182NQ030-1
182NQ030-1
    SMCDIODESOLUTIONS(桑德斯)
    HALF-PAK
182NQ030-1 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1173, Rev. - 182NQ030-1 Green Products 182NQ030-1 SCHOTTKY RECTIFIER Applications: ● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection Features: • • • • • • • • • • • 150℃ TJ operation Unique high power, Half-Pak module Replaces three parallel DO-5’S Easier to mount and lower profile than DO-5’S High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Very low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In Inches / mm PRM1-1(HALF PAK Module) MARKING,MOLDING RESIN st nd Marking for182NQ030-1, 1 row SS YYWWL, 2 row 182NQ030-1 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 182NQ030-1 Technical Data Data Sheet N1173, Rev. - Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Max. Average Forward Current Symbol VRRM VRWM VR IF(AV) Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy Condition - Max. 30 Units V 50% duty cycle @TC =107°C, rectangular wave form 180 A IFSM 8.3 ms, half Sine pulse 4140 A EAS TJ=25℃,IAS=36A,L=0.25mH Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 162 mJ 36 A Repetitive Avalanche Current IAR Electrical Characteristics: Characteristics Max. Forward Voltage Drop(per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change IR1 IR2 CT LS dv/dt Condition @ 180A, Pulse, TJ = 25 °C @ 360A, Pulse, TJ = 25 °C @ 180A, Pulse, TJ = 125 °C @ 360A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Condition - Max. 0.51 0.61 0.41 0.54 15 840 Units V V mA mA 7700 pF 6.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C *Pulse Width < 300µs, Duty Cycle
182NQ030-1 价格&库存
很抱歉,暂时无法提供与“182NQ030-1”相匹配的价格&库存,您可以联系我们找货
182NQ030-1
  • 594+250.65923594+32.46914
