MBRH120200R
MBRH120200R
    GENESICSEMICONDUCTOR
    D67
MBRH120200R 数据手册
MBRH120150 thru MBRH120200R Silicon Power Schottky Diode VRRM = 150 V - 200 V IF(AV) = 120 A Features • High Surge Capability • Types from 150 V to 200 V VRRM D-67 Package • Not ESD Sensitive Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature MBRH120150(R) MBRH120200(R) Unit VRRM 150 200 V VRMS 106 141 V VDC Tj Tstg 150 -55 to 150 -55 to 150 150 -55 to 150 -55 to 150 V °C °C Symbol Conditions Electrical characteristics, at Tj = 25 °C, unless otherwise specified Symbol Conditions MBRH120150(R) MBRH120200(R) Unit Average forward current (per pkg) IF(AV) TC = 125 °C 120 120 A Peak forward surge current IFSM tp = 8.3 ms, half sine 2000 2000 A Maximum instantaneous forward voltage VF IFM = 120 A, Tj = 25 °C 0.88 0.92 V Maximum instantaneous reverse current at rated DC blocking voltage IR Tj = 25 °C Tj = 100 °C Tj = 150 °C 1 10 30 1 10 30 mA 0.48 0.48 °C/W Parameter Thermal characteristics Thermal resistance, junctioncase Oct. 2018 RΘJC http://www.diodemodule.com/silicon_products/modules/mbrh120200r.pdf 1 MBRH120150 thru MBRH120200R Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh120200r.pdf 2 MBRH120150 thru MBRH120200R Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh120200r.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: MBRH120200R
MBRH120200R 价格&库存
很抱歉,暂时无法提供与“MBRH120200R”相匹配的价格&库存,您可以联系我们找货
MBRH120200R
    • 1+944.35200
    • 216+376.80120
    • 504+364.21920
    • 1008+357.98760
