GB10SLT12-220
GB10SLT12-220
    GENESICSEMICONDUCTOR
    TO-220-2
    DIODE SCHOTTKY 1200V 10A TO220AC
GB10SLT12-220 数据手册
GB10SLT12-220   Silicon Carbide Power Schottky Diode VRRM IF (Tc = 25°C) QC Features Package         RoHS Compliant 1200 V Schottky rectifier 175 °C maximum operating temperature Temperature independent switching behavior Superior surge current capability Positive temperature coefficient of VF Extremely fast switching speeds Superior figure of merit QC/IF = = =   1200 V 25 A 31 nC case PIN 1 2 CASE PIN 2 1       TO – 220AC Advantages Applications                Improved circuit efficiency (Lower overall cost) Low switching losses Ease of paralleling devices without thermal runaway Smaller heat sink requirements Low reverse recovery current Low device capacitance Low reverse leakage current at operating temperature Power Factor Correction (PFC) Switched-Mode Power Supply (SMPS) Solar Inverters Wind Turbine Inverters Motor Drives Induction Heating Uninterruptible Power Supply (UPS) High Voltage Multipliers Maximum Ratings at Tj = 175 °C, unless otherwise specified Parameter Repetitive peak reverse voltage Continuous forward current RMS forward current Surge non-repetitive forward current, Half Sine Wave Non-repetitive peak forward current 2 Symbol VRRM IF IF(RMS) IF,SM IF,max 2 I t value ∫i dt Power dissipation Operating and storage temperature Ptot Tj , Tstg Conditions Values 1200 10 17 65 55 280 21 15 190 -55 to 175 TC ≤ 150 °C TC ≤ 150 °C TC = 25 °C, tP = 10 ms TC = 150 °C, tP = 10 ms TC = 25 °C, tP = 10 µs TC = 25 °C, tP = 10 ms TC = 150 °C, tP = 10 ms TC = 25 °C Unit V A A A A 2 As W °C Electrical Characteristics at Tj = 175 °C, unless otherwise specified Parameter Symbol Diode forward voltage VF Reverse current IR Total capacitive charge QC Switching time ts Total capacitance C Conditions min. IF = 10 A, Tj = 25 °C IF = 10 A, Tj = 175 °C VR = 1200 V, Tj = 25 °C VR = 1200 V, Tj = 175 °C VR = 400 V IF ≤ IF,MAX VR = 960 V dIF/dt = 200 A/μs VR = 400 V Tj = 175 °C VR = 960 V VR = 1 V, f = 1 MHz, Tj = 25 °C VR = 400 V, f = 1 MHz, Tj = 25 °C VR = 1000 V, f = 1 MHz, Tj = 25 °C Values typ. 1.5 2.6 5 10 31 52 max. 1.8 3.0 50 100 Unit V µA nC < 25 ns 490 45 33 pF RthJC 0.8 °C/W M 0.6 Nm Thermal Characteristics Thermal resistance, junction - case Mechanical Properties Mounting torque Aug 2014   http://www.genesicsemi.com/index.php/sic-products/schottky Pg1 of 4 GB10SLT12-220   Figure 1: Typical Forward Characteristics Figure 2: Typical Reverse Characteristics Figure 3: Power Derating Curve Figure 4: Current Derating Curves (D = tP/T, tP= 400 µs) (Considering worst case Zth conditions ) Figure 5: Typical Junction Capacitance vs Reverse Voltage Characteristics Figure 6: Typical Switching Energy vs Reverse Voltage Characteristics Aug 2014   http://www.genesicsemi.com/index.php/sic-products/schottky   Pg2 of 4 GB10SLT12-220   Figure 7: Current vs Pulse Duration Curves at TC = 150 °C   Figure 8: Transient Thermal Impedance Package Dimensions: TO-220AC PACKAGE OUTLINE   NOTE 1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS Aug 2014   http://www.genesicsemi.com/index.php/sic-products/schottky Pg3 of 4 GB10SLT12-220     Revision History Date Revision Comments 2014/08/26 4 Updated Electrical Characteristics 2013/06/12 3 Updated Electrical Characteristics 2012/12/18 2 Second generation update 2012/05/22 1 Second generation release 2010/12/14 0 Initial release Supersedes Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155 Dulles, VA 20166 GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal injury and/or property damage. Aug 2014   http://www.genesicsemi.com/index.php/sic-products/schottky Pg4 of 4 GB10SLT12-220     SPICE Model Parameters Copy the following code into a SPICE software program for simulation of the GB10SLT12-220 device. * MODEL OF GeneSiC Semiconductor Inc. * * $Revision: 1.0 $ * $Date: 20-SEP-2013 $ * * GeneSiC Semiconductor Inc. * 43670 Trade Center Place Ste. 155 * Dulles, VA 20166 * http://www.genesicsemi.com/index.php/sic-products/schottky * * COPYRIGHT (C) 2013 GeneSiC Semiconductor Inc. * ALL RIGHTS RESERVED * * These models are provided "AS IS, WHERE IS, AND WITH NO WARRANTY * OF ANY KIND EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED * TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A * PARTICULAR PURPOSE." * Models accurate up to 2 times rated drain current. * * Start of GB10SLT12-220 SPICE Model * .SUBCKT GB10SLT12 ANODE KATHODE D1 ANODE KATHODE GB10SLT12_SCHOTTKY D2 ANODE KATHODE GB10SLT12_PIN .MODEL GB10SLT12_SCHOTTKY D + IS 4.55E-15 RS 0.0736 + N 1 IKF 1000 + EG 1.2 XTI -2 + TRS1 0.0054347826 TRS2 2.71739E-05 + CJO 6.40E-10 VJ 0.469 + M 1.508 FC 0.5 + TT 1.00E-10 BV 1200 + IBV 1.00E-03 VPK 1200 + IAVE 10 TYPE SiC_Schottky + MFG GeneSiC_Semi .MODEL GB10SLT12_PIN D + IS 1.54E-22 RS 0.19 + TRS1 -0.004 N 3.941 + EG 3.23 IKF 19 + XTI 0 FC 0.5 + TT 0 BV 1200 + IBV 1.00E-03 VPK 1200 + IAVE 10 TYPE SiC_PiN .ENDS * * End of GB10SLT12-220 SPICE Model Nov 2013   http://www.genesicsemi.com/index.php/sic-products/schottky Pg1 of 1 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: GB10SLT12-220
GB10SLT12-220
物料型号:GB10SLT12-220
器件简介:这是一个硅碳化物(Silicon Carbide)功率肖特基二极管,具有1200V的反向重复峰值电压(VRRM)和25A的正向连续电流(IF)。
引脚分配:文档中提到了PIN 1和PIN 2,但没有具体说明每个引脚的功能。
参数特性: - 工作温度范围:-55°C 至 175°C - 正向电压(VF)在25°C和175°C时的典型值分别为1.5V和1.8V - 反向电流(IR)在25°C和175°C时的典型值分别为5mA和50mA - 总电容电荷(Qc)在不同反向电压下的典型值范围为31nC至52nC - 开关时间(t_e)小于25ns - 热阻(RthJC)为0.8°C/W
功能详解:该二极管具有温度独立开关行为、优越的浪涌电流能力、正向电压的温度系数、极快的开关速度等特性。
应用信息:适用于功率因数校正(PFC)、开关电源(SMPS)、太阳能逆变器、风力涡轮逆变器、电机驱动、感应加热、不间断电源(UPS)和高压倍压器。
封装信息:采用TO-220AC封装。
GB10SLT12-220 价格&库存
很抱歉,暂时无法提供与“GB10SLT12-220”相匹配的价格&库存,您可以联系我们找货
