S150MR
S150MR
    GENESICSEMICONDUCTOR
    DO-205AA
S150MR 数据手册
S150J thru S150QR Silicon Standard Recovery Diode VRRM = 600 V - 1200 V IF =150 A Features • High Surge Capability • Types from 600 V to 1200 V VRRM DO-8 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S150J (R) S150K (R) S150M (R) S150Q (R) Unit VRRM 600 800 1000 1200 V VRMS 420 560 700 840 V 1200 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage VDC Conditions 600 800 1000 Continuous forward current IF TC ≤ 180 °C 150 150 150 150 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 3140 3140 3140 3140 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S150J (R) S150K (R) S150M (R) S150Q (R) Unit IF = 150 A, Tj = 25 °C VR = 600 V, Tj = 25 °C VR = 600 V, Tj = 150 °C 1.2 10 15 1.2 10 15 1.2 10 15 1.2 10 9 μA mA 0.35 0.35 0.35 0.35 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s150mr.pdf 1 S150J thru S150QR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s150mr.pdf 2 S150J thru S150QR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO-8 (DO-205AA) H I F A C D B A C Stud Stud (R) G C E A Inches Min Millimeters Max A Oct. 2018 Min Max 3/8-24 UNF B ----- φ0.930 ----- φ23.5 C 1.050 1.060 26.67 26.92 D 4.300 4.700 109.22 119.38 E ----- 0.690 ----- 17.00 F 0.260 ----- 6.50 ----- G ----- 0.940 ----- 24.00 H ----- 0.600 ----- 15.23 I 0.276 0.286 7.010 7.260 http://www.diodemodule.com/silicon_products/studs/s150mr.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S150MR
S150MR 价格&库存
很抱歉,暂时无法提供与“S150MR”相匹配的价格&库存,您可以联系我们找货
S150MR
  • 50+321.9315050+41.70324
