MM3Z16BW
MM3Z16BW
    JSMSEMI(杰盛微)
    SOD-323
    SMT型齐纳二极管
MM3Z16BW 数据手册
MM3Z2V0BW- MM3Z75BW SMT-Type Zener Diode FEATURES Large selection of zener voltages: 2V ~ 75V Tight voltage tolerance: ±2% for B-series Ultra low-profile package well suited for automated assembly MSL Class 1 compatible to r • • • • APPLICATIONS uc General voltage regulation Mobile & handheld systems ORDERING INFORMATION Marking MM3Z2V0BW - MM3Z75BW See Page 2 co Part Number nd • • Package mi SOD-323 Parameter Se MAXIMUM RATING (@ TA = 25°C unless otherwise specified) Symbol Value Unit VF 0.9 V PD 400 mW RθJA 313 °C/W Junction Temperature Range TJ -55 ~ +150 °C Storage Temperature Range TSTG -65 ~ +150 °C Forward Voltage @ IF=10mA CR O Power Dissipation JS MI Thermal Resistance (Junction-to-Ambient) Note: Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint www.jsmsemi.com 第1/4页 MM3Z2V0BW- MM3Z75BW SMT-Type Zener Diode Zener Voltage Range Type Marking VZT( at IZT ) Min( V ) Nom( V ) Dynamic Impedance IZT Max( V ) Reverse Current ZZT( at IZT ) IR at VR (mA) Max (Ω) Max( μA ) (V) B0 1 .96 2.0 2 .04 5 100 120 0.5 MM3Z2V2BW C0 2 . 16 2.2 2 .24 5 100 120 0.7 MM3Z2V4BW 1C 2 .35 2 .4 2 .45 5 100 120 1 MM3Z2V7BW 1D 2 .65 2.7 2 .75 5 110 120 1 MM3Z3V0BW 1E 2 .94 3.0 3 .06 5 120 50 1 MM3Z3V3BW 1F 3 .23 3.3 3 .37 5 130 20 1 MM3Z3V6BW 1H 3 .53 3.6 3 .67 5 130 10 1 MM3Z3V9BW 1J 3 .82 3.9 3 .98 5 130 5 1 MM3Z4V3BW 1K 4 .21 4.3 4 .39 5 130 MM3Z4V7BW 1M 4 .61 4.7 4 .79 5 130 MM3Z5V1BW 1N 5 5.1 5.2 5 MM3Z5V6BW 1P 5 .49 5.6 5 .71 5 MM3Z6V2BW 1R 6 .08 6.2 6 .32 5 MM3Z6V8BW 1X 6 .66 6.8 6 .94 5 MM3Z7V5BW 1Y 7 .35 7.5 7 .65 5 MM3Z8V2BW 1Z 8 .04 8.2 8 .36 MM3Z9V1BW 2A 8 .92 9.1 9 .28 MM3Z10BW 2B 9.8 10 MM3Z11BW 2C 10 .78 11 MM3Z12BW 2D 11 .76 12 MM3Z13BW 2E 12 .74 13 MM3Z15BW 2F 14 .7 MM3Z16BW 2H 15 .68 MM3Z18BW 2J MM3Z20BW 2K MM3Z22BW 2M MM3Z24BW 2N MM3Z27BW 2P MM3Z30BW 2R MM3Z33BW 2X MM3Z36BW 2Y MM3Z39BW 2Z MM3Z43BW MM3Z47BW to r MM3Z2V0BW 1 1 130 2 1.5 80 1 2.5 50 1 3 30 0.5 3.5 30 0.5 4 5 0.5 5 5 30 0.5 6 5 30 0.1 7 11 .22 5 30 0.1 8 12 .24 5 35 0.1 9 13 .26 5 35 0.1 10 15 15 .3 5 40 0.1 11 16 16 .32 5 40 0.1 12 17 .64 18 18 .36 5 45 0.1 13 Se mi 30 10 .2 co nd uc 5 2 20 20 .4 5 50 0.1 15 22 22 .44 5 55 0.1 17 23 .52 24 24 .48 5 60 0.1 19 26 .46 27 27 .54 2 70 0.1 21 29 .4 30 30 .60 2 80 0.1 23 32 .34 33 33 .66 2 80 0.1 25 35 .28 36 36 .72 2 90 0.1 27 38 .22 39 39 .78 2 100 0.1 30 3A 42 . 14 43 43 .86 2 130 0.1 33 3B 46 .06 47 47 .94 2 150 0.1 36 MM3Z51BW 3C 49 .98 51 52 .02 2 180 0.1 39 MM3Z56BW 3D 54 .88 56 57 . 12 2 200 0.1 43 MM3Z62BW 3E 60 .76 62 63 .24 2 215 0.1 47 MM3Z68BW 3F 66 .64 68 69 .36 2 240 0.1 52 MM3Z75BW 3H 73 .5 75 76 .5 2 265 0.1 56 JS MI CR O 19 .6 21 .56 ( 1 ) VZT is tested with pulses (20 ms) www.jsmsemi.com 第2/4页 MM3Z2V0BW- MM3Z75BW SMT-Type Zener Diode (@ TA = 25°C unless otherwise specified) JS MI CR O Se mi co nd uc to r TYPICAL CHARACTERISTICS 0.020 0.015 0.010 0.100 IZ = 5m A 0.080 0.060 IZ = 50μA 0.005 0.040 0.000 TC of VZ(%°/C) 0.020 -0.010 0.000 -0.005 -0.015 -0.020 -0.020 10 20 30 40 50 60 70 80 VZ , ZENER VOLTAGE(V) (V ) V O L T A G E Z , V Z E N E R Fig. 5 Typical Temperature Coefficient of Zener Voltage 0246810 Fig. 6 Typical Temperature Coefficient of Zener Voltage www.jsmsemi.com 第3/4页 MM3Z2V0BW- MM3Z75BW SMT-Type Zener Diode PACKAGE OUTLINE (Unit: mm) Plastic surface mounted package K C SOD-323 Dimension Min. Max. A 1.60 1.80 B 1.20 1.40 0.80 0.90 0.25 0.35 0.22 0.42 B D to r A C D E E H J J CR O 0.10 0.05 0.15 2.55 2.75 0.63 Se mi MOUNTING PAD LAYOUT (Unit: mm) JS MI 0.02 co nd K uc H 0.83 1.60 2.85 PACKAGE INFORMATION Part Number MM3Z2V0BW – MM3Z75BW Package Shipping Quantity SOD-323 3000pcs / Tape & Reel www.jsmsemi.com 第4/4页
MM3Z16BW 价格&库存
很抱歉,暂时无法提供与“MM3Z16BW”相匹配的价格&库存,您可以联系我们找货
