MBRH20030
MBRH20030
    GENESICSEMICONDUCTOR
    D67
MBRH20030 数据手册
MBRH20020 thru MBRH20040R Silicon Power Schottky Diode VRRM = 20 V - 40 V IF(AV) = 200 A Features • High Surge Capability • Types from 20 V to 40 V VRRM D-67 Package • Not ESD Sensitive Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature Symbol Conditions MBRH20020(R) MBRH20030(R) MBRH20035(R) MBRH20040(R) Unit VRRM 20 30 35 40 V VRMS 14 21 25 28 V VDC Tj Tstg 20 -55 to 150 -55 to 150 30 -55 to 150 -55 to 150 35 -55 to 150 -55 to 150 40 -55 to 150 -55 to 150 V °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Symbol Conditions Average forward current (per pkg) IF(AV) TC = 125 °C 200 200 200 200 A Peak forward surge current IFSM tp = 8.3 ms, half sine 3000 3000 3000 3000 A Maximum instantaneous forward voltage VF IFM = 200 A, Tj = 25 °C 0.70 0.70 0.70 0.70 V Maximum instantaneous reverse current at rated DC blocking voltage IR Tj = 25 °C Tj = 100 °C Tj = 150 °C 1 10 50 1 10 50 1 10 50 1 10 50 mA 0.35 0.35 0.35 0.35 °C/W Parameter MBRH20020(R) MBRH20030(R) MBRH20035(R) MBRH20040(R) Unit Thermal characteristics Thermal resistance, junctioncase Oct. 2018 RΘJC http://www.diodemodule.com/silicon_products/modules/mbrh20030.pdf 1 MBRH20020 thru MBRH20040R Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh20030.pdf 2 MBRH20020 thru MBRH20040R Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh20030.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: MBRH20030
MBRH20030 价格&库存
很抱歉,暂时无法提供与“MBRH20030”相匹配的价格&库存,您可以联系我们找货
