PHK04P02T,518
PHK04P02T,518
    NEXPERIA(安世)
    SOT96-1
    MOSFET P-CH 16V 4.66A 8-SOIC
PHK04P02T,518 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PHK04P02T P-channel vertical D-MOS logic level FET Rev. 02 — 14 December 2010 Product data sheet 1. Product profile 1.1 General description Logic level P-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using vertical D-MOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Suitable for high frequency applications due to fast switching characteristics „ Suitable for logic level gate drive sources „ Suitable for very low gate drive sources voltage 1.3 Applications „ Battery powered applications „ High-speed digital interfaces 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - - -16 V ID drain current Tsp = 25 °C - - -4.6 6 A Ptot total power dissipation - - 5 W VGS = -2.5 V; ID = -1 A; Tj = 25 °C - 117 150 mΩ VGS = -4.5 V; ID = -1 A; Tj = 25 °C - 80 120 mΩ VGS = -4.5 V; ID = -1 A; VDS = -10 V; Tj = 25 °C - 1.83 - Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge nC PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source 2 S source 3 S source 4 G gate 5 D drain 6 D drain 7 D drain 8 D drain Simplified outline 8 Graphic symbol D 5 G 1 4 S SOT96-1 (SO8) 001aaa025 3. Ordering information Table 3. Ordering information Type number Package PHK04P02T Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - -16 V VDGR drain-gate voltage RGS = 20 kΩ - -16 V VGS gate-source voltage -8 8 V ID drain current Tsp = 100 °C - -1.87 A Tsp = 25 °C - -4.66 A IDM peak drain current Tsp = 25 °C; pulsed - -26.4 A Ptot total power dissipation Tsp = 25 °C - 5 W Tsp = 100 °C - 2 W Tstg storage temperature -55 150 °C Tj junction temperature -55 150 °C Source-drain diode IS source current Tsp = 25 °C - -4.66 A ISM peak source current Tsp = 25 °C; pulsed; tp ≤ 5 s - -26 A PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 2 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 001aam073 100 Ptot (%) 80 001aam074 120 ID (%) 80 60 40 40 20 0 0 0 40 80 120 160 0 40 Ta (°C) 80 120 160 Ta (°C) VGS ≤ -10 V Fig 1. Normalised power dissipation as a function of ambient temperature Fig 2. Normalized continuous drain current as a function of ambient temperature 001aam075 102 IDM (A) tp = 1 ms RDS(on) = VDS / ID 10 ms 10 100 ms 1 D.C. 10−1 10−2 10−1 1 102 10 VDS (V) Tsp = 25 °C; IDM is single pulse Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 3 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-sp) thermal resistance from junction to solder point mounted on metal clad substrate - 25 - K/W 102 Zth(j-sp) (K/W) 10 001aam076 D = 0.5 0.2 0.1 1 0.05 0.02 10−2 10−3 single pulse tp T t tp T 10−6 Fig 4. δ= P 10−1 10−5 10−4 10−3 10−2 10−1 1 10 tp (s) Transient thermal impedance from junction to solder point as a function of pulse duration PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 4 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = -10 µA; VGS = 0 V; Tj = 25 °C -16 - - V VGS(th) gate-source threshold voltage ID = -1 mA; VDS = VGS; Tj = 25 °C -0.4 -0.6 - V ID = -1 mA; VDS = VGS; Tj = 150 °C -0.1 - - V IDSS drain leakage current VDS = -13 V; VGS = 0 V; Tj = 25 °C - -50 -100 nA VDS = -13 V; VGS = 0 V; Tj = 150 °C - -13 -100 µA IGSS gate leakage current VGS = 8 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -8 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -2.5 V; ID = -1 A; Tj = 25 °C - 117 150 mΩ VGS = -2.5 V; ID = -1 A; Tj = 150 °C - 175 230 mΩ VGS = -1.8 V; ID = -0.5 A; Tj = 25 °C - 140 180 mΩ VGS = -4.5 V; ID = -1 A; Tj = 25 °C - 80 120 mΩ ID = -1 A; VDS = -10 V; VGS = -4.5 V; Tj = 25 °C - 7.2 - nC - 1.7 - nC - 1.83 - nC - 528 - pF - 200 - pF - 57 - pF - 2 - ns - 4.5 - ns RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 45 - ns tf fall time - 20 - ns gfs transfer conductance VDS = -13 V; ID = -1 A; Tj = 25 °C 1.5 4.5 - S VDS = -13 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C VDS = -10 V; RL = 10 Ω; VGS = -8 V; RG(ext) = 6 Ω; Tj = 25 °C; ID = -1 A Source-drain diode VSD source-drain voltage IS = -0.62 A; VGS = 0 V; Tj = 25 °C - -0.62 -1.3 V trr reverse recovery time - 75 - ns Qr recovered charge IS = -0.5 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = -12.8 V; Tj = 25 °C - 69 - nC PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 5 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 001aam077 −5 ID (A) −4 −4.5 −2.5 −1.8 −3 −1.3 0.5 −1.2 0.4 −1.1 0.3 −1.0 0.2 −0.9 VGS (V) = −0.8 0.1 −2 −1 0 0 −0.5 −1.0 −1.5 VDS (V) VGS (V) = −1.3 −1.8 −2.5 −4.5 0 −2.0 0 Tj = 25 °C Fig 5. 001aam078 0.7 RDS(on) −0.8 −1.0 −1.2 (Ω) 0.6 −0.9 −1.1 −1 −2 −3 −4 −5 ID (A) Tj = 25 °C Output characteristics: drain current as a function of drain-source voltage; typical values Fig 6. Drain-source on-state resistance as a function of drain current; typical values 001aam079 −5 ID (A) −4 Tj = 25 °C Tj = 150 °C 001aam080 8 gfs (S) Tj = 25 °C 6 Tj = 150 °C −3 4 −2 2 −1 0 0 −0.5 −1.0 −1.5 VGS (V) 0 −2.0 0 VDS > ID x RDSon Fig 7. −1.6 ID (A) −2.4 VDS > ID x RDSon Transfer characteristics: drain current as a function of gate-source voltage; typical values 001aam081 1.6 Fig 8. Forward transconductance as a function of drain current; typical values 001aam082 0.8 VGS(th) (V) a −2.5 V 1.4 −0.8 0.6 VGS = −4.5 V typical −1.8 V 1.2 0.4 minimum 1.0 0.2 0.8 0 0.6 0 50 100 150 0 50 100 150 Tj (°C) Tj (°C) ID = 1 mA; VDS = VGS Fig 9. Normalized drain-source on-state resistance factor as a function of junction temperature PHK04P02T Product data sheet Fig 10. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 6 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 001aam083 10−2 ID (A) 10−3 001aam084 103 Ciss C (pF) 10−4 Coss 102 10−5 Crss 10−6 10−7 −1.0 −0.8 −0.6 −0.4 −0.2 0 VGS (V) 10 −10−1 VDS = -5 V; Tj = 25 °C −1 −10 VDS (V) −102 VGS = 0 V; f = 1 MHz Fig 11. Sub-threshold drain current as a function of gate-source voltage Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 001aam085 −5 VGS (V) −4 001aam086 5 IF (A) 4 −3 3 −2 2 −1 1 Tj = 150 °C Tj = 25 °C 0 0 0 2 4 6 8 10 QG (nC) Tj = 25 °C; ID = -1 A Product data sheet 0.4 0.8 1.2 VSDS (V) VGS = 0 V Fig 13. Gate-source voltage as a function of turn-on gate charge; typical values PHK04P02T 0 Fig 14. Reverse diode current as a function of reverse diode voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 7 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 7. Package outline SO8: plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 D E A X c y HE v M A Z 5 8 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 5.0 4.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.014 0.0075 0.20 0.19 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 inches 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Notes 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT96-1 076E03 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Fig 15. Package outline SOT96-1 (SO8) PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 8 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHK04P02T v.2 20101214 Product data sheet - PHK04P02T v.1 Modifications: PHK04P02T v.1 PHK04P02T Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 20020501 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 - © NXP B.V. 2010. All rights reserved. 9 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 10 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. 10. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PHK04P02T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 14 December 2010 © NXP B.V. 2010. All rights reserved. 11 of 12 PHK04P02T NXP Semiconductors P-channel vertical D-MOS logic level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9 Legal information. . . . . . . . . . . . . . . . . . . . . . . .10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 14 December 2010 Document identifier: PHK04P02T
PHK04P02T,518
物料型号:PHK04P02T
器件简介:这是一种P沟道增强型垂直D-MOS逻辑电平场效应晶体管(FET),采用塑料封装,使用垂直D-MOS技术。设计并限定用于计算机、通信、消费和工业应用。
引脚分配:文档中提供了引脚信息表,展示了8个引脚的配置,其中1、2、3、7、8引脚为源极(S),4引脚为栅极(G),5、6引脚为漏极(D)。
参数特性:文档提供了快速参考数据表,列出了如漏源电压(Vps)、漏电流(I)、总功耗(Ptot)和漏源导通电阻(RpSon)等参数的最小值、典型值和最大值。
功能详解:该FET适用于高频应用,由于其快速开关特性;适用于逻辑电平栅极驱动源;适用于非常低的栅极驱动源电压。
应用信息:适用于电池供电应用和高速数字接口。
封装信息:封装类型为SO8,即塑料小外形封装,8个引脚,封装体宽度为3.9毫米。
PHK04P02T,518 价格&库存
很抱歉,暂时无法提供与“PHK04P02T,518”相匹配的价格&库存,您可以联系我们找货
