SMB46 Mounting Brackets
Datasheet
Stainless steel mounting brackets for Banner Sensors
Rugged stainless steel mounting brackets available in three styles:
◦ Basic right angle L-bracket
◦ S-bracket offering lens protection
◦ U-shaped hat bracket offering protections for all sides of
sensor
Mounting hole pattern accommodates the following sensors:
◦ MINI-BEAM®
◦ PicoDot™
◦ Q14
◦ Q23
◦ QH23
◦ QM42
Hardware List
The hardware packet (included) contains two each of the following for all SMB46 brackets:
For sensor mounting:
M3 × 0.5 × 20 mm screw
M3 × 0.5 hex nut
M3 flat washer
M3 split lock washer
For bracket mounting:
M6 × 1.0 × 12 mm screw
M6 × 1.0 hex nut
M6 flat washer
M6 split lock washer
Brackets
All measurements are listed in millimeters, unless noted otherwise.
SMB46L
Right-angle
L bracket
14-ga. 316 stainless steel
SMB46S
Right-angle
S bracket
54
65
Hole center spacing: A = 16.0
65
16
54
Hole size: A = 16.5 × 18.7
Hole size: A = 16.5 × 18.7, B = 34.0 ×
10.0
A
27
Part Number: 48747
SMB46U
Right-angle
U bracket for sensor
protection
27
A
B
Part Number: 48748
70
B
54
13.0
A
65
Part Number: 48746
Original Document
48749 Rev. A
13 May 2019
48749
Mounting Options
Figure 1. PicoDot™ Mounting Options
Figure 2. Q23 Mounting Options
Figure 3. QM42 Mounting Options
Figure 4. QH23 Mounting Options
Figure 5. MINI-BEAM® Mounting Options
Figure 6. Q14 Mounting Options
Banner Engineering Corp Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the
date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time
it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or
liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED
(INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE),
AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT
SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS,
EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM
ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR
WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any
obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or
improper application or installation of this product or use of the product for personal protection applications when the product is
identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express
approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to
change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and
product information in English supersede that which is provided in any other language. For the most recent version of any
documentation, refer to: www.bannerengineering.com.
For patent information, see www.bannerengineering.com/patents.
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“SMB46L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+323.435011+41.96543
