S70V thru S70YR
Silicon Standard
Recovery Diode
VRRM = 1400 V - 1600 V
IF = 70 A
Features
• High Surge Capability
• Types from 1400 V to 1600 V VRRM
DO-5 Package
• Not ESD Sensitive
C
A
Note:
1. Standard polarity: Stud is cathode.
2. Reverse polarity (R): Stud is anode.
A
C
Stud Stud
(R)
3. Stud is base.
Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed)
S70V (R)
S70Y (R)
Unit
VRRM
1400
1600
V
VRMS
990
1130
V
VDC
1400
1600
V
Parameter
Symbol
Repetitive peak reverse voltage
RMS reverse voltage
DC blocking voltage
Conditions
Continuous forward current
IF
TC ≤ 110 °C
70
70
A
Surge non-repetitive forward
current, Half Sine Wave
IF,SM
TC = 25 °C, tp = 8.3 ms
1250
1250
A
Operating temperature
Storage temperature
Tj
Tstg
-55 to 150
-55 to 150
-55 to 150
-55 to 150
°C
°C
Electrical characteristics, at Tj = 25 °C, unless otherwise specified
Parameter
Diode forward voltage
Reverse current
Symbol
VF
IR
Conditions
S70V (R)
S70Y (R)
Unit
IF = 70 A, Tj = 25 °C
VR = 100 V, Tj = 25 °C
VR = 100 V, Tj = 150 °C
1.1
10
4.5
1.1
10
4.5
μA
mA
0.65
0.65
°C/W
V
Thermal characteristics
Thermal resistance, junction case
Oct. 2018
RthJC
http://www.diodemodule.com/silicon_products/studs/s70yr.pdf
1
S70V thru S70YR
Oct. 2018
2
S70V thru S70YR
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
DO- 5 (DO-203AB)
M
J
K
P
D
B
G
N
C
F
E
A
A
C
A
C
Stud Stud
(R)
Inches
Millimeters
Min
Max
Min
Max
B
0.669
0.687
17.19
17.44
C
0.794
20.16
D
1.020
25.91
E
0.422
0.453
10.72
11.50
F
0.115
0.200
2.93
5.08
G
0.460
11.68
J
0.280
7.00
K
0.236
6.00
M
0.589
14.96
N
0.063
1.60
P
0.140
0.175
3.56
4.45
1/4 –28 UNF
A
Oct. 2018
3
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
GeneSiC Semiconductor:
S70YR
很抱歉,暂时无法提供与“S70YR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+160.81200
- 200+64.17360
- 500+62.02440
- 1000+60.96600
