SR1206FR-7W33RL
SR1206FR-7W33RL
    YAGEO(国巨)
    贴片电阻 1206 33Ω ±1% 1/2W ±200ppm/℃
SR1206FR-7W33RL 数据手册
DATA SHEET AUTOMOTIVE GRADE SURGE CHIP RESISTORS SR series 1%, 0.5% sizes 0402/0603/0805/1206/1210/1218/2010/2512 Product specification – August 9, 2021 V.5 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SR 0402/0603/0805/1206/1210/1218/2010/2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes SR0402 to SR2512 chip resistors with lead-free terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. 2 9 GLOBAL PART NUMBER SR XXXX X X X XX XXXX L APPLICATIONS ⚫ Telecommunications ⚫ Power supplies ⚫ Car electronics FEATURES ⚫ AEC-Q200 qualified ⚫ Superior to RC series in pulse withstanding voltage and surge withstanding voltage. ⚫ MSL class: MSL 1 ⚫ Halogen free epoxy ⚫ RoHS compliant - - Products with lead-free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS ⚫ Reduce environmentally hazardous waste ⚫ High component and equipment reliability (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D = ± 0.5% F = ± 1% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 7T = 7 inch dia. Reel & 3 x standard power 47 = 7 inch dia. Reel & 4 x standard power (6) RESISTANCE VALUE 1 Ω ≤ R ≤ 1M Ω There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6= 97,600 Ω XXXK (100 KΩ) O RDERING EXAMPLE The ordering code for an SR0805 chip resistor, value 10 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: SR0805FR-0710KL. 100K = 100,000 Ω www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 3 9 MARKING SR0402 No Marking ynsc007 Fig. 1 SR1218 YNSC099-1 Fig. 2 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512 03 Fig. 3 YNSC001 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Table 1 TAPING REEL & POWER POWER, W (P70) TYPE CODING 07 7W 7T 47 0402 1/16 1/8 1/5 - 0603 1/10 1/5 1/4 - 0805 1/8 1/4 1/3 1/2 1206 1210 1/4 1/2 3/4 1 1/2 1 - - 1218 1 1.5 - - 2010 3/4 1.25 - - 2512 1 2 - - www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount SR SERIES 4 9 0402/0603/0805/1206/1210/1218/2010/2512 CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead -free glass. The composition of the glaze is adjusted to give the approximately required resistance value. The whole element is cove red by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external terminations (Ni/matte tin) are added, as shown in Fig.5. OUTLINES SR0402/0603/0805/1206/1210/1218/2010 SR2512 marking layer marking layer overcoat overcoat protective glass protective glass resistive layer resistive layer inner electrode termination (Ni/matte tin) inner electrode inner electrode termination (Ni/matte tin) inner electrode YNSC095-1 ceramic substrate YNSC095 resistive layer protective glass overcoat Fig. 5-1 Fig. 5-2 Chip resistor outlines Chip resistor outlines DIMENSIONS Table 2 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) SR0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 SR0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 SR0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 SR1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 SR1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.55± 0.15 0.50± 0.20 SR2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.50± 0.20 SR0402 For dimension, please refer to Table 1 SR0603/0805/1206/ 1210/2010/2512 I1 SR1218 Side view for all type I1 I1 W W Fig. 5 Chip resistor dimensions H W I2 L L L YNSC096_1 www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 5 9 ELECTRICAL CHARACTERISTICS Table 3 TYPE POWER RESISTANCE RANGE Operating Temperature Range CHARACTERISTICS Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage Temperature Coefficient of Resistance 1/16W SR0402 1/8W 50 V 100 V 100 V 75V 150V 150V 150V 300V 300V 1/5W 1/10W SR0603 1/5W 1/4W 1/8 W SR0805 1/4W 1/3W 10Ω < R ≤ 1MΩ 1/2W 1/4 W SR1206 1/2W ± 100 ppm/°C E24/E96 0.5%, 1% 1 Ω ≤ R ≤ 1M Ω –55 °C to +155 °C 200 V 3/4W 400 V 500 V ± 200 ppm/°C 1W SR1210 SR1218 SR2010 1/2W 1W 1W 1.5W 3/4W 1.25W 1W SR2512 1Ω ≤ R ≤ 10Ω 2W 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 4 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION SR0402 SR0603/0805/1206 SR1210 SR1218/2010/2512 7" (178 mm) 10,000 5,000 5,000 --- 13" (330 mm) 50,000 20,000 20,000 --- 7" (178 mm) --- --- --- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE PT040 2 Aug. 09, 2021 V.5 PT060 100 mΩ to 910 mΩ ± 200 ppm/°C ± 200 ppm/°C www.yageo.com Product specification Chip Resistor Surface Mount SR SERIES FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE Range: –55 °C to +155 °C 6 9 MRA632 Pmax (%Prated) POWER RATING 100 Each type rated power at 70 °C: SR0402: 1/16W, 1/8W, 1/5W SR0603: 1/10W, 1/5W, 1/4W SR0805: 1/8W, 1/4W, 1/3W, 1/2W SR1206: 1/4W, 1/2W, 3/4W, 1W SR1210: 1/2W, 1W SR1218: 1W, 1.5W SR2010: 3/4W, 1.25W SR2512: 1W, 2W R ATED VOLTAGE 0402/0603/0805/1206/1210/1218/2010/2512 50 0 55 0 50 70 100 155 Tamb ( C) Fig. 6 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb) The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (P X R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) PULSE LOAD BEHAVIOR Fig. 7 Pulse-Load behavior www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 7 9 TESTS AND REQUIREMENTS Table 5 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS High Temperature Exposure AEC-Q200 Test 3 1,000 hours at TA = 155 °C, unpowered ± (2.0%+0.05Ω) Moisture Resistance AEC-Q200 Test 6 Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (0.5%+0.05Ω) Biased Humidity AEC-Q200 Test 7 1,000 hours; 85 °C / 85% RH 10% of operating power ± (1.0%+0.05Ω) MIL-STD-202 Method 108 MIL-STD-202 Method 106 MIL-STD-202 Method 103 Measurement at 24± 4 hours after test conclusion. Operational Life Resistance to Soldering Heat AEC-Q200 Test 8 ± (2.0%+0.05Ω) MIL-STD-202 Method 108 1,000 hours at 125 °C, derated voltage applied for 1.5 hours on, 0.5 hour off, still-air required AEC-Q200 Test 15 Condition B, no pre-heat of samples ± (1%+0.05Ω) MIL-STD-202 Method 210 Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol Thermal Shock AEC-Q200 Test 16 -55/+125 °C MIL-STD-202 Method 107 Number of cycles is 300. Devices mounted ± (0.5%+0.05Ω) Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ESD AEC-Q200 Test 17 Human Body Model, AEC-Q200-002 1 pos. + 1 neg. discharges ± (3.0%+0.05Ω) 0201: 500V 0402/0603: 1KV 0805 and above: 2KV www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount TEST Solderability - Wetting SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 TEST METHOD PROCEDURE AEC-Q200 Test 18 Electrical Test not required Magnification 50X J-STD-002 SMD conditions: 8 9 REQUIREMENTS Well tinned (≥95% covered) No visible damage (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 30± 0.5 seconds. Board Flex AEC-Q200 Test 21 AEC-Q200-005 Chips mounted on a 90mm glass epoxy resin PCB (FR4) ± (1.0%+0.05Ω) Bending for 0201/0402: 5 mm 0603/0805: 3 mm 1206 and above: 2 mm Holding time: minimum 60 seconds Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------× 106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (2.0%+0.05Ω) www.yageo.com Aug. 09, 2021 V.5 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 9 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 5 Aug. 09, 2021 - - Upgrade to Automotive Grade Version 4 Jul. 22, 2019 - - Update power rating - Extend resistance range of 0402 ~ 2512 to 1Mohm Version 3 Sep. 27, 2018 - - Tighten TCR of all sizes for for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ± 100 ppm/°C - Add SR1210, SR1218, SR2010 7W (double power) - Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512 7W (double power) Version 2 Oct. 02, 2017 - Version 1 Nov. 11, 2016 - - Update 7T power for 1206 Version 0 Dec. 01, 2015 - - New product datasheet “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products are unchanged. Any product change will be announced by PCN.” "The reimbursement is limited to the value of the products." www.yageo.com Aug. 09, 2021 V.5
SR1206FR-7W33RL
- 物料型号:SR系列,尺寸包括0402、0603、0805、1206、1210、1218、2010和2512。 - 器件简介:这些电阻器采用无铅端接,通过厚膜工艺制造,符合AEC-Q200标准,具有优越的脉冲和浪涌电压承受能力。 - 引脚分配:文档中没有明确说明引脚分配,但通常贴片电阻器有两端用于连接电路。 - 参数特性:电阻值范围1Ω至1MΩ,公差为±0.5%或±1%,采用E-24系列编码。产品符合RoHS标准,无卤素环氧树脂。 - 功能详解:电阻器构建在高级陶瓷基板上,内部金属电极通过电阻性釉料连接,覆盖无铅玻璃,调整釉料组成以获得所需的电阻值。 - 应用信息:适用于通信、电源和汽车电子等领域。 - 封装信息:提供多种尺寸和包装类型,包括纸带卷装和压花带卷装,不同尺寸的电阻器有不同的功率容量。
SR1206FR-7W33RL 价格&库存
很抱歉,暂时无法提供与“SR1206FR-7W33RL”相匹配的价格&库存,您可以联系我们找货
SR1206FR-7W33RL
  • 5000+1.613695000+0.20877
  • 10000+1.5632910000+0.20225
  • 15000+1.5387115000+0.19907
  • 25000+1.5120525000+0.19562
  • 35000+1.4967735000+0.19365
  • 50000+1.4823350000+0.19178
库存:2922
SR1206FR-7W33RL
  • 1+1.32570
  • 100+0.98370
  • 1000+0.70270
  • 2500+0.52160
  • 5000+0.37150
库存:10120
SR1206FR-7W33RL
  • 1+5.913511+0.76505
  • 10+3.4862010+0.45102
  • 25+2.9516325+0.38186
  • 50+2.6446450+0.34215
  • 100+2.39924100+0.31040
  • 250+2.15098250+0.27828
  • 500+2.00748500+0.25972
  • 1000+1.893431000+0.24496
库存:2922
SR1206FR-7W33RL
    • 5000+0.345895000+0.04475
    库存:10000
    SR1206FR-7W33RL
      • 5000+0.23094
      库存:10000
      SR1206FR-7W33RL
      • 1+0.44880
      • 500+0.29920
      • 2500+0.25960
      • 5000+0.23650
      库存:7799
      SR1206FR-7W33RL
        • 5000+0.20183
        库存:45000
        SR1206FR-7W33RL
          库存:5000
