220CNQ025
220CNQ025
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
220CNQ025 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1194, Rev. B 220CNQ025 Green Products 220CNQ025 SCHOTTKY RECTIFIER Applications: ● Parallel switching power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● Redundant power subsystems Features: • • • • • • • • • 150℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 220CNQ025, 1 row SS YYWWL, 2 row 220CNQ025 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 220CNQ025 Technical Data Data Sheet N1194, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Max. Average Forward IF(AV) Condition 50% duty cycle @TC =74°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 2850 A Condition @ 110A, Pulse, TJ = 25 °C @ 110A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.48 0.40 Units V V 10 mA 560 mA 7400 pF 7.0 nH 10,000 V/μs Condition - Specification -55 to +150 -55 to +150 Units °C °C 110 220 Max. 25 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current at DC condition Max. Reverse Current Max. Junction Capacitance Typical Series Inductance (per leg) Max. Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Pulse Width < 300µs, Duty Cycle
220CNQ025
物料型号:220CNQ025
器件简介:该器件是一款肖特基整流器,适用于并联开关电源、自由轮二极管、反向电池保护、转换器和冗余电源子系统。
引脚分配:文档中提供了机械尺寸和引脚布局,例如3 1/4-20 SLOTTED HEX ANODE和CATHOD。
参数特性:包括最大反向电压、最大平均正向电流、最大正向电压降、最大反向电流、最大结电容、典型串联电感和最大电压变化率。
功能详解:文档详细描述了器件的电气特性和热机械规格,如最大结温、最大存储温度、最大热阻和安装扭矩。
应用信息:适用于高频率操作,具有低正向电压降和高纯度、耐高温的环氧树脂封装,增强了机械强度和防潮性。
封装信息:封装类型为PRM4(非隔离型),重量约为79克。
免责声明:文档包含了一些法律声明,涉及产品规格的更改、高可靠性应用的安全措施、公司对任何损害的责任限制、最大额定值的遵守、版权和专利信息,以及产品出口的法律合规性。
公司联系信息:提供了公司的地址、电话、传真、网站和电子邮件地址。
220CNQ025 价格&库存
很抱歉,暂时无法提供与“220CNQ025”相匹配的价格&库存,您可以联系我们找货
