150KR80A
150KR80A
    GENESICSEMICONDUCTOR
    DO-205AA
150KR80A 数据手册
150K(R)20A thru 150K(R)100A Silicon Standard Recovery Diode VRRM = 200 V - 1000 V IF = 150 A Features • High Surge Capability • Types from 200 V to 1000 V VRRM DO-8 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. 3. Stud is base. C A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Conditions 150K(R)20A 150K(R)40A 150K(R)60A 150K(R)80A 150K(R)100A Unit Parameter Symbol Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V DC blocking voltage VDC 200 400 600 800 1000 V 150 A 3740 A Continuous forward current IF TC ≤ 110 °C 150 150 150 150 Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 3740 3740 3740 3740 I2t for fusing Operating temperature Storage temperature I2 t Tj Tstg 58000 -55 to 150 -55 to 150 58000 -55 to 150 -55 to 150 58000 -55 to 150 -55 to 150 58000 -55 to 150 -55 to 150 t = 8.3ms 58000 A2sec -55 to 150 °C -55 to 150 °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Symbol Conditions 150K(R)20A 150K(R)40A 150K(R)60A 150K(R)80A 150K(R)100A Unit Diode forward voltage VF IF = 150 A, Tj = 25 °C 1.33 1.33 1.33 1.33 1.33 V Reverse current IR VR = VRRM, Tj = 175 °C 35 35 35 32 24 mA 0.25 0.25 0.25 0.25 0.25 °C/W Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/150kr80a.pdf 1 150K(R)20A thru 150K(R)100A Oct. 2018 http://www.diodemodule.com/silicon_products/studs/150kr80a.pdf 2 150K(R)20A thru 150K(R)100A Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO-8 (DO-205AA) H I F A C D B A C Stud Stud (R) G C E A Inches Min Millimeters Max A Oct. 2018 Min Max 3/8-24 UNF B ----- φ0.930 ----- φ23.5 C 1.050 1.060 26.67 26.92 D 4.300 4.700 109.22 119.38 E ----- 0.690 ----- 17.00 F 0.260 ----- 6.50 ----- G ----- 0.940 ----- 24.00 H ----- 0.600 ----- 15.23 I 0.276 0.286 7.010 7.260 http://www.diodemodule.com/silicon_products/studs/150kr80a.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: 150KR80A
150KR80A 价格&库存
很抱歉,暂时无法提供与“150KR80A”相匹配的价格&库存,您可以联系我们找货
150KR80A
  • 50+322.7869050+41.70155
