FR70MR05
FR70MR05
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
    FR70MR05
FR70MR05 数据手册
FR70K05 thru FR70MR05 Silicon Fast Recovery Diode VRRM = 800 V - 1000 V IF = 70 A Features • High Surge Capability • Types from 800 V to 1000 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. 3. Stud is base. C A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage FR70K(R)05 FR70M(R)05 Unit VRRM 800 1000 V VRMS 560 700 V VDC 800 1000 V Symbol Conditions Continuous forward current IF TC ≤ 100 °C 70 70 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 870 870 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions FR70K(R)05 FR70M(R)05 Unit VF IF = 70 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 125 °C 1.0 25 15 1.0 25 15 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 500 500 nS IR V Recovery Time Maximum reverse recovery time Oct. 2018 TRR http://www.diodemodule.com/silicon_products/studs/fr70mr05.pdf 1 FR70K05 thru FR70MR05 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr70mr05.pdf 2 FR70K05 thru FR70MR05 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr70mr05.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: FR70MR05
FR70MR05 价格&库存
很抱歉,暂时无法提供与“FR70MR05”相匹配的价格&库存,您可以联系我们找货
