RMCW0612FT1R00
RMCW0612FT1R00
    SEI
    贴片电阻 1206 1Ω ±1% 3/4W ±400ppm/℃
RMCW0612FT1R00 数据手册
RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • Small size and light weight Reliability and high quality Wider terminations provide higher power handling and more robust thermal performance Qualified to AEC-Q200 RoHS compliant, lead free and halogen free REACH compliant Electrical Specifications Type/Code Power Rating (W) @ 70°C RMCW0612 0.75 RMCW1020 1 RMCW1218 1 RMCW1225 2 RMCW2030 3 Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) 200 400 TCR (ppm/ºC) ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 Ohmic Range (Ω) and Tolerance(2) 1%, 5% 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M (1) Lesser of √ P*R or maximum working voltage (2) E96 resistance values may be available in 1% tolerance but will be subject to a high MOQ's - contact Stackpole Electrical Specifications – RMCW-HP Type/Code Power Rating (W) @ 70°C RMCW0612_-HP 1.5 RMCW1020_-HP 2 RMCW1218_-HP 2 RMCW1225_-HP 3 Maximum Working Voltage (V)(1) Maximum Overload Voltage (V) TCR (ppm/ºC) 200 400 ±100 Ohmic Range (Ω) and Tolerance 1%, 5% (2) 1 - 9.1 10 - 10M (1) Lesser of √ P*R or maximum working voltage (2) E96 resistance values may be available in 1% tolerance but will be subject to a high MOQ's - contact Stackpole Electrical Specifications - Jumper Type/Code Jumper Rated Current (A) RMCW0612 RMCW1020 RMCW1218 RMCW1225 RMCW2030 4 6 6 8 10 Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Maximum Overload Current (A) < 1 second and 1 time 15 22 22 30 35 1 Jumper Resistance Value 0.02 max. www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications L Type/Code RMCW0612 RMCW1020 RMCW1218 RMCW1225 RMCW1225_-HP RMCW2030 0.063 1.60 0.098 2.50 0.122 3.10 0.126 3.20 0.126 3.20 0.201 5.10 ± ± ± ± ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.004 0.10 0.008 0.20 0.008 0.20 0.004 0.10 0.126 3.20 0.197 5.00 0.181 4.60 0.256 6.50 0.256 6.50 0.299 7.60 ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.004 0.10 0.008 0.20 0.008 0.20 0.004 0.10 0.022 0.55 0.022 0.55 0.022 0.55 0.022 0.55 0.026 0.65 0.047 1.20 ± ± ± ± ± ± ± ± ± ± ± ± I1 0.004 0.10 0.004 0.10 0.002 0.05 0.008 0.20 0.008 0.20 0.004 0.10 0.012 0.30 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.031 0.80 ± ± ± ± ± ± ± ± ± ± ± ± I2 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.020 0.50 0.030 0.75 0.020 0.50 0.030 0.75 0.030 0.75 0.031 0.80 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Item Temperature Coefficient of Resistance Short Time Overload Leaching Resistance to Soldering Heat Rapid Change of Temperature Resistance to Solvent Test Method Test Specification 1% 5% JIS-C-5201-1 4.8 Within the specified tolerance IEC-60115-1 4.8 ± (1% + 0.05Ω) JIS-C-5201-1 4.13 IEC-60115-1 4.13 JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 JIS-C-5201-1 4.18 IEC-60115-1 4.18 JIS-C-5201-1 4.19 IEC-60115-1 4.19 JIS-C-5201-1 4.29 ± (2% + 0.1Ω) JIS-C-5201-1 4.24 IEC-60115-1 4.24 JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 Individual leaching area ≤ 5% Total leaching area ≤ 10% 260 ± 5°C for 30 seconds ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) 260 ± 5°C for 10 seconds ± (0.5% + 0.05Ω) ± (1% + 0.1Ω) -55°C to +155°C, 5 cycles ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) The tested resistor should be immersed into isopropyl alcohol of 20 ~ 25°C for 60 seconds. Then the resistor is left in room temperature for 48 hours ± (1% + 0.05Ω) ± (2% + 0.05Ω) ± (1% + 0.05Ω) ± (3% + 0.1Ω) Jumper: max 0.02 Ω after test JIS-C-5201-1 4.6 IEC-60115-1 4.6 JIS-C-5201-1 4.33 Bending Strength IEC-60115-1 4.33 Operating temperature range is -55°C to 155°C 6.25 times rated power or max. overload voltage whichever is less for 5 seconds, except for high power (-HP). For high power (-HP): 5 times rated power or max. overload voltage whichever is less for 5 seconds Jumper: overload current for 5 seconds 0612=10A, 1020=15A, 1218=15A, 1225=20A, 2030=25A Jumper: max 0.02 Ω after test Load Life (Endurance) At 25 / -55°C and 25°C / +155°C, 25°C is the reference temperature Jumper: max 0.02 Ω after test Jumper: max 0.02 Ω after test Damp Heat with Load Test Condition Insulation Resistance ≥ 10 GΩ ± (1% + 0.05Ω) Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± (1% + 0.05Ω) 2 40 ± 2°C, 90 ~ 95% R.H. RCWV or Max. Working voltage whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" 70 ± 2°C, RCWV or Max. Working voltage whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" Apply 100 VDC for 1 minute Bending once for 5 seconds. D: 0612, 1020, 1218, 1225, 2030 = 2 mm www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Power Derating Curve: Surface Temperature vs. Power Rating 1. 2. 3. 4. Resistance value used for each size was at or near critical value. Used poor heat conduction PCB. Applied full power for 10 minutes prior to measurement. Data for reference only. Actual performance under customer conditions may vary. Recommended Pad Layouts Type/Code RMCW0612 RMCW1020 RMCW1218 RMCW1225 RMCW2030 A 0.024 0.60 0.030 0.75 0.080 2.04 0.033 0.85 0.138 3.50 Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. B 0.114 2.90 0.134 3.40 0.167 4.24 0.146 3.70 0.295 7.50 3 C 0.126 3.20 0.197 5.00 0.189 4.80 0.252 6.40 0.307 7.80 Unit inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Recommended Customer Soldering Parameters Wave Solder Temperature Condition Solder Reflow Temperature Condition Rework temperature (hot air equipment): 350°C, 3 ~ 5 seconds Recommended reflow methods: • IR, vapor phase oven, hot air oven • If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Reel Specifications Type / Code Size RMCW0612 Reel Quantity A B C D W M Unit 5000 0.079 ± 0.020 2.00 ± 0.50 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 0.453 ± 0.079 7.008 ± 0.079 11.50 ± 2.00 178.00 ± 2.00 inches mm 4000 0.079 ± 0.020 2.00 ± 0.50 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 0.630 ± 0.079 7.008 ± 0.079 16.00 ± 2.00 178.00 ± 2.00 inches mm 1000 0.079 ± 0.020 2.00 ± 0.50 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 0.748 ± 0.079 7.008 ± 0.079 19.00 ± 2.00 178.00 ± 2.00 inches mm RMCW1020 RMCW1218 7" RMCW1225 RMCW2030 Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications – Paper Tape Type/Code A B W RMCW0612 0.075 ± 0.008 1.90 ± 0.20 G 0.157 ± 0.004 4.00 ± 0.10 0.138 ± 0.008 3.50 ± 0.20 H 0.079 ± 0.002 2.00 ± 0.05 0.315 ± 0.008 8.00 ± 0.20 T 0.030 ± 0.004 0.75 ± 0.10 E 0.069 ± 0.004 1.75 ± 0.10 D 0.059 +0.004 / -0 1.50 +0.10 / -0 F Unit 0.138 ± 0.002 3.50 ± 0.05 P 0.157 ± 0.004 4.00 ± 0.10 inches mm Unit inches mm Packaging Specifications – Embossed Tape Type/Code A B W E F G Unit RMCW1020 0.110 ± 0.008 2.80 ± 0.20 0.220 ± 0.008 5.60 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW1225 0.134 ± 0.008 3.40 ± 0.20 0.264 ± 0.008 6.70 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW1225_-HP 0.134 ± 0.008 3.40 ± 0.20 0.264 ± 0.008 6.70 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW1218 0.130 ± 0.008 3.30 ± 0.20 0.181 ± 0.008 4.60 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW2030 0.217 ± 0.008 5.50 ± 0.20 0.311 ± 0.008 7.90 ± 0.20 0.630 ± 0.004 16.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.295 ± 0.002 7.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm Type/Code H T RMCW1020 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 RMCW1225 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 RMCW1225_-HP 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 RMCW1218 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 RMCW2030 0.079 ± 0.002 2.00 ± 0.05 0.010 ± 0.004 0.25 ± 0.10 Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. D 0.059 +0.004 / -0 1.50 +0.10 / -0 0.059 +0.004 / -0 1.50 +0.10 / -0 0.059 +0.004 / -0 1.50 +0.10 / -0 0.059 +0.004 / -0 1.50 +0.10 / -0 0.059 +0.004 / -0 1.50 +0.10 / -0 5 D1 T1 P Unit 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.039 ± 0.006 1.00 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.051 ± 0.004 1.30 ± 0.10 0.315 ± 0.008 8.00 ± 0.20 inches mm www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Peel Force of Top Cover Tape Top adhesive peel off strength: 10~70g RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Wide Termination Thick Film Chip SMD Resistors Note (1): RoHS compliant by means of exemption 7c-I RMCW Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 R M C W 0 6 1 2 J T 1 0 R 0 - H P Product Series Wide RMCW Termination Thick Film Size and W Code Std -HP 0612 0.75 1.5 1020 1 2 1218 1 2 2 3 1225 2030 3 NA Tolerance Code Tol Value(*) F 1% E24 J 5% Z Jumper Packaging Code Description Size Quantity 0612 5000 7" Reel T 1020, 1218, 1225 4000 Paper Tape 2030 1000 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 100 ohm = 100R 10 Kohm = 10K0 10 Mohm = 10M0 Special Code Description blank Standard -HP High Power (*) E96 resistance values may be available in 1% tolerance but will be subject to high MOQ's. Contact Stackpole. Rev Date: 2/16/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com
RMCW0612FT1R00 价格&库存
很抱歉,暂时无法提供与“RMCW0612FT1R00”相匹配的价格&库存,您可以联系我们找货
