - 30 10 EMI filter with ESD protection for MIPI or MDDI IP3348CX10 CSP10, staggered 1.56 x 1.06 x 0.61 compressed 6 - - 30 10 EMI filter with ESD protection for MIPI or MDDI IP3348CX15 CSP15, staggered 2.36 x 1.06 x 0.61 compressed 8 - - 30 10 EMI filter with ESD protection for MIPI or MDDI IP3348CX20 CSP20, staggered 3.16 x 1.06 x 0.61 compressed 5.0 x 5.0 x 1.0 LVDS ESD protection acc. to IEC 61000-4-2 (level 4) 34 35 Application-specific ESD and ESD/EMI solutions Multichannel EMI filters, ESD protection for LCD and camera Number of Baseband protected interface lines 1 LCD display, camera, keypad 2 Line small-signal equivalents Rline (Ω) Cline (pF) Lline (nH) 75 36 - ~50 155 Type Package Size (mm) IP4307CX4/LF 4 ball CSP 0.76 x 0.76 x 0.61 Multichannel EMI filters, ESD protection for LCD and camera Number of Baseband protected interface lines Line small-signal equivalents Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) Type Rline (Ω) Cline (pF) Lline (nH) 20 23 - ~90 264 PEMI2STD/CK 20 19 - ~105 317 PEMI2STD/CG 20 40 - ~50 153 PEMI1QFN/CT 20 36 - ~55 170 PEMI1QFN/CR 20 15 - ~130 397 PEMI2STD/CE 20 32 - ~60 185 PEMI1QFN/CP 45 40 - ~50 145 PEMI2STD/HT 20 28 - ~70 218 PEMI1QFN/CM 45 36 - ~55 161 PEMI2STD/HR 20 23 - ~90 264 PEMI1QFN/CK 45 32 - ~60 175 PEMI2STD/HP 20 19 - ~105 317 PEMI1QFN/CG 45 28 - ~70 206 PEMI2STD/HM 20 15 - ~130 397 PEMI1QFN/CE 45 23 - ~80 249 PEMI2STD/HK 45 40 - ~50 145 PEMI1QFN/HT 45 19 - ~100 300 PEMI2STD/HG 45 36 - ~55 161 PEMI1QFN/HR 45 32 - ~60 175 PEMI1QFN/HP 45 28 - ~70 206 PEMI1QFN/HM 45 23 - ~80 249 PEMI1QFN/HK 45 19 - ~100 300 PEMI1QFN/HG 45 15 - ~125 376 PEMI1QFN/HE 65 40 - ~45 139 PEMI1QFN/LT 65 36 - ~50 155 PEMI1QFN/LR 65 32 - ~55 168 PEMI1QFN/LP 65 28 - ~65 197 PEMI1QFN/LM 65 23 - ~80 239 PEMI1QFN/LK 65 19 - ~95 288 PEMI1QFN/LG 65 15 - ~120 361 PEMI1QFN/LE 100 40 - ~45 131 PEMI1QFN/RT 100 36 - ~50 145 PEMI1QFN/RR 100 32 - ~55 159 PEMI1QFN/RP 100 28 - ~60 187 PEMI1QFN/RM 100 30 - ~65 200 IP4256CZ3-M 100 23 - ~75 227 PEMI1QFN/RK 100 19 - ~90 272 PEMI1QFN/RG 100 15 - ~115 343 PEMI1QFN/RE SOT883 (SC-101) 1.0 x 0.6 x 0.5 LCD display, camera, keypad 2 45 15 - ~125 376 PEMI2STD/HE 65 40 - ~45 139 PEMI2STD/LT 65 36 - ~50 155 PEMI2STD/LR 65 32 - ~55 168 PEMI2STD/LP 65 28 - ~65 197 PEMI2STD/LM 65 23 - ~80 239 PEMI2STD/LK 65 19 - ~95 288 PEMI2STD/LG 65 15 - ~120 361 PEMI2STD/LE 100 40 - ~45 131 PEMI2STD/RT 100 36 - ~50 145 PEMI2STD/RR 100 32 - ~55 159 PEMI2STD/RP 100 30 - ~65 200 IP4256CZ5-W 100 28 - ~60 187 PEMI2STD/RM 100 23 - ~75 227 PEMI2STD/RK 100 19 - ~90 272 PEMI2STD/RG 100 15 - ~115 343 PEMI2STD/RE 200 40 - ~40 119 PEMI2STD/WT 200 36 - ~45 132 PEMI2STD/WR 200 32 - ~50 143 PEMI2STD/WP 200 28 - ~55 169 PEMI2STD/WM 200 23 - ~70 205 PEMI2STD/WK 200 19 - ~80 247 PEMI2STD/WG 200 15 - ~105 311 PEMI2STD/WE 200 40 - ~40 119 PEMI1QFN/WT 200 36 - ~45 132 PEMI1QFN/WR 200 32 - ~50 143 PEMI1QFN/WP 200 28 - ~55 169 PEMI1QFN/WM 20 40 - ~50 153 PEMI2QFN/CT 36 - ~55 170 PEMI2QFN/CR 32 - ~60 185 PEMI2QFN/CP 200 23 - ~70 205 PEMI1QFN/WK 20 200 19 - ~80 247 PEMI1QFN/WG 20 200 15 - ~105 311 PEMI1QFN/WE 20 28 - ~70 218 PEMI2QFN/CM 20 23 - ~90 264 PEMI2QFN/CK 20 19 - ~105 317 PEMI2QFN/CG 20 15 - ~130 397 PEMI2QFN/CE 10 35 15 ~115 350 IP3348CX5 18 65 40 ~60 175 IP3088CX5 0.76 x 1.06 x 0.61 5 ball CSP 0.96 x 1.28 x 0.65 IP3053CX5 100 45 35 ~50 150 20 40 - ~50 153 PEMI2STD/CT 20 36 - ~55 170 PEMI2STD/CR 20 32 - ~60 185 PEMI2STD/CP 20 28 - ~70 218 PEMI2STD/CM ESD protection acc. to IEC 61000-4-2 (level 4) 36 Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) types in bold represent new products SOT665 1.6 x 1.2 x 0.5 45 40 - ~50 145 PEMI2QFN/HT 45 36 - ~55 161 PEMI2QFN/HR 45 32 - ~60 175 PEMI2QFN/HP 45 28 - ~70 206 PEMI2QFN/HM types in bold represent new products Package Size (mm) SOT665 1.6 x 1.2 x 0.5 Protection and signal conditioning Application-specific ESD and ESD/EMI solutions SOT886 (XSON6) 1.45 x 1.0 x 0.5 ESD protection acc. to IEC 61000-4-2 (level 4) 37 Application-specific ESD and ESD/EMI solutions Multichannel EMI filters, ESD protection for LCD and camera Number of Baseband protected interface lines 2 LCD display, camera, keypad Line small-signal equivalents Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) Type types in bold represent new products Package Size (mm) Multichannel EMI filters, ESD protection for LCD and camera Number of Baseband protected interface lines Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) Type Rline (Ω) Cline (pF) Lline (nH) 45 23 - ~80 249 PEMI2QFN/HK 45 19 - ~100 300 PEMI2QFN/HG 65 40 - ~45 139 PEMI4QFN/LT 36 - ~50 155 PEMI4QFN/LR 32 - ~55 168 PEMI4QFN/LP Rline (Ω) Cline (pF) Lline (nH) 45 15 - ~125 376 45 15 - ~125 376 PEMI2QFN/HE 65 40 - ~45 139 PEMI2QFN/LT 65 65 36 - ~50 155 PEMI2QFN/LR 65 28 - ~65 197 PEMI4QFN/LM 23 - ~80 239 PEMI4QFN/LK PEMI4QFN/LG 65 32 - ~55 168 PEMI2QFN/LP 65 65 28 - ~65 197 PEMI2QFN/LM 65 19 - ~95 288 65 23 - ~80 239 PEMI2QFN/LK 65 15 - ~120 361 PEMI4QFN/LE 40 - ~45 131 PEMI4QFN/RT 36 - ~50 145 PEMI4QFN/RR 65 19 - ~95 288 PEMI2QFN/LG 100 65 15 - ~120 361 PEMI2QFN/LE 100 100 40 - ~45 131 PEMI2QFN/RT 100 36 - ~50 145 PEMI2QFN/RR 100 32 - ~55 159 PEMI2QFN/RP 100 30 - ~65 200 IP4256CZ6-F 100 28 - ~60 187 PEMI2QFN/RM 100 23 - ~75 227 PEMI2QFN/RK 100 19 - ~90 272 PEMI2QFN/RG 100 15 - ~115 343 PEMI2QFN/RE 200 40 - ~40 119 PEMI2QFN/WT 200 36 - ~45 132 PEMI2QFN/WR 200 32 - ~50 143 PEMI2QFN/WP 200 28 - ~55 169 PEMI2QFN/WM SOT886 (XSON6) 1.45 x 1.0 x 0.5 100 32 - ~55 159 PEMI4QFN/RP 100 28 - ~60 187 PEMI4QFN/RM 100 23 - ~75 227 PEMI4QFN/RK 100 19 - ~90 272 PEMI4QFN/RG 100 15 - ~115 343 PEMI4QFN/RE 4 LCD display, camera, keypad 200 40 - ~40 119 PEMI4QFN/WT 200 36 - ~45 132 PEMI4QFN/WR 200 32 - ~50 143 PEMI4QFN/WP 200 28 - ~55 169 PEMI4QFN/WM 200 23 - ~70 205 PEMI4QFN/WK 200 19 - ~80 247 PEMI4QFN/WG 200 15 - ~105 311 PEMI4QFN/WE 15 43 12 ~60 175 IP3253CZ8-4-TTL 15 50 18 ~50 145 IP3254CZ8-4-TTL 200 23 - ~70 205 PEMI2QFN/WK 200 19 - ~80 247 PEMI2QFN/WG 200 15 - ~105 311 PEMI2QFN/WE 10 35 15 ~115 350 IP3348CX10 1.56 x 1.06 x 0.61 18 65 40 ~60 175 IP3088CX10 1.96 x 1.28 x 0.65 100 54 - ~30 98 PEMI4CSP/RW 100 45 35 ~20 150 IP3053CX10 1.96 x 1.28 x 0.65 100 41 - ~40 125 PEMI4CSP/RT 1.56 x 1.06 x 0.61 20 40 - ~50 153 PEMI4QFN/CT 20 36 - ~55 170 PEMI4QFN/CR 20 32 - ~60 185 PEMI4QFN/CP 20 28 - ~70 218 PEMI4QFN/CM 20 23 - ~90 264 PEMI4QFN/CK 20 19 - ~105 317 PEMI4QFN/CG 20 15 - ~130 397 PEMI4QFN/CE 45 40 - ~50 145 PEMI4QFN/HT 45 36 - ~55 161 PEMI4QFN/HR 45 32 - ~60 175 PEMI4QFN/HP 45 28 - ~70 206 PEMI4QFN/HM 20 19 - 45 23 - ~80 249 PEMI4QFN/HK 20 15 - 45 19 - ~100 300 PEMI4QFN/HG 45 40 - ~50 10 ball CSP 1.56 x 1.06 x 0.61 ESD protection acc. to IEC 61000-4-2 (level 4) 40 18 - ~100 300 IP4252CZ8-4 -TTL 100 45 - ~40 130 IP4254CZ8-4-TTL 100 15 - ~110 330 IP4251CZ8-4-TTL 1.7 x 1.2 x 0.5 Size (mm) SOT1157 (8 pin QFN) 1.7 x 1.2 x 0.5 SOT1166 (8 pin QFN) 1.7 x 1.35 x 0.5 200 45 - ~35 110 IP4253CZ8-4-TTL 10 35 15 ~115 350 IP3348CX15 2.36 x 1.06 x 0.61 18 65 40 ~60 175 IP3088CX15 2.96 x 1.28 x 0.65 100 60 - ~40 120 IP4053CX15/LF 2.96 x 1.32 x 0.65 100 60 - ~40 120 IP4353CX15/LF 2.38 x 1.05 x 0.61 100 54 - ~30 98 PEMI6CSP/RW 100 45 35 ~20 150 IP3053CX15 2.96 x 1.28 x 0.65 100 41 - ~40 125 PEMI6CSP/RT 2.36 x 1.06 x 0.61 2.91 x 1.28 x 0.65 100 30 - ~70 210 IP4153CX15/LF 20 40 - ~50 153 PEMI6QFN/CT 20 36 - ~55 170 PEMI6QFN/CR 20 32 - ~60 185 PEMI6QFN/CP 20 28 - ~70 218 PEMI6QFN/CM 20 23 - ~90 264 PEMI6QFN/CK ~105 317 PEMI6QFN/CG ~130 397 PEMI6QFN/CE 145 PEMI6QFN/HT 6 SOT1157 (8 pin QFN) Package PEMI4QFN/HE 65 4 38 Line small-signal equivalents types in bold represent new products Protection and signal conditioning Application-specific ESD and ESD/EMI solutions 15 ball CSP 2.36 x 1.06 x 0.61 SOT1158 (12 pin QFN) 2.5 x 1.2 x 0.5 ESD protection acc. to IEC 61000-4-2 (level 4) 39 Application-specific ESD and ESD/EMI solutions Multichannel EMI filters, ESD protection for LCD and camera Number of Baseband protected interface lines Line small-signal equivalents Rline (Ω) LCD display, camera, keypad 7 8 Package Size (mm) Number of Baseband protected interface lines Line small-signal equivalents Rline (Ω) Cline (pF) Lline (nH) Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) Type 45 36 - ~55 161 PEMI6QFN/HR 45 40 - ~50 145 PEMI8QFN/HT 32 - ~60 175 PEMI6QFN/HP 45 36 - ~55 161 PEMI8QFN/HR 45 28 - ~70 206 PEMI6QFN/HM 45 32 - ~60 175 PEMI8QFN/HP 28 - ~70 206 PEMI8QFN/HM 45 23 - ~80 249 PEMI6QFN/HK 45 45 19 - ~100 300 PEMI6QFN/HG 45 23 - ~80 249 PEMI8QFN/HK 45 19 - ~100 300 PEMI8QFN/HG PEMI8QFN/HE 45 15 - ~125 376 PEMI6QFN/HE 65 40 - ~45 139 PEMI6QFN/LT 36 - ~50 155 PEMI6QFN/LR 65 32 - ~55 168 PEMI6QFN/LP 65 28 - ~65 197 PEMI6QFN/LM 65 23 - ~80 239 PEMI6QFN/LK 65 19 - ~95 288 PEMI6QFN/LG 65 15 - ~120 361 PEMI6QFN/LE 100 40 - ~45 131 PEMI6QFN/RT 100 36 - ~50 145 PEMI6QFN/RR 100 32 - ~55 159 PEMI6QFN/RP 100 28 - ~60 187 PEMI6QFN/RM 100 23 - ~75 227 PEMI6QFN/RK 100 19 - ~90 272 PEMI6QFN/RG 100 15 - ~115 343 PEMI6QFN/RE SOT1158 (12 pin QFN) 2.5 x 1.2 x 0.5 8 LCD display, camera, keypad 45 15 - ~125 376 65 40 - ~45 139 PEMI8QFN/LT 65 36 - ~50 155 PEMI8QFN/LR 65 32 - ~55 168 PEMI8QFN/LP PEMI8QFN/LM 65 28 - ~65 197 65 23 - ~80 239 PEMI8QFN/LK 65 19 - ~95 288 PEMI8QFN/LG 65 15 - ~120 361 PEMI8QFN/LE 100 40 - ~45 131 PEMI8QFN/RT 100 36 - ~50 145 PEMI8QFN/RR 100 32 - ~55 159 PEMI8QFN/RP 100 28 - ~60 187 PEMI8QFN/RM 100 23 - ~75 227 PEMI8QFN/RK 100 19 - ~90 272 PEMI8QFN/RG 100 15 - ~115 343 PEMI8QFN/RE 40 - ~40 119 PEMI8QFN/WT PEMI8QFN/WR 200 40 - ~40 119 PEMI6QFN/WT 200 200 36 - ~45 132 PEMI6QFN/WR 200 36 - ~45 132 200 32 - ~50 143 PEMI6QFN/WP 200 32 - ~50 143 PEMI8QFN/WP 200 28 - ~55 169 PEMI8QFN/WM 200 23 - ~70 205 PEMI8QFN/WK 200 19 - ~80 247 PEMI8QFN/WG 200 15 - ~105 311 PEMI8QFN/WE 15 43 12 ~60 175 IP3253CZ16-8-TTL 15 50 18 ~50 145 IP3254CZ16-8-TTL 40 18 - ~100 300 IP4252CZ16-8-TTL 100 45 - ~40 130 IP4254CZ16-8-TTL 200 28 - ~55 169 PEMI6QFN/WM 200 23 - ~70 205 PEMI6QFN/WK 200 19 - ~80 247 PEMI6QFN/WG 200 15 - ~105 311 PEMI6QFN/WE 15 50 18 ~50 145 IP3254CZ12-6-TTL 15 43 12 ~60 175 IP3253CZ12-6-TTL 40 18 - ~100 300 IP4252CZ12-6-TTL 100 45 - ~40 130 IP4254CZ12-6-TTL 100 15 - ~110 330 IP4251CZ12-6-TTL SOT1167 (12 pin QFN) 2.5 x 1.35 x 0.5 100 15 - ~110 330 IP4251CZ16-8-TTL 200 45 - ~35 110 IP4253CZ16-8-TTL 70 25 - ~75 220 IP4338CX24/LF 125 25 60 ~60 180 IP3338CX24/LF 1000 50 - ~7 22 IP4035CX24/LF 200 45 - ~35 110 IP4253CZ12-6-TTL 70 25 - ~75 220 IP4337CX18/LF 125 25 60 ~60 180 IP3337CX18/LF 10 35 15 ~115 350 IP3348CX20 3.16 x 1.06 x 0.61 80 40 - ~30 100 IP4032CX25/LF 18 65 40 ~60 175 IP3088CX20 3.96 x 1.28 x 0.65 200 50 - ~35 105 IP4041CX25/LF 18 ball CSP 1.96 x 1.61 x 0.61 2.06 x 1.66 x 0.61 100 54 - ~30 98 PEMI8CSP/RW 100 50 - ~40 120 IP4088CX20/LF 100 45 35 ~20 150 IP3053CX20 3.96 x 1.28 x 0.65 100 41 - ~40 125 PEMI8CSP/RT 3.16 x 1.06 x 0.61 20 40 - ~50 153 PEMI8QFN/CT 20 36 - ~55 170 PEMI8QFN/CR 20 32 - ~60 185 PEMI8QFN/CP 20 28 - ~70 218 PEMI8QFN/CM 20 23 - ~90 264 PEMI8QFN/CK 20 19 - ~105 317 PEMI8QFN/CG 20 15 - ~130 397 PEMI8QFN/CE ESD protection acc. to IEC 61000-4-2 (level 4) 40 Lline (nH) Type Multichannel EMI filters, ESD protection for LCD and camera 45 65 6 Cline (pF) Digital interface Insertion Loss clock speed S21~ -3 dB (MHz) (MHz) types in bold represent new products 20 ball CSP 3.16 x 1.06 x 0.61 3.91 x 1.28 x 0.65 10 types in bold represent new products Package Size (mm) SOT1159 (16 pin QFN) 3.3 x 1.2 x 0.5 Protection and signal conditioning Application-specific ESD and ESD/EMI solutions SOT1168 (16 pin QFN) 3.3 x 1.35 x 0.5 1.96 x 2.01 x 0.61 24 ball CSP 2.11 x 2.11 x 0.61 2.41 x 2.41 x 0.65 25 ball CSP 2.41 x 2.41 x 0.65 ESD protection acc. to IEC 61000-4-2 (level 4) PEMI-series nomenclature PEMI--x--yyy/zz ESD protection and multichannel EMI filters (1-, 2-, 4-, 6-, and 8-channels) SOT1159 (16 pin QFN) 3.3 x 1.2 x 0.5 x: no. of channels zz: R-, C- or L- value yyy: QFN: Plastic Quad Flat No-leads package CSP: Wafer-level Chip-Scale-Package STD: Standard Leaded Package 41 Application-specific ESD and ESD/EMI solutions SIM card 3 Package Size (mm) 11 ball CSP 1.16 x 1.56 x 0.61 47 Ω / 100 Ω 10 ~20 Integrated low capacitance SIM-card passive filter array & USB ESD protection IP4365CX11 47 Ω / 100 Ω 40 ~12 Integrated SIM-card EMI filter and ESD protection IP4044CX8/LF 47 Ω / 100 Ω 20 ~20 Integrated SIM-card EMI filter and ESD protection IP4064CX8/LF/P 47 Ω / 100 Ω 20 ~20 47 Ω / 100 Ω 10 ~20 47 Ω / 100 Ω 40 ~12 47 Ω / 100 Ω 20 ~20 Smaller size, integrated SIM-card EMI IP4364CX8/LF/P filter and ESD protection Smaller size, low capacitance integrated SIM-card EMI filter and IP4366CX8/P ESD protection Integrated SIM-card EMI filter and IP4264CZ8-40-TTL ESD protection Integrated SIM-card EMI filter and ESD protection IP4264CZ8-20-TTL 1.46 x 1.49 x 0.65 1.41 x 1.41 x 0.65 8 ball CSP 33 Ω / 1.3 kΩ 30 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching IP4056CX8/LF 8 ball CSP 1.27 x 1.83 x 0.65 33 Ω / 1.3 kΩ / 10 kΩ 30 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching IP4057CX10/LF 10 ball CSP 1.56 x 1.91 x 0.65 33 Ω / 1.3 kΩ / 17 kΩ / 15 kΩ 27 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching IP4065CX11/LF 11 ball CSP 1.47 x 1.97 x 0.65 33 Ω / 1.5 kΩ 35 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching IP4058CX8/LF 8 ball CSP 0.91 x 1.91 x 0.65 IP4158CX8/LF 6 ball CSP 0.91 x 1.41 x 0.65 1.16 x 1.16 x 0.61 SOT1166 (8 pin QFN) 1.7 x 1.35 x 0.5 47 Ω / 100 Ω 10 ~20 Integrated SIM-card EMI filter and ESD protection IP4264CZ8-10-TTL - 1 ~240 Quad channel low capacitance ESD protection IP4221CZ6-S ~30 MMC ESD protection, pull-up resistors IP4051CX11/LF 11 ball CSP 1.44 x 1.96 x 0.65 ~50 High-speed MMC ESD protection, pull-up resistors IP4060CX16/LF 16 ball CSP 1.96 x 1.97 x 0.65 Remark Type Package Size (mm) Protection and signal conditioning Type Digital interface clock speed (MHz) 3+2 Remark types in bold represent new products Cline (pF) Number of Line small-signal equivalents Digital interface Baseband protected clock speed interface Cline (pF) Rline lines (MHz) USB, SATA, LAN Rline types in bold represent new products Number of protected lines SD-, SIM-card and MMC Baseband interface Application-specific ESD and ESD/EMI solutions SOT886 (XSON6) 47 Ω / 13 kΩ / 56 kΩ 25 4 50 Ω / 75 kΩ / 7 kΩ 18 1.45 x 1.0 x 0.5 2 SOT1167 (12 pin QFN) 6 40 Ω 12 >52 (Mini) SD card/trans flash ESD protection, EMI filter IP4252CZ12-6-TTL 2.5 x 1.35 x 0.5 USB (CSP package) SOT1168 (16 pin QFN) 6+2 SD-card / MMC 7 40 Ω 12 >52 (Mini) SD card/trans flash ESD protection, EMI filter 40 Ω / 50 kΩ / 25 kΩ 18 ~20 (Mini) SD/trans flash card ESD protection, EMI filter, pull-up resistors IP4052CX20/LF 20 ball CSP 2.54 x 1.96 x 0.65 - 5 ~24 Memory stick PRO ESD protection IP4067CX9/LF 9 ball CSP 1.46 x 1.52 x 0.65 15 Ω / 50 kΩ / 15 kΩ 8 >52 Very low capacitance, low channel resistance (mini) SD card/trans flash ESD protection EMI filter, pull-up resistor IP4350CX24/LF IP4252CZ16-8-TTL >52 (Mini) SD card/trans flash ESD protection, EMI filter, pull-up resistor IP4352CX24/LF - - >52 (Mini) SD/SDIO memory card level shifter, can be combined with IP4352CX24/LF IP4852CX25/LF (Mini) SD/SDIO memory card level shifter, and voltage regular, incl. ESD and EMI filter IP4853CX24/P - >52 3 1.95 x 2.11 x 0.61 3+2 20 40 Ω / 50 kΩ / 15 kΩ 35 >6 33 Ω 35 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection and impedance matching IP4078CX6/LF - 1.3 ~1 GHz USB2.0 high-speed ESD protection IP4359CX4/LF 4 ball CSP 0.76 x 0.76 x 0.61 - 1.3 ~1 GHz USB2.0 high-speed ESD protection IP4356CX4 4 ball CSP 0.76 x 0.76 x 0.61 IP4365CX11/P 11 ball CSP 1.16 x 1.56 x 0.61 3.3 x 1.35 x 0.5 24 ball CSP 40 Ω / 50 kΩ / 15 kΩ 6 (+3) 17 Ω / 1.5 kΩ Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching 47 Ω / 100 Ω 10 ~20/6 Integrated low capacitance SIM-Card & USB passive filter array with ESD protection 33 Ω / 1.5 kΩ / 20 kΩ 17 >6 Fully integrated USB low / fullspeed interface with EMI filter, ESD protection, pull-up resistors and impedance matching IP4368CX9/P 5 ball CSP 1.16 x 1.16 x 0.61 3 >240 USB2.0 high-speed ESD protection IP4059CX5/LF 5 ball CSP 0.96 x 1.34 x 0.65 1.3 ~1 GHz USB2.0 high-speed ESD protection IP4358CX6 6 ball CSP 0.76 x 1.16 x 0.41 1.3 ~1 GHz USB2.0 high-speed ESD protection IP4319CX10 10 ball CSP 1.56 x 1.05 x 0.61 2.02 x 2.01 x 0.61 25 ball CSP 2.01 x 2.01 x 0.61 4 24 ball CSP ESD protection acc. to IEC 61000-4-2 (level 4) - Please find more ESD protection diodes for ultra high-speed interfaces on pages 28 - 31 SOT457 (SC-74) Battery and charger protection Baseband Number of interface protected lines types in bold represent new products Cline (pF) Diode voltage Remark Type 180 450 160 290 Breakdown 16 V Breakdown 7 V Breakdown 16 V Breakdown 10 V Power diode Power diode Power diode Power diode IP4085CX4 IP4385CX4 IP4386CX4 IP4387CX4 160 VRWM = 12 V Power diode with 2 A integrated fuse IP4389CX4 160 VRWM = 12 V Power diode PESD12VS1UJ Package 4 ball CSP A1 2 - >15 kV IEC contact ESD protection with pi-filter IP4234CZ6 - 1.0 - ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2X - ESD protection for up to 2 ultra high-speed datalines with 12 kV ESD robustness 0.91 x 0.91 x 0.65 USB2.0 (Plastic A2 B2 package) SOT143B 2 2.9 x 1.3 x 1.0 - 1.8 PRTR5V0U2AX SOT886 (XSON6) SOD323F (SC-90) Battery & charger protection 1 1.7 x 1.25 x 0.7 - SOD323 (SC-76) 160 VRWM = 12 V Power diode PESD12VS1UA 480 VRWM = 5 V Power diode PESD5V0S1UJ 480 VRWM = 5 V Power diode PESD5V0S1UA 2.9 x 1.5 x 1.0 Size (mm) 0.76 x 0.76 x 0.61 B1 0.5 0.7 - ESD protection for ultra high-speed interfaces IP4282CZ6 1.45 x 1.0 x 0.5 1.7 x 1.25 x 0.95 SOD323F (SC-90) 1.7 x 1.25 x 0.7 ESD protection acc. to IEC 61000-4-2 (level 4) SOD323 (SC-76) 1.7 x 1.25 x 0.95 ESD protection acc. to IEC 61000-4-2 (level 4) 42 43 Application-specific ESD and ESD/EMI solutions Type Package Size (mm) Cline (pF) Remark SOT891 (XSON6) - 1 ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2K USB, SATA, LAN USB3.0: Ultra high-speed 4 channel ESD protection – IP4292CZ10-TBR Protection and signal conditioning types in bold represent new products Rline Number of protected lines Baseband interface USB, SATA, LAN In the Spotlight Application-specific ESD and ESD/EMI solutions Low clamping voltage ensures best protection of the System Chip Low Cline and high ESD protecion level Straight through routing ➞ best signal integrity Clean eye diagrams 10 pin QFN package with exposed leads (SOT1176) 1.0 x 1.0 x 0.5 types in bold represent new products ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2D 2.9 x 1.5 x 1.0 SOT886 (XSON6) - 1 ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2F - 0.8 USB protection for USB OTG with 5.5 V Vbat protection PUSBM5V5X4-TL - 0.8 USB protection for USB OTG with 12 V Vbat protection PUSBM12VX4-TL - 0.8 USB protection for USB OTG with 15 V Vbat protection PUSBM15VX4-TL 1.45 x 1.0 x 0.5 Type Package Size (mm) SOT1176 (XSON10) SOT1189 (HXSON6) - 3+1 USB2.0 (Plastic package) Remark Cline (pF) 1 Rline - Baseband interface 2 Number of protected lines SOT457 (SC-74) 0.5 ESD protection for ultra high-speed interfaces IP4284CZ10-TBR 1.0 x 2.5 x 0.5 1.6 x 1.6 x 0.5 - 0.8 USB protection for USB OTG with 27 V Vbat protection PUSBM27VX4-TL - 1 Dual ESD protection for USB2.0 high-speed, SD-card, SIM card IP4220CZ6 SOT552 (TSSOP10) USB3.0 SuperSpeed USB 4 - 0.5 ESD protection for ultra high-speed interfaces IP4284CZ10-TT 3.0 x 3.0 x 1.1 SOT457 (SC-74) SOT1176 (XSON10) 2.9 x 1.5 x 1.0 - 1 Dual ESD protection for USB2.0 high-speed, SD-card, SIM card - PRTR5V0U4D 0.5 ESD protection for ultra high-speed interfaces IP4292CZ10-TBR 1.0 x 2.5 x 0.5 SOT363 (SC-88) - 1 Dual ESP protection for USB2.0 high-speed, SD-card, SIM card ESD protection acc. to IEC 61000-4-2 (level 4) PRTR5V0U4Y 2.0 x 1.25 x 0.95 SOT886 (XSON6) 4 - 1 ESD protection for USB2.0 high-speed, SD-card, SIM card IP4221CZ6-S 1.45 x 1.0 x 0.5 SOT891 (XSON6) - 1 ESD protection for USB2.0 high-speed, SD-card, SIM card IP4221CZ6-XS 1.0 x 1.0 x 0.5 SOT457 (SC-74) 1 3 >15 kV IEC contact ESD protection with pi-filter IP4225CZ10 2.9 x 1.5 x 1.0 ESD protection acc. to IEC 61000-4-2 (level 4) 44 45 Application-specific ESD and ESD/EMI solutions Remark Type Package - 0.6 Ethernet ESD protection VRWM = 3.3 V PESD3V3U1UT - 0.6 Ethernet ESD protection VRWM = 5.0 V PESD5V0U1UT - 0.6 Ethernet ESD protection VRWM = 12 V PESD12VU1UT - 0.6 Ethernet ESD protection VRWM = 15 V PESD15VU1UT - 0.6 Ethernet ESD protection VRWM = 24 V PESD24VU1UT Size (mm) SOT363 (SC-88) 4 - 0.6 ESD protection for ultra high-speed interfaces IP4286CZ6-TTY Display port 2.0 x 1.25 x 0.95 Protection and signal conditioning Size (mm) Cline (pF) Package types in bold represent new products Rline Type Cline (pF) Remark USB, SATA, LAN Number of protected lines types in bold represent new products Rline Number of protected lines Baseband interface USB, SATA, LAN Baseband interface Application-specific ESD and ESD/EMI solutions SOT510 (TSSOP38) 11 - 0.7 ESD protection IP4790CZ38 - 0.7 ESD protection for ultra high-speed interfaces IP4282CZ6 9.7 x 4.4 x 1.1 SOT23 SOT886 (XSON6) 1 2.9 x 1.3 x 1.0 1.45 x 1.0 x 0.5 IP4286CZ6-TBF 2 - 0.6 LAN SOT363 (SC-88) ESD protection for ultra high-speed interfaces IP4286CZ6-TTY 2.0 x 1.25 x 0.95 SOT1176 (XSON10) - 0.6 ESD protection for ultra high-speed interfaces IP4283CZ10-TBR 1.0 x 2.5 x 0.5 SOT457 (SC-74) - 1 Ethernet ESD protection IP4220CZ6 2.9 x 1.5 x 1.0 SOT552 (TSSOP10) - 0.6 ESD protection for ultra high-speed interfaces 4 IP4283CZ10-TT SOT363 (SC-88) 3.0 x 3.0 x 1.1 - SATA 1 IP4233CZ6 Ethernet line surge ESD protection 2.0 x 1.25 x 0.95 SOT1176 (XSON10) ESD protection acc. to IEC 61000-4-2 (level 4) 3.0 x 3.0 x 1.1 SOT1178 (XSON9) - 0.8 ESD protection for ultra high-speed interfaces IP4285CZ9-TBB 1.0 x 2.5 x 0.1 VRWM (V) 1 15 (diode 1) 24 (diode 2) Ir max [µA] @ VRWM IP4284CZ10-TT [2] ESD protection for ultra high-speed interfaces ESD rating max (kV) 0.5 max (W) Automotive LIN/CAN/FlexRay SOT552 (TSSOP10) - Please find more ESD protection diodes for ultra high-speed interfaces on pages 28 - 31 [1] 4 1.0 x 2.5 x 0.5 PPP IP4284CZ10-TBR Cline max (pF) ESD protection for ultra high-speed interfaces Cline typ (pF) 0.5 Number of protected lines bidirectional - Configuration Type Package Size (mm) SOD323 (SC-76) SOT1176 (XSON10) - 0.5 ESD protection for ultra high-speed interfaces 13 17 160 23 0.05 15 V 1 24 V 2 PESD1LIN 1.7 x 1.25 x 0.95 bra526 IP4292CZ10-TBR 1.0 x 2.5 x 0.5 11 ESD protection acc. to IEC 61000-4-2 (level 4) 17 200 23 0.05 PESD1CAN 1 2 24 25 30 230 30 SOT23 3 0.01 PESD2CAN 2.9 x 1.3 x 1.0 2 mse213 11 46 [1] 8/20 µs surge pulse acc. to IEC 61000-4-5 17 200 [2] 23 0.05 acc. to IEC 61000-4-2 (contact discharge) PESD1FLEX 47 24 40 [1] 5.32 5.6 5.88 20 30 210 8 3 5 MMBZ5V6AL 5.89 6.2 6.51 1 30 175 8.7 2.76 0.2 MMBZ6V2AL 4.5 6.48 6.8 7.14 1 30 150 9.6 2.5 0.3 MMBZ6V8AL 6 8.65 9.1 9.56 1 30 155 14 1.7 0.1 MMBZ9V1AL 6.5 9.5 10 10.5 1 30 130 14.2 1.7 0.02 MMBZ10VAL 8.5 11.4 12 12.6 1 30 110 17 2.35 0.005 MMBZ12VAL 12 14.25 15 15.75 1 30 85 21 1.9 0.005 MMBZ15VAL 14.5 17.1 18 18.9 1 30 70 25 1.6 0.005 MMBZ18VAL 17 19 20 21 1 30 65 28 1.4 0.005 MMBZ20VAL 22 25.65 27 28.35 1 30 48 40 1 0.005 MMBZ27VAL 26 31.35 33 34.65 1 30 45 46 0.87 0.005 MMBZ33VAL 8.5 11.4 12 12.6 1 30 110 17 2.35 0.005 MMBZ12VDL 12.8 14.3 15 15.8 1 30 85 21.2 1.9 0.005 14.5 17.1 18 18.9 1 30 70 25 1.6 0.005 17 19 20 21 1 30 65 28 1.4 0.005 22 25.65 27 28.35 1 30 48 38 1 0.005 26 31.35 33 34.65 1 30 45 46 0.87 0.005 acc. to IEC 61643-321 [2] 1 SOT23 2.9 x 1.3 x 1.0 MMBZ15VDL 3 MMBZ18VCL MMBZ20VCL 2 MMBZ27VCL bra004 600 MMBZ33VCL acc. to IEC 61000-4-2 (contact discharge) 400 [1] 48 3.5 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10 11 12 13 14 15 16 17 18 20 22 24 26 28 30 33 36 40 43 45 48 51 54 58 60 64 5.60 6.70 7.02 7.60 8.20 8.77 9.36 9.92 10.55 11.70 12.85 14.00 15.15 16.40 17.60 18.75 19.90 21.00 23.35 25.60 28.10 30.40 32.80 35.10 38.70 42.10 46.80 50.30 52.65 56.10 59.70 63.15 67.80 70.20 74.85 6.00 7.00 7.37 7.98 8.60 9.21 9.83 10.40 11.10 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 49.10 52.80 55.30 58.90 62.70 66.30 71.20 73.70 78.60 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 8.0 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 43.8 43.5 38.8 35.7 33.3 31.0 29.4 27.8 26.0 23.5 22.0 20.1 18.6 17.2 16.4 15.4 14.5 13.7 12.3 11.3 10.3 9.5 8.8 8.3 7.5 6.9 6.2 5.8 5.5 5.2 4.9 4.6 4.3 4.1 3.9 5 5 5 5 3 0.2 0.03 0.01 0.005 0.005 0.005 0.005 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 0.001 IRM max (µA) @ VRWM IRM typ (µA) @ VRWM IPP (A) VCL max (V) @ IPP IR (mA) VBR max (V) @ IR VBR typ (V) @ IR VBR min (V) @ IR 5.20 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.00 11.10 12.20 13.30 14.40 15.60 16.70 17.80 18.90 20.00 22.20 24.40 26.70 28.90 31.10 33.30 36.70 40.00 44.40 47.80 50.00 53.30 56.70 60.00 64.40 66.70 71.10 600 400 400 250 100 50 25 10 5 2.5 2.5 2.5 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 Type PTVS3V3S1UR PTVS5V0S1UR PTVS6V0S1UR PTVS6V5S1UR PTVS7V0S1UR PTVS7V5S1UR PTVS8V0S1UR PTVS8V5S1UR PTVS9V0S1UR PTVS10VS1UR PTVS11VS1UR PTVS12VS1UR PTVS13VS1UR PTVS14VS1UR PTVS15VS1UR PTVS16VS1UR PTVS17VS1UR PTVS18VS1UR PTVS20VS1UR PTVS22VS1UR PTVS24VS1UR PTVS26VS1UR PTVS28VS1UR PTVS30VS1UR PTVS33VS1UR PTVS36VS1UR PTVS40VS1UR PTVS43VS1UR PTVS45VS1UR PTVS48VS1UR PTVS51VS1UR PTVS54VS1UR PTVS58VS1UR PTVS60VS1UR PTVS64VS1UR Package Size (mm) [1] SOD123W 2.6 x 1.7 x 1.0 IRM max (µA) @ VRWM IRM typ (µA) @ VRWM IPP (A) VCL max (V) @ IPP IR (mA) VBR max (V) @ IR 3.5 5.20 5.60 6.00 10 8 75 5 600 PTVS3V3P1UP 5 6.40 6.70 7.00 10 9.2 65.2 5 400 PTVS5V0P1UP 6 6.67 7.02 7.37 10 10.3 58.3 5 400 PTVS6V0P1UP 6.5 7.22 7.60 7.98 10 11.2 53.6 5 250 PTVS6V5P1UP 7 7.78 8.20 8.60 10 12 50 3 100 PTVS7V0P1UP 7.5 8.33 8.77 9.21 1 12.9 46.5 0.2 50 PTVS7V5P1UP 8 8.89 9.36 9.83 1 13.6 44.1 0.03 25 PTVS8V0P1UP 8.5 9.44 9.92 10.40 1 14.4 41.7 0.01 10 PTVS8V5P1UP 9 10.00 10.55 11.10 1 15.4 39 0.005 5 PTVS9V0P1UP 10 11.10 11.70 12.30 1 17 35.3 0.005 2.5 PTVS10VP1UP 11 12.20 12.85 13.50 1 18.2 33 0.005 2.5 PTVS11VP1UP 12 13.30 14.00 14.70 1 19.9 30.2 0.005 2.5 PTVS12VP1UP 13 14.40 15.15 15.90 1 21.5 27.9 0.001 0.1 PTVS13VP1UP 14 15.60 16.40 17.20 1 23.2 25.9 0.001 0.1 PTVS14VP1UP 15 16.70 17.60 18.50 1 24.4 24.6 0.001 0.1 PTVS15VP1UP 16 17.80 18.75 19.70 1 26 23.1 0.001 0.1 PTVS16VP1UP 17 18.90 19.90 20.90 1 27.6 21.7 0.001 0.1 PTVS17VP1UP 18 20.00 21.00 22.10 1 29.2 20.5 0.001 0.1 PTVS18VP1UP 20 22.20 23.35 24.50 1 32.4 18.5 0.001 0.1 PTVS20VP1UP 22 24.40 25.60 26.90 1 35.5 16.9 0.001 0.1 PTVS22VP1UP 24 26.70 28.10 29.50 1 38.9 15.4 0.001 0.1 PTVS24VP1UP 26 28.90 30.40 31.90 1 42.1 14.2 0.001 0.1 PTVS26VP1UP 28 31.10 32.80 34.40 1 45.4 13.2 0.001 0.1 PTVS28VP1UP 30 33.30 35.10 36.80 1 48.4 12.4 0.001 0.1 PTVS30VP1UP 33 36.70 38.70 40.60 1 53.3 11.3 0.001 0.1 PTVS33VP1UP 36 40.00 42.10 44.20 1 58.1 10.3 0.001 0.1 PTVS36VP1UP 40 44.40 46.80 49.10 1 64.5 9.3 0.001 0.1 PTVS40VP1UP 43 47.80 50.30 52.80 1 69.4 8.6 0.001 0.1 PTVS43VP1UP 45 50.00 52.65 55.30 1 72.7 8.3 0.001 0.1 PTVS45VP1UP 48 53.30 56.10 58.90 1 77.4 7.8 0.001 0.1 PTVS48VP1UP 51 56.70 59.70 62.70 1 82.4 7.3 0.001 0.1 PTVS51VP1UP 54 60.00 63.15 66.30 1 87.1 6.9 0.001 0.1 PTVS54VP1UP 58 64.40 67.80 71.20 1 93.6 6.4 0.001 0.1 PTVS58VP1UP 60 66.70 70.20 73.70 1 96.8 6.2 0.001 0.1 PTVS60VP1UP 64 71.10 74.85 78.60 1 103 5.8 0.001 0.1 PTVS64VP1UP Package Size (mm) SOD128 3.8 x 2.6 x 1.0 10/1000 µs acc. to IEC 61643-321 In the Spotlight 350 VRWM (V) Power (W) (10/1000 µs waveform) [1] TVS diodes, 400 W Type Protection and signal conditioning 3 3 Size (mm) VBR typ (V) @ IR Package VBR min (V) @ IR Type VRWM (V) Configuration Power (W) (10/1000 µs waveform) IRM max (µA) @ VRWM IPP (A) VCL max (V) @ IPP Cline typ (pF) [1] max (kV) [2] ESD rating IR (mA) VBR typ (V) @ IR VBR max (V) @ IR TVS diodes, 600 W VBR min (V) @ IR TVS diodes, 24 W / 40 W VRWM (V) TVS diodes Power (W) (10/1000 µs waveform) [1] TVS diodes 600 / 400 W TVS series – PTVSxP1UP & PTVSxS1UR Industry‘s smallest packages in the 600 / 400 W surge protection class Small FlatPower packages SOD123W/128, only 1 mm high AEC-Q101 qualified Low reverse leakage current (down to 1 nA typical) 10/1000 µs acc. to IEC 61643-321 49 Protection andconditioning signal conditioning nomenclature Protection and signal nomenclature PESD 5V0 S 1 UL NXP Packages ESD (ESD protection) RTR (Rail-to-rail ESD protection) TVS (10/1000 μs pulse spec.) Uni-directional* Bi-directional* *not for rail-to-rail devices Number of protected lines Reverse stand-off voltage For ESD – Capacitance class >50 pF Standard capacitance
BYC10X-600,127 价格&库存
很抱歉,暂时无法提供与“BYC10X-600,127”相匹配的价格&库存,您可以联系我们找货
