S85MR
S85MR
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
S85MR 数据手册
S85K thru S85QR Silicon Standard Recovery Diode VRRM = 800 V - 1200 V IF = 85 A Features • High Surge Capability • Types from 800 V to 1200 V VRRM DO-5 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified S85K (R) S85M (R) S85Q (R) Unit VRRM 800 1000 1200 V VRMS 560 700 840 V VDC 800 1000 1200 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Conditions ("R" devices have leads reversed) Continuous forward current IF TC ≤ 140 °C 85 85 85 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 1800 1800 1800 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S85K (R) S85M (R) S85Q (R) Unit IF = 85 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 180 °C 1.1 10 9 1.1 10 9 1.1 10 9 μA mA 0.65 0.65 0.65 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s85mr.pdf 1 S85K thru S85QR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s85mr.pdf 2 S85K thru S85QR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Oct. 2018 Min Max 1/4 –28 UNF A B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/s85mr.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S85MR
S85MR 价格&库存
很抱歉,暂时无法提供与“S85MR”相匹配的价格&库存,您可以联系我们找货
