180NQ045-1
180NQ045-1
    SMCDIODESOLUTIONS(桑德斯)
    HALF-PAK
180NQ045-1 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1171, Rev. - 180NQ...-1 SERIES Green Products 180NQ...-1 SERIES SCHOTTKY RECTIFIER Applications: ● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection Features: • • • • • • • • • • • 150℃ TJ operation Unique high power, Half-Pak module Replaces three parallel DO-5’S Easier to mount and lower profile than DO-5’S High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Very low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In Inches / mm PRM1-1(HALF PAK Module) MARKING,MOLDING RESIN st nd Marking for180NQ035-1, 1 row SS YYWWL, 2 row 180NQ035-1 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 180NQ...-1 SERIES Technical Data Data Sheet N1171, Rev. - Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Max. Average Forward Current Symbol VRRM VRWM VR IF(AV) Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy Condition - Max. 35(180NQ035) 40(180NQ040) 45(180NQ045) 180 50% duty cycle @TC =90°C, rectangular wave form Units V A IFSM 8.3 ms, half Sine pulse 3480 A EAS TJ=25℃,IAS=36A,L=0.37mH Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5×VR typical 243 mJ 36 A Repetitive Avalanche Current IAR Electrical Characteristics: Characteristics Max. Forward Voltage Drop(per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change IR1 IR2 CT LS dv/dt Condition @ 180A, Pulse, TJ = 25 °C @ 360A, Pulse, TJ = 25 °C @ 180A, Pulse, TJ = 125 °C @ 360A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Condition - Max. 0.60 0.78 0.56 0.75 15 600 Units V V mA mA 7700 pF 6.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C *Pulse Width < 300µs, Duty Cycle
180NQ045-1 价格&库存
很抱歉,暂时无法提供与“180NQ045-1”相匹配的价格&库存,您可以联系我们找货
