S40YR
S40YR
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
S40YR 数据手册
S40V thru S40YR Silicon Standard Recovery Diode VRRM = 1400 V - 1600 V IF = 40 A Features • High Surge Capability • Types from 1400 V to 1600 V VRRM DO-5 Package • Not ESD Sensitive C A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S40V (R) S40Y (R) Unit VRRM 1400 1600 V VRMS 990 1130 V VDC 1400 1600 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Conditions Continuous forward current IF TC ≤ 110 °C 40 40 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 595 595 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S40V (R) S40Y (R) Unit IF = 40 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 160 °C 1.1 10 4.5 1.1 10 4.5 μA mA 1.25 1.25 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s40yr.pdf 1 S40V thru S40YR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s40yr.pdf 2 S40V thru S40YR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/s40yr.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S40YR
S40YR 价格&库存
很抱歉,暂时无法提供与“S40YR”相匹配的价格&库存,您可以联系我们找货
