TPH3206LS
TPH3206LS
    TRANSPHORM
    PowerDFN3
    TPH3206LS
TPH3206LS 数据手册
TPH3206LS Not recommended for new designs—see TPH3206LSB 600V Cascode GaN FET in PQFN88 (source tab) Description Features The TPH3206LS 600V, 150mΩ gallium nitride (GaN) FET is a normally-off device. Transphorm GaN FETs offer better efficiency through lower gate charge, faster switching speeds, and smaller reverse recovery charge, delivering significant advantages over traditional silicon (Si) devices. Transphorm is a leading-edge wide band gap supplier with world-class innovation and a portfolio of fully-qualified GaN transistors that enables increased performance and reduced overall system size and cost. Related Literature • AN0009: Recommended External Circuitry for GaN FETs • AN0003: Printed Circuit Board Layout and Probing • • • • • Easy to drive—compatible with standard gate drivers Low conduction and switching losses Low Qrr of 52nC—no free-wheeling diode required JEDEC-qualified GaN technology RoHS compliant and Halogen-free Benefits • • • • Increased efficiency through fast switching Increased power density Reduced system size and weight Enables more efficient topologies—easy to implement bridgeless totem-pole designs • Lower BOM cost Applications Ordering Information Package Package Configuration 8 x 8mm PQFN Common Source Part Number* TPH3206LS • • • • Renewable energy Industrial Telecom and datacom Servo motors * Add “-TR” suffix for tape and reel; see page 9 Key Specifications TPH3206LS 8x8 PQFN (bottom view) S D VDS (V) min 600 VTDS (V) max 750 RDS(on) (mΩ) max* 180 Qrr (nC) typ 52 Qg (nC) typ 6 * Dynamic R(on) G Cascode Device Structure April 6, 2017 tph3206ls.9 © 2017 Transphorm Inc. Subject to change without notice. 1 TPH3206LS Absolute Maximum Ratings (TC=25°C unless otherwise stated) Symbol Parameter ID25°C Continuous drain current @TC=25°C ID100°C Continuous drain current @TC=100°C a a Limit Value Unit 17 A 12 A IDM Pulsed drain current (pulse width: 100µs) 60 A VDSS Drain to source voltage 600 V VTDS Transient drain to source voltage b 750 V VGSS Gate to source voltage ±18 V Maximum power dissipation 96 W Case -55 to +150 °C Junction -55 to +175 °C -55 to +150 °C 260 °C Typical Unit 1.55 °C/W 45 °C/W PD25°C TC TJ TS TCSOLD Operating temperature Storage temperature Soldering peak temperature c Thermal Resistance Symbol Parameter RΘJC Junction-to-case RΘJA Junction-to-ambient d Notes: a. For high current operation, see application note AN0009 b. In off-state, spike duty cycle D
TPH3206LS 价格&库存
很抱歉,暂时无法提供与“TPH3206LS”相匹配的价格&库存,您可以联系我们找货
