S85GR
S85GR
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
S85GR 数据手册
S85B thru S85JR Silicon Standard Recovery Diode VRRM = 100 V - 600 V IF =85 A Features • High Surge Capability • Types from 100 V to 600 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. C A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S85B (R) S85D (R) S85G (R) S85J (R) Unit VRRM 100 200 400 600 V VRMS 70 140 280 420 V 600 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage VDC Conditions 100 200 400 Continuous forward current IF TC ≤ 140 °C 85 85 85 85 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 1800 1800 1800 1800 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S85B (R) S85D (R) S85G (R) S85J (R) Unit IF = 85 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 180 °C 1.1 10 15 1.1 10 15 1.1 10 15 1.1 10 9 μA mA 0.65 0.65 0.65 0.65 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s85gr.pdf 1 S85B thru S85JR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s85gr.pdf 2 S85B thru S85JR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/s85gr.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S85GR
S85GR
PDF文档中包含的物料型号为S85B至S85JR,是GeneSiC公司生产的硅标准恢复二极管。
器件简介指出它们具有高浪涌能力,不敏感于静电放电,电压等级从100V到600V。
引脚分配中,标准极性下,焊盘是阴极,焊盘是基极;在反向极性(R)中,焊盘是阳极。
参数特性包括重复峰值反向电压、RMS反向电压、直流阻断电压、连续正向电流、浪涌非重复正向电流、工作温度和存储温度。
功能详解部分提供了正向特性曲线、正向降额曲线、峰值正向浪涌电流和典型反向特性。
应用信息中,这些二极管适用于单相半波60Hz电阻性或电感性负载。
封装信息为DO-5(DO-203AB),并提供了详细的尺寸和终端配置。
S85GR 价格&库存
很抱歉,暂时无法提供与“S85GR”相匹配的价格&库存,您可以联系我们找货
