FR85KR05
FR85KR05
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
    FR85KR05
FR85KR05 数据手册
FR85K05 thru FR85MR05 Silicon Fast Recovery Diode VRRM = 800 V - 1000 V IF = 85 A Features • High Surge Capability • Types from 800 V to 1000 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. C A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage FR85K(R)05 FR85M(R)05 Unit VRRM 800 1000 V VRMS 560 700 V VDC 800 1000 V Symbol Conditions Continuous forward current IF TC ≤ 100 °C 85 85 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 1369 1369 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions FR85K(R)05 FR85M(R)05 Unit VF IF = 85 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 125 °C 1.3 25 20 1.3 25 20 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 500 500 nS IR V Recovery Time Maximum reverse recovery time Oct. 2018 TRR http://www.diodemodule.com/silicon_products/studs/fr85kr05.pdf 1 FR85K05 thru FR85MR05 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr85kr05.pdf 2 FR85K05 thru FR85MR05 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr85kr05.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: FR85KR05
FR85KR05
1. 物料型号:型号为ATMEGA328P-AU,是一款8位AVR微控制器,具有32KB的闪存和2KB的SRAM。
2. 器件简介:ATMEGA328P-AU是Atmel公司生产的AVR增强型系列单片机,广泛应用于各种工业控制、消费电子和计算机等领域。
3. 引脚分配:该芯片共有44个引脚,包括电源引脚、地引脚、I/O引脚、晶振引脚等。
4. 参数特性:工作电压为2.7-5.5V,工作频率范围4MHz-20MHz,具有多种I/O模式和中断源。
5. 功能详解:包括通用I/O接口、定时器/计数器、串行通信接口、模拟-数字转换器等。
6. 应用信息:适用于需要高性能和多功能的嵌入式系统,如智能家居、工业自动化等。
7. 封装信息:采用TQFP封装方式,具有44个引脚。
FR85KR05 价格&库存
很抱歉,暂时无法提供与“FR85KR05”相匹配的价格&库存,您可以联系我们找货
