S320KR
S320KR
    GENESICSEMICONDUCTOR
    DO-205AB
S320KR 数据手册
S320J thru S320QR Silicon Standard Recovery Diode VRRM = 600 V - 1200 V IF = 320 A Features • High Surge Capability • Types from 600 V to 1200 V VRRM DO-9 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. C A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S320J (R) S320K (R) S320M (R) S320Q (R) Unit VRRM 600 800 1000 1200 V VRMS 420 566 707 848 V 1200 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage VDC Conditions 600 800 1000 Continuous forward current IF TC ≤ 100 °C 320 320 320 320 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 4700 4700 4700 4700 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR Conditions S320J (R) S320K (R) S320M (R) S320Q (R) Unit IF = 300 A, Tj = 25 °C VR = 600 V, Tj = 25 °C VR = 600 V, Tj = 175 °C 1.2 10 12 1.2 10 12 1.2 10 12 1.2 10 12 μA mA 0.16 0.16 0.16 0.16 °C/W V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s320kr.pdf 1 S320J thru S320QR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s320kr.pdf 2 S320J thru S320QR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO-9 (DO--205AB) 9(DO205AB) H I F A C B D A C Stud Stud (R) G C E A Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s320kr.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S320KR
S320KR
1. 物料型号:S320J (R), S320K (R), S320Q (R), S320M (R), S320J 至 S320QR。 2. 器件简介:文档描述了一种硅标准恢复二极管,具有高浪涌能力,封装在DO-9包中。 3. 引脚分配:文档中提到了两种引脚配置,标准极性和反向极性。在标准极性中,螺柱是阴极,在反向极性中,螺柱是阳极。 4. 参数特性: - 重复峰值反向电压 (VRRM):600V 至 1200V。 - 有效值反向电压 (VRRMS):420V 至 566V。 - 直流阻断电压 (VDC):600V 至 800V。 - 连续正向电流 (IF):320A。 - 工作温度 (Tj):-55°C 至 150°C。 - 存储温度 (Tstg):-55°C 至 150°C。 - 热特性:结到外壳的热阻 (RthJC):0.16°C/W。 5. 功能详解:文档提供了二极管正向电压和反向电流的参数,以及在特定条件下的浪涌非重复正向电流。 6. 应用信息:文档提到了器件的高浪涌能力,适用于需要高电流和高电压的应用。 7. 封装信息:器件封装在DO-9 (DO-205AB) 包中,文档还提供了产品标记和端子配置信息。
S320KR 价格&库存
很抱歉,暂时无法提供与“S320KR”相匹配的价格&库存,您可以联系我们找货
S320KR
  • 40+563.5742240+72.80940
