1N1204AR
1N1204AR
    GENESICSEMICONDUCTOR
    DO-203AA(DO-5)
    Diode Standard, Reverse Polarity 400V 12A Chassis, Stud Mount DO-4
1N1204AR 数据手册
1N1199A thru 1N1206AR Silicon Standard Recovery Diode VRRM = 50 V - 600 V IF = 12 A Features • High Surge Capability • Types from 50 V to 600 V VRRM DO-4 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Symbol Conditions 1N1199A(R) 1N1200A(R) 1N1202A(R) 1N1204A(R) 1N1206A(R) Unit VRRM 50 100 200 400 600 V VRMS 35 70 140 280 420 V VDC 50 100 200 400 600 V Continuous forward current IF TC ≤ 150 °C 12 12 12 12 12 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 240 240 240 240 240 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Symbol Diode forward voltage VF Reverse current IR Conditions IF = 12 A, Tj = 25 °C VR = 50 V, Tj = 25 °C VR = 50 V, Tj = 175 °C 1N1199A(R) 1N1200A(R) 1N1202A(R) 1N1204A(R) 1N1206A(R) Unit V 1.1 10 15 1.1 10 15 1.1 10 15 1.1 10 15 1.1 10 15 μA mA 2.00 2.00 2.00 2.00 2.00 °C/W Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/1n1204ar.pdf 1 1N1199A thru 1N1206AR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/1n1204ar.pdf 2 1N1199A thru 1N1206AR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 4 (DO-203AA) M J P D B G N C E F A A C A C Stud Stud (R) Inches Min Millimeters Max A Oct. 2018 Min Max 10-32 UNF B 0.424 0.437 10.77 11.10 C ----- 0.505 ----- 12.82 D ------ 0.800 ----- 20.30 E 0.453 0.492 11.50 12.50 F 0.114 0.140 2.90 3.50 G ----- 0.405 ----- 10.29 J ----- 0.216 ----- 5.50 M ----- φ0.302 ----- φ7.68 N 0.031 0.045 0.80 1.15 P 0.070 0.79 1.80 2.00 http://www.diodemodule.com/silicon_products/studs/1n1204ar.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: 1N1204AR
1N1204AR 价格&库存
很抱歉,暂时无法提供与“1N1204AR”相匹配的价格&库存,您可以联系我们找货
1N1204AR
    • 1+66.61440
    • 250+26.57880
    • 500+25.69320
    • 1000+25.25040
