PLVA2650A,215
PLVA2650A,215
    NEXPERIA(安世)
    SOT-23
    DIODE ZENER DUAL 5V TO236AB
PLVA2650A,215 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET dbook, halfpage M3D088 PLVA2600A series Low-voltage avalanche regulator double diodes Product data sheet Supersedes data of 1999 May 10 2001 Oct 15 NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes FEATURES PLVA2600A series MARKING • Very low dynamic impedance at low currents: approximately 1⁄20 of conventional series MARKING CODE(1) TYPE NUMBER PLVA2650A ∗9J • Hard breakdown knee PLVA2653A ∗9K • Low noise: approximately 1⁄10 of conventional series PLVA2656A ∗9L PLVA2659A ∗9M • Total power dissipation: max. 250 mW PLVA2662A ∗9N PLVA2665A ∗9O • Small tolerances of VZ PLVA2668A ∗9P • Working voltage range: nom. 5.0 to 6.8 V • Non-repetitive peak reverse power dissipation: max. 30 W. APPLICATIONS • Low current, low power, low noise applications Note 1. ∗ = p : Made in Hong Kong. ∗ = t : Made in Malaysia. ∗ = W: Made in China. PINNING PIN DESCRIPTION 1 cathode (k1) • CMOS RAM back-up circuits 2 cathode (k2) • Voltage stabilizers 3 common anode • Voltage limiters • Smoke detector relays. 2 1 DESCRIPTION The PLVA2600A series consists of two high performance voltage regulator diodes with common anodes, in small SOT23 plastic SMD packages. The series consists of PLVA2650A to PLVA2668A. 2 1 3 3 Top view MAM245 Fig.1 Simplified outline (SOT23) and symbol. 2001 Oct 15 2 NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes PLVA2600A series LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT − 250 mA tp = 100 μs; δ = 10% − 250 mA non-repetitive peak reverse power dissipation tp = 100 μs; Tj = 150 °C − 30 W total power dissipation single diode loaded; Tamb = 25 °C; note 1 − 250 mW double diode loaded; Tamb = 25 °C; note 1 − 180 mW IF continuous forward current IZRM repetitive peak working current PZSM Ptot Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Note 1. Device mounted on an FR4 printed circuit-board. 2001 Oct 15 3 NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes PLVA2600A series ELECTRICAL CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL PARAMETER CONDITIONS V PLVA2650A 4.80 5.00 5.20 V PLVA2653A 5.10 5.30 5.50 V PLVA2656A 5.40 5.60 5.80 V PLVA2659A 5.70 5.90 6.10 V PLVA2662A 6.00 6.20 6.40 V PLVA2665A 6.30 6.50 6.70 V PLVA2668A 6.60 6.80 7.00 V PLVA2650A − 4.30 − V PLVA2653A − 5.20 − V PLVA2656A − 5.51 − V PLVA2659A − 5.85 − V PLVA2662A − 6.19 − V PLVA2665A − 6.49 − V − 6.80 − V − − 700 Ω PLVA2653A − − 250 Ω PLVA2656A to PLVA2668A − − 100 Ω PLVA2650A − 0.20 − mV/K PLVA2653A − 1.60 − mV/K PLVA2656A − 1.90 − mV/K PLVA2659A − 2.40 − mV/K PLVA2662A − 2.65 − mV/K PLVA2665A − 2.90 − mV/K PLVA2668A − 3.40 − mV/K PLVA2650A − − 20 000 nA PLVA2653A − − 5 000 nA PLVA2656A − − 1 000 nA PLVA2659A − − 500 nA PLVA2662A − − 100 nA PLVA2665A − − 50 nA PLVA2668A − − 10 nA IZ = 250 μA working voltage IZ = 10 μA PLVA2668A dynamic resistance PLVA2650A 2001 Oct 15 UNIT 0.9 IF = 10 mA working voltage IR MAX. − forward voltage VZ SZ TYP. − VF RZ MIN. temperature coefficient reverse current 1 kHz superimposed; IZAC is 10% of IZDC; IZ = 250 μA IZ = 250 μA VR = 80%; VZ nominal 4 NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes SYMBOL IR PARAMETER reverse current Vn CONDITIONS MIN. TYP. MAX. UNIT VR = 50%; VZ nominal PLVA2650A − 34 − nA PLVA2653A − 22 − nA PLVA2656A − 1.1 − nA PLVA2659A − 0.9 − nA PLVA2662A − 0.9 − nA PLVA2665A − 0.9 − nA PLVA2668A − 0.8 − nA PLVA2650A − 21 − μA PLVA2653A − 3.5 − μA PLVA2656A − 1.3 − μA PLVA2659A − 1.0 − μA PLVA2662A − 0.05 − μA PLVA2665A − 0.04 − μA PLVA2668A − 0.006 − μA PLVA2659A to PLVA2668A ILO = 10 μA; IHi = 1 mA − − 0.1 V PLVA2656A ILO = 50 μA; IHi = 1 mA − − 0.1 V PLVA2650A ILO = 100 μA; IHi = 1 mA − − 0.4 V PLVA2653A ILO = 100 μA; IHi = 1 mA − − 0.2 V f = 1 kHz; B = 1 kHz; IZ = 250 μA − − 1.0 μV -----------Hz reverse current ΔVZ PLVA2600A series VR = 90%; VZ nominal line regulation noise voltage density THERMAL CHARACTERISTICS SYMBOL PARAMETER Rth j-tp thermal resistance from junction to tie-point Rth j-a thermal resistance from junction to ambient CONDITIONS note 1 Note 1. Device mounted on an FR4 printed circuit-board. 2001 Oct 15 5 VALUE UNIT 360 K/W 500 K/W NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes PLVA2600A series PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 2001 Oct 15 REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 97-02-28 99-09-13 TO-236AB 6 NXP Semiconductors Product data sheet Low-voltage avalanche regulator double diodes PLVA2600A series DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DISCLAIMERS above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 2001 Oct 15 7 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613514/04/pp8 Date of release: 2001 Oct 15 Document order number: 9397 750 08768
PLVA2650A,215 价格&库存
很抱歉,暂时无法提供与“PLVA2650A,215”相匹配的价格&库存,您可以联系我们找货
