CS10FTFTR191
CS10FTFTR191
    VIKING(光颉)
    贴片电阻 2010 191mΩ ±1% 1W ±200ppm/℃
CS10FTFTR191 数据手册
Data Sheet Customer: Product: Current Sensing Chip Resistor – CS Series Size: 0201/0402/0603/0805/1206/1210/2010/2512 1225/3720/7520/0612 Issued Date: 15-Jun-22 Edition: REV.E2 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 15-Jun-22 15-Jun-22 15-Jun-22 Alice Hsiao Susan Huang Susan Huang Prepared by (Sales) Accepted by (Customer) 【CS Series】 Current Sensing Chip Resistor Current Sensing Chip Resistor ■Features -3 Watts power rating in 1 Watt size, 1225 package -Low TCR of ±100 PPM/°C -Resistance values from 1m to 1 ohm -High purity alumina substrate for high power dissipation -Long side terminations with higher power rating -RoHS Compliance ■Construction ■Applications -Power Management Applications L -Switching Power Supply -Over Current Protection in Audio Applications D1 -Voltage Regulation Module (VRM) -DC-DC Converter, Battery Pack, Charger, Adaptor w     T -Disk Driver      D2  Alumina Substrate  Bottom Electrode  Top Electrode Edge Electrode Barrier Layer External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat ■Dimensions Type Size (Inch) L (mm) W (mm) T (mm) D1 (mm) D2 (mm) Weight(g) (1000pcs) CS01 0201 0.60±0.03 0.30±0.03 0.23±0.05 0.12±0.05 0.15±0.05 0.18 CS02 0402 1.00±0.05 0.50±0.05 0.32±0.10 0.25±0.10 0.20±0.10 0.7 CS03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 1.99 CS05 0805 2.00±0.10 1.25±0.10 0.55±0.10 0.30±0.20 0.40±0.25 5.3 CS06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.30 0.40±0.25 8.82 CS06 (1W) 1206 (102 - 1000mΩ) 3.15±0.10 1.60±0.15 0.65±0.10 0.80±0.20 0.80±0.20 12.15 CS13 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.30 0.50±0.25 15.5 CS10 2010 5.00±0.10 2.50±0.15 0.60±0.15 0.60±0.30 0.50±0.25 27.03 CS12 CS12 (2W) CS12 (2W) 2512 2512 (10 - 99mΩ) 2512 (100 - 1000mΩ) 6.35±0.10 3.10±0.15 0.60±0.10 0.60±0.30 0.55±0.25 43.08 6.35±0.20 3.15±0.15 0.74±0.10 0.60±0.30 0.55±0.25 53.08 6.35±0.20 3.15±0.15 0.74±0.10 0.60±0.30 2.10±0.10 53.08 CS25 1225 3.20±0.15 6.45±0.15 0.90±0.15 0.60±0.30 0.80±0.25 64.88 CS37 3720 2.00±0.20 3.75±0.20 0.60±0.10 0.40±0.20 0.40±0.20 19.96 CS75 7520 2.00±0.20 7.50±0.30 0.60±0.10 0.40±0.20 0.40±0.20 35.71 CS62 0612 1.55±0.10 3.10±0.15 0.55±0.10 0.30±0.15 0.45±0.15 10.19 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor ■Part Numbering Part Number:CS06FTFR100 Part Number:CS06FTETR200N ( CS06 1W No Marking ) CS 06 T Product Type Dimensions (L×W) Resistance Tolerance 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 13: 1210 10: 2010 12: 2512 25: 1225 37: 3720 75: 7520 62: 0612 F: ±1% G: ±2% J: ±5% F G Packaging Code TCR (PPM/C) T: Taping Reel B: Bulk E: ±100 F: ±200 G: ±300 H: ±400 J: ±600 K: ±150 R: ±1000 ■Recommend Land Pattern U R100 Power Rating : Standard S: 2W A: 1.5W T: 1W Q: 3/4W U: 1/2W V: 1/4W P: 1/5W W: 1/8W Resistance Marking R010: 0.01Ω R100: 0.1Ω 1R00: 1Ω : Standard N: No Marking ■Derating Curve 100 90 Power ratio(%) 80 C 70 60 50 40 30 20 B A 10 0 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 160 Ambient Temperature(℃) Pad Layout (Except For CS12:Ultra High Power Rating Series) Type A (mm) B (mm) C (mm) CS01 0.25 0.30 0.40±0.2 CS02 0.50 0.50 0.60±0.2 CS03 0.80 1.00 0.90±0.2 Type CS05 1.00 1.00 1.35±0.2 CS06 CS06 (1W) CS13 2.00 1.15 1.70±0.2 0.90 1.70 1.70±0.2 2.00 1.15 2.50±0.2 CS10 3.60 1.40 2.50±0.2 CS12 4.90 1.60 3.20±0.2 CS25 1.20 2.00 7.00±0.2 CS37 1.00 1.80 3.90±0.2 CS75 1.00 1.80 7.60±0.2 CS62 0.60 1.00 3.20±0.2 www.viking.com.tw Pad Layout ( For CS12: Ultra High Power Rating Series) Resistance Range A (mm) CS12 10~99 mΩ CS12 100~1000mΩ For detail questions, contact:sales@viking.com.tw 3 B (mm) C (mm) 4.9 1.6 3.2±0.2 1.0 3.55 3.2±0.2 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor ■Soldering Condition (Ref. IPC/JEDEC J-STD-020 & J-STD-002) Reflow Profiles Profile Feature Pb-Free Assembly Preheat Min. Temperature (Tsmin) Max Temperature (Tsmax) Preheating time (ts) from (Tsmin to Tsmax) 150 °C 200 °C 60-120 seconds Ramp-up rate (TL to Tp) 3 °C/second max. Liquidous temperature (TL) Time (tL) maintained above TL 217 °C 60-150 seconds Min. Peak temperature (Tp min) 235°C Max. Peak temperature (Tp max) 260°C Time (tp) within 5 °C of the specified classification temperature (Tc) 30 seconds max. Ramp-down rate (Tp to TL) 6 °C/second max. Time 25 °C to peak temperature 8 minutes max. www.viking.com.tw For detail questions, contact:sales@viking.com.tw 4 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor ■Standard Electrical Specifications Item Resistance Range (mΩ) Power Rating at 70°C Operating Temp. Range Max. Operating Current CS01 (0201) 1/20W -55 ~ +155C 0.70A 100 - 147 150 - 500 510 - 1000 ±1000 ±600 ±300 CS02 (0402) 1/16W -55 ~ +155C 1.11A 50 - 100 102 - 500 510 - 1000 ±400 ±300 ±200 2.23A 20 - 50 51 - 100 102 - 300 301 - 1000 ±600 ±400 ±300 ±200 2.50A 20 - 50 51 - 100 102 -196 200 - 1000 ±600 ±400 ±300 ±200 10 - 20 21 - 50 51 - 91 100 - 1000 ±600 ±400 ±300 ±200 ±300 ±200 ±150 ±100 ±300 ±150 Type CS03 (0603) 1/10W -55 ~ +155C CS05 (0805) 1/8W CS06 (1206) 1/4W 5.00A CS13 (1210) 1/2W 7.07A CS10 (2010) 3/4W CS12 (2512) 1W -55 ~ +155C -55 ~ +155C ±1% 8.66A 10.0A ±2% ±5% CS25 (1225) 3W -55 ~ +155C 31.6A 3-5 6 - 20 21 - 30 33 - 8000 CS37 (3720) 1W -55 ~ +155C 10.0A 10 - 18 20 - 500 - CS75 (7520) 2W -55 ~ +155C 44.7A CS62 (0612) 1W -55 ~ +155C 10.0A 1-4 TCR (PPM/°C) ±300 5 - 10 11 - 350 10 - 27 30 - 91 100 – 499 500 - 1000 ±200 ±150 ±600 ±300 ±200 ±100 ■High Power & Ultra High Power Rating Electrical Specifications Item Type CS02 (0402) CS03 (0603) CS05 (0805) Power Rating at 70°C Operating Temp. Range 1/8W 1/8W 1/5W 1/4W 1/2W Max. Operating Current ±1% ±2% TCR (PPM/°C) ±5% 1.56A -55 ~ +155C 1.98A 51 - 100 102 - 500 510 - 1000 ±400 ±300 ±200 10 - 20 21 - 50 51 - 91 100 - 1000 ±600 ±400 ±300 ±200 102-1000 ±100 2.21A CS06 (1206) 1/2W 7.07A CS13 (1210) 3/4W 8.66A CS10 (2010) 1W CS12 (2512) 1.5W 12.2A CS12 (2512) *2W 14.1A -55 ~ +155C 10.0A CS06 (1206) *1W -55 ~ +155C 3.13A *: Ultra High Power ■CS06 1W: double side printed resistor element without marking. www.viking.com.tw Resistance Range (mΩ) For detail questions, contact:sales@viking.com.tw 5 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor ■Low TCR Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Range Max. Operating Current Resistance Range (mΩ) ±1% ±2% TCR (PPM/°C) ±5% CS05 (0805) 1/8W 1.11A 100 - 1000 ±100 CS06 (1206) 1/4W 1.58A 100 - 1000 ±100 CS13 (1210) 1/2W 2.58A 75 - 1000 ±100 CS10 (2010) 3/4W 3.87A 50 - 1000 ±100 7.07A 20 - 1000 ±100 -55 ~ +155C CS12 (2512) 1W CS12 (2512) *2W 6.32A 50 - 1000 ±100 CS37 (3720) 1W 3.16A 100 - 500 ±100 CS75 (7520) 2W 6.32A 50 - 350 ±100 *: Ultra High Power Operating Current=√(P/R) ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. ■Environmental Characteristics Item Temperature Coefficient of Resistance (T.C.R.) Requirement Test Method JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS C 5201-1 4.13 IEC 60115-1 4.13 (0.5%+0.05Ω) Short Time Overload Insulation Resistance RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds CS06 1W: 5*rated power for 5 seconds (1.0%+0.05Ω) For High power rating JIS-C-5201-1 4.6 IEC-60115-1 4.6 ≧10G Max. Overload Voltage for 1 minute Endurance JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 (1.0%+0.05Ω) 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” (0.5%+0.05Ω) JIS-C-5201-1 4.24 IEC-60115-1 4.24 CS06 1W : (1.0%+0.05Ω) 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” (0.5%+0.05Ω) JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 CS06 1W : (1.0%+0.05Ω) at +155C for 1000 hrs Damp Heat with Load Dry Heat Bending Strength Solderability JIS-C-5201-1 4.33 IEC-60115-1 4.33 (1.0%+0.05Ω) Bending once for 60 seconds with 3mm 2010, 2512 sizes: 2mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 95% min. coverage 2455C for 3 seconds www.viking.com.tw For detail questions, contact:sales@viking.com.tw 6 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor Item Requirement Test Method (0.5%+0.05Ω) JIS-C-5201-1 4.18 IEC-60115-1 4.18 CS06 1W : (1.0%+0.05Ω) 2605C for 10 seconds Resistance to Soldering Heat JIS-C-5201-1 4.7 IEC-60115-1 4.7 Voltage Proof 1.42 times Max. Operating Voltage for 1 minute CS01:50V; CS02:100V; CS03:150V; CS05:300V CS06/13/10/25/37/75/62:400V; CS12:500V No breakdown or flashover JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Individual leaching area ≦5% Total leaching area ≦10% Leaching 2605C for 30 seconds (0.5%+0.05Ω) JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles Rapid Change of Temperature CS06 1W : (1.0%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH ■ Shelf Life: 2 years from production date. ▓Packaging Packaging Quantity & Reel Specifications Type ΦA (mm) ΦB (mm) ΦC (mm) W (mm) T (mm) Paper Tape (EA) Embossed Plastic Tape (EA) CS01 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 10,000 CS02 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 10,000 - CS03 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS05 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS06 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - CS13 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 CS10 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 CS12 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 4,000 CS12 (2W) 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS25 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS37 178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0 - 2,000 CS75 178.0±1.0 60.0+1.0 13.5±0.7 17.5±1.0 19.5±1.0 - 2,000 CS62 178.0±1.0 60.0+1.0 13.5±0.7 9.5±0.1 11.5±1.0 5,000 - www.viking.com.tw For detail questions, contact:sales@viking.com.tw 7 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor Paper Tape Specifications Top Tape Bottom Tape ψ D0 E A F B T P1 Resistor Paper Tape P2 P0 W direction of unreeling P2 (mm) ΦD0 (mm) Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) T (mm) CS01 0.38±0.05 0.68±0.05 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.42±0.20 CS02 0.65±0.10 1.15±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 CS03 1.10±0.10 1.90±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 CS05 1.60±0.10 2.40±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS06 1.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS13 2.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 CS62 1.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 Emboss Plastic Tape Specifications Top Tape ψ D0 E A F B W ψ D1 1.4Min. T P1 Resistor P2 P0 direction of unreeling Emboss Tape Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) ΦD0 (mm) T (mm) CS10 2.80±0.10 5.40±0.20 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 CS12 3.50±0.10 6.70±0.10 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.00±0.20 CS12 (2W) 3.38±0.10 6.68±0.10 12.0±0.30 1.75±0.10 5.50±0.10 4.00±0.10 4.00±0.10 2.00±0.05 1.55+0.05 1.45±0.20 CS25 3.38±0.10 6.68±0.10 12.0±0.30 1.75±0.10 5.50±0.10 4.00±0.10 4.00±0.10 2.00±0.05 1.55+0.05 1.45±0.20 CS37 2.50±0.20 4.45±0.20 12.0±0.30 1.75±0.10 5.50±0.05 4.00 ±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.20 ±0.20 CS75 2.50±0.20 8.30±0.20 16.0±0.30 1.75±0.10 7.80±0.05 4.00±0.05 4.00±0.10 2.00±0.05 1.50+0.10 1.20 ±0.20 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 8 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor ■Marking No Marking for 0201/0402/1206(1W). 1%, 5% for 0805/1206/1210/2010/2512/1225/3720/7520/0612 : 4 digits marking Example: Resistance Marking 47mΩ R047 75mΩ R075 15mΩ R015 750mΩ R750 820mΩ R820 5% for 0603: 3 digits marking in E24 1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series) R10 3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ 243 3 digits marking for E96: 243=243mΩ; 511=511mΩ www.viking.com.tw For detail questions, contact:sales@viking.com.tw 9 Edition: REV.E2 Revision: 15-Jun-2022 【CS Series】 Current Sensing Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version D1 Jun 03, 2014 - - Electrical Specifications updated - CS25 Pad Layout updated - Environmental Characteristics updated Version D2 Apr 30, 2015 - - Increase Product Size 0612 Version D3 Jul 15, 2016 - - Version D4 Jan 12, 2018 - - Modify 1225 Dimension L, W Version D5 Jul 27, 2018 - Version D6 May 20, 2019 - Version D7 Mar 23, 2020 - Version D8 Mar 10, 2021 - Version D9 Nov 15, 2021 - - Increase the shelf life description Version E Dec 21, 2021 - Version E1 Feb 15, 2022 - - Added 0805 1/2W high power production range - Derating Curve changes the temperature range Version E2 Jun 15, 2022 - www.viking.com.tw Remove Material Description Modify Storage Temperature CS12 Pad Layout updated CS62 Resistance Range updated - Increase 1206 1W Ultra High Power Electrical Specifications - Modify TCR Test description - Electrical Specifications updated - Environmental Characteristics : Added test voltage for Voltage Proof - Modify Bending Test description - Modify 2010 Embossed Plastic Tape B Specification - Modify Soldering Condition (IPC/JEDEC J-STD-020) - Modify Soldering Condition For detail questions, contact:sales@viking.com.tw 10 Edition: REV.E2 Revision: 15-Jun-2022
CS10FTFTR191 价格&库存
很抱歉,暂时无法提供与“CS10FTFTR191”相匹配的价格&库存,您可以联系我们找货
