MBRH200150R
MBRH200150R
    GENESICSEMICONDUCTOR
    D67
MBRH200150R 数据手册
MBRH200150 thru MBRH200200R Silicon Power Schottky Diode VRRM = 150 V - 200 V IF(AV) = 200 A Features • High Surge Capability • Types from 150 V to 200 V VRRM D-67 Package • Not ESD Sensitive Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature MBRH200150(R) MBRH200200(R) Unit VRRM 150 200 V VRMS 106 141 V VDC Tj Tstg 150 -55 to 150 -55 to 150 150 -55 to 150 -55 to 150 V °C °C Symbol Conditions Electrical characteristics, at Tj = 25 °C, unless otherwise specified Symbol Conditions MBRH200150(R) MBRH200200(R) Unit Average forward current (per pkg) IF(AV) TC = 125 °C 200 200 A Peak forward surge current IFSM tp = 8.3 ms, half sine 3000 3000 A Maximum instantaneous forward voltage VF IFM = 200 A, Tj = 25 °C 0.88 0.92 V Maximum instantaneous reverse current at rated DC blocking voltage IR Tj = 25 °C Tj = 100 °C Tj = 150 °C 1 10 50 1 10 50 mA 0.35 0.35 °C/W Parameter Thermal characteristics Thermal resistance, junctioncase Oct. 2018 RΘJC http://www.diodemodule.com/silicon_products/modules/mbrh200150r.pdf 1 MBRH200150 thru MBRH200200R Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh200150r.pdf 2 MBRH200150 thru MBRH200200R Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Oct. 2018 http://www.diodemodule.com/silicon_products/modules/mbrh200150r.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: MBRH200150R
MBRH200150R
1. 物料型号:MBRH200150至MBRH200200R系列。 2. 器件简介:这些是硅功率肖特基二极管,具有高浪涌能力,不敏感于静电放电(ESD),电压等级从150V到200V。 3. 引脚分配:文档中提到了共阴极和共阳极的引脚配置,以及基板的配置。 4. 参数特性: - 重复峰值反向电压(VRRM):150V至200V。 - 有效值反向电压(VRMS):106V至141V。 - 直流阻断电压(VDc):150V。 - 工作温度范围:-55°C至150°C。 - 存储温度范围:-55°C至150°C。 5. 功能详解:文档提供了正向特性曲线、正向降额曲线、峰值正向浪涌电流和典型反向特性的图表。 6. 应用信息:虽然文档没有明确列出应用信息,但这些二极管适用于高功率应用,如电源转换、电机驱动等。 7. 封装信息:提供了D-67封装的尺寸和端子配置。
MBRH200150R 价格&库存
很抱歉,暂时无法提供与“MBRH200150R”相匹配的价格&库存,您可以联系我们找货
MBRH200150R
    • 1+1101.91320
    • 216+439.66800
    • 504+424.98000
    • 1008+417.72240
