E60067
E60067
    IFM(易福门)
    FLEXIBLE COUPLING FOR ENCODERS
E60067 数据手册
E60067 Flexible coupling for encoders COUPLING 25-10-10-32-KV Mechanical data Weight [g] Dimensions [mm] Materials 32.9 Ø 25 / L = 32 aluminium External diameter D [mm] 25 Inside diameter A1 [mm] 10 Inside diameter A2 [mm] 10 Length L [mm] 32 Depth of the clamping hub [mm] 8 Clamp screw [mm] M3 Max. revolution, mechanical [U/min] 6000 Max. axial shaft misalignment [mm] ± 0,5 Max. radial shaft misalignment [mm] ± 0,35 [°] ± 4,0 Max. angular displacement Remarks Remarks Pack quantity The data indicated apply to couplings with the above hub borings at an ambient temperature of 23 °C. The values of radial, angular and axial displacement are maximum values which must not reach their maximum simultaneously while in operation. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — E60067-00 — 15.06.2022 —
E60067 价格&库存
很抱歉,暂时无法提供与“E60067”相匹配的价格&库存,您可以联系我们找货
E60067
  • 1+690.18747
库存:8
