PTVSHC3N7VU
PTVSHC3N7VU
    PRISEMI(上海芯导电子)
    DFN-3(2x2)
    TVS二极管 VRWM=7V VBR(Min)=8V VC=19V IPP=200A Ppp=4.3KW DFN3L_2X2MM
PTVSHC3N7VU 数据手册
PTVSHC3N7VU Transient Voltage Suppressor Description The PTVSHC3N7VU ESD protector is designed to replace multilayer varistors (MLVs) in portable applications such as cell phones, notebook computers, and PDA’s. They feature 1、2 large cross-sectional area junctions for conducting high transient currents, offer desirable 3 electrical characteristics for board level protection, such as fast response time, lower operating voltage, lower clamping voltage and no device degradation when compared to MLVs. The PTVSHC3N7VU protects sensitive semiconductor components from damage or upset due to electrostatic discharge (ESD) and other voltage induced transient events. The 1 3 2 Top View PTVSHC3N7VU is available in a DFN2×2-3L package with working voltages of 7 volt. It is used to meet the ESD immunity requirements of IEC 61000-4-2 (±30kV air, ±30kV contact discharge) Feature Applications  4300W Peak pulse power per line (tP = 8/20μs)  Cell phone handsets and accessories  DFN2×2-3L package  Personal digital assistants (PDA’s)  Response time is typically < 1 ns  Notebooks, desktops, and servers  Protect one I/O or power line  Portable instrumentation  Low clamping Voltage  Cordless phones  RoHS compliant  Digital cameras  Transient protection for data lines to IEC 61000-4-2(ESD)  Peripherals ±30KV(air), ±30KV(contact); IEC 61000-4-4 (EFT) 80A (5/50ns)  MP3 players IEC 61000-4-5 (Lightning) 260A (8/20us) Mechanical Characteristics  Lead finish:100% matte Sn(Tin)  Mounting position: Any  Qualified max reflow temperature:260℃  Pure tin plating: 7 ~ 17 um  Pin flatness:≤3mil Rev.06.7 1 www.prisemi.com Transient Voltage Suppressor PTVSHC3N7VU Electronics Parameter I IF Symbol Parameter VRWM Peak Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF V VC VBR VRWM IR VF IT IPP Electrical characteristics per line@25℃( unless otherwise specified) Parameter Symbol Conditions Min. Typ. Peak Reverse Working Voltage VRWM Breakdown Voltage VBR It =1mA Reverse Leakage Current IR VRWM =7V Maximum Reverse Peak Pulse Current IPP Clamping Voltage VC IPP=20A tP = 8/20μs 9.5 11 V Clamping Voltage VC IPP=80A tP = 8/20μs 11 13 V Clamping Voltage VC IPP=200A tP = 8/20μs 15 19 V Junction Capacitance Cj 1700 1900 pF 8 9 Max. Units 7 V 10 V 1 μA 260 VR=0V f = 1MHz A Notes :Measured from pin 3 to pin 1 and pin 2. Absolute maximum rating@25℃ Rating Symbol Value Units Peak Pulse Power ( tP = 8/20μS ) Ppp 4300 W Lead Soldering Temperature TL 260 (10 sec) ℃ Operating Temperature TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Storage Temperature Rev.06.7 2 www.prisemi.com Transient Voltage Suppressor PTVSHC3N7VU tf=8μs 100 100 80 % Of Rated Power IPP – Peak Pulse Current - % of IPP Typical Characteristics 60 tP =20μs(IPP /2) 40 80 60 40 20 20 0 0 0 5 10 15 20 25 0 30 25 50 75 100 125 150 TL – Lead Temperature - ℃ t - Time -μs Fig 1.Pulse Waveform Fig 2.Power Derating Curve 2000 2000 18 1800 Pulse waveform: tp=8/20us 16 f=1MHz C-Junction capacitance (pF) VC-Clamping Voltage (V) 1600 1600 12 8 4 1400 1200 1200 1000 系列1 800 800 600 400 400 200 0 0 50 100 150 200 250 00 300 IPP-Peak pulse current (A) Fig 3. Clamping voltage vs. Peak pulse current 0 2 0 2 4 6 4 voltage (V) 6 VR-Reverse Fig 4. Capacitance vs. Reveres voltage Peak Pulse Power (W) 10000 1000 100 10 1 10 100 Pulse Duration(us) 1000 Fig 5. Non Repetitive Peak Pulse Power vs. Pulse time Rev.06.7 3 www.prisemi.com 8 8 Transient Voltage Suppressor PTVSHC3N7VU Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 30 60 90 120 150 180 240 210 270 300 330 360 390 420 450 480 Time (sec) PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Rev.06.7 4 www.prisemi.com Transient Voltage Suppressor PTVSHC3N7VU Product dimension (DFN2×2-3L) J F F 1 2 D H B G K I E C L F 3 A Bottom View Millimeters Dim MIN MAX A 1.90 2.10 B 1.90 2.10 C 1.40 1.60 D 0.90 E 1.10 1.30BSC F 0.25 0.35 G 0.95 1.05 H 0.20 0.30 I 0.35 0.45 J 0.65 K 0.30 0.35 L 0.15 0.20 1.3 1.05 0.5 0.4 1.1 0.25 0.4 1.6 Unit:mm Recommended Soldering Pad Ordering information Rev.06.7 Device Package Shipping PTVSHC3N7VU DFN2×2-3L (Pb-Free) 3000 / Tape & Reel 5 www.prisemi.com Transient Voltage Suppressor PTVSHC3N7VU IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.7 6 www.prisemi.com
PTVSHC3N7VU 价格&库存
很抱歉,暂时无法提供与“PTVSHC3N7VU”相匹配的价格&库存,您可以联系我们找货
PTVSHC3N7VU
  • 10+0.49846
  • 100+0.41233
  • 600+0.36927
  • 1200+0.36373
  • 3000+0.32799
库存:2369
