S70K
S70K
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
S70K 数据手册
S70K thru S70QR Silicon Standard Recovery Diode VRRM = 800 V - 1200 V IF = 70 A Features • High Surge Capability • Types from 800 V to 1200 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. C A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified S70K (R) S70M (R) S70Q (R) Unit VRRM 800 1000 1200 V VRMS 560 700 840 V VDC 800 1000 1200 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Conditions ("R" devices have leads reversed) Continuous forward current IF TC ≤ 140 °C 70 70 70 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 1250 1250 1250 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S70K (R) S70M (R) S70Q (R) Unit IF = 70 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 180 °C 1.1 10 9 1.1 10 9 1.1 10 9 μA mA 0.65 0.65 0.65 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s70k.pdf 1 S70K thru S70QR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s70k.pdf 2 S70K thru S70QR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Millimeters Min Max Min Max B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 1/4 –28 UNF A Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s70k.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S70K
很抱歉,暂时无法提供与“S70K”相匹配的价格&库存,您可以联系我们找货
S70K
    • 1+155.70360
    • 200+62.13240
    • 500+60.04800
    • 1000+59.03280
