High power thin film chip resistors
(short side terminal)
■HRG series
AEC-Q200 Compliant
Features
・ Wider bottom terminal enabling higher power capability (short side terminal)
・ Significantly larger power handling capability than existing same size resistors
Thin film surface mount resistors
Size: 3216, Power rating: 1.0W, Resistance range: 10 ~ 100KΩ
・ Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/°C
・ Thin film structure enabling low noise and anti-sulfur
Applications
・ Power source related devises
・ DC motors, inverters
HRG series
・ Robotics, Industrial control system
◆Part numbering system
HRG 3216
P - 1001 - B - T5
Packaging quantity:
T1(1,000pcs), T5(5,000pcs)
Series code
Resistance tolerance
Temperature coefficient of resistance
Nominal resistance value (E-24, E-96: all 4 digit)
◆Electrical Specification
Temperature
coefficient
of resistance
Power
ratings
Type
Resistance range(Ω)
(ppm/°C)
±0.1% (B)
±25(P)
Resistance
value series
Operating
temperature
200V
E-24, E-96
-55℃ ~ 155℃
47≦R≦100k
±50(Q)
Packaging
quantity
±0.5% (D)
1.0W
HRG3216
Maximum
voltage
47≦R≦100k
10≦R≦100k
T1
T5
◆Dimensions
L
a
a
Type
W
t
b
29
b
HRG3216
Size
(inch)
1206
L
W
a
b
t
3.20±0.20
1.60±0.20
0.50±0.25
1.10±0.20
0.45±0.10
(unit:mm)
◆Reliability specification
Standard
≦47Ω
≧47Ω
Test items
Condition (test methods (JIS C5201-1)
Life (biased)
70℃, rated voltage,* 1 90min on 30min off, 1000hours
High temperature high humidity
85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours
±(0.25%+0.05Ω) ±(0.1%+0.01Ω)
Temperature shock
-55℃ (30min) ∼ 125℃ (30min) 1000cycles
High temperature exposure
155℃, no bias, 1000hours
Resistance to soldering heat
260±5℃, 10 seconds (reflow)
Rated voltage is given by E= R x P
E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W)
If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage.
◆Reliability test data
○High temperature high humidity (biased)
0.12
0.08
0.06
0.12
0.10
Load Life @ 70℃ at
Rated Power 1.0W n = 4
0.04
0.02
0.00
-0.02
-0.04
-0.06
HRG3216:10kΩ
-0.08
Resistance drift(%)
Resistance drift(%)
0.10
-0.10
-0.12
0.08
0.06
0.02
0.00
-0.02
-0.04
-0.06
Test duration(h)
0.12
0.10
Thermal Shock
-55℃ - +125℃ n = 25
0.02
0.00
-0.02
-0.04
-0.06
HRG3216:10kΩ
-0.08
Resistance drift(%)
Resistance drift(%)
10 100 1000 10000
○High temperature exposure
0.04
0.08
0.06
High Temperature Exposure
at 155℃ with no power n = 25
0.04
0.02
0.00
-0.02
-0.04
-0.06
HRG3216:10kΩ
-0.08
-0.10
-0.10
-0.12
HRG3216:10kΩ
-0.08
-0.12
10 100 1000 10000
0.12
0.06
0.1W n = 25
-0.10
○Temperature shock
0.08
Temperature Humidity Bias
0.04
Test duration(h)
0.10
HRG series
○Biased life test
10 100 1000 10000
Test duration(h)
-0.12
10 100 1000 10000
Test duration(h)
Ratio to rated power (%)
◆Derating Curve
100
50
*1
±(0.5%+0.05Ω) ±(0.25%+0.01Ω)
0 50 70 100 155
Ambient temperature (℃)
30
很抱歉,暂时无法提供与“HRG3216P-75R0-B-T1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+3.478801000+0.43290
- 国内价格 香港价格
- 1000+4.237001000+0.52725
- 2000+4.147802000+0.51615
- 3000+4.128333000+0.51373
- 4000+4.103204000+0.51060
- 国内价格 香港价格
- 1+7.507051+0.93418
- 10+6.2256210+0.77472
- 25+5.7715725+0.71821
- 50+5.4574050+0.67912
- 100+5.16588100+0.64284
- 250+4.82045250+0.59986
- 500+4.58787500+0.57092
- 国内价格 香港价格
- 1000+4.686061000+0.58313
- 2000+4.487542000+0.55843
- 3000+4.382163000+0.54532
- 5000+4.259945000+0.53011
- 7000+4.185557000+0.52085
- 10000+4.1117110000+0.51166
- 12000+4.0758712000+0.50720
