BUK7226-75A
N-channel TrenchMOS standard level FET
Rev. 02 — 22 February 2008
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a
plastic package using Nexperia General Purpose Automotive (GPA) TrenchMOS
technology. This product has been designed and qualified to the appropriate AEC
standard for use in automotive critical applications.
1.2 Features
175 °C rated
Q101 compliant
Low on-state resistance
Standard level compatible
1.3 Applications
12 V, 24 V and 42 V loads
General purpose power switching
Automotive systems
Motors, lamps and solenoids
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 1 and 4
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
Tj
junction temperature
VDS
[1]
Min
Typ
Max
Unit
75
V
45
A
158
W
-55
175
°C
22
26
mΩ
215
mJ
Static characteristics
RDSon
drain-source on-state
resistance
VGS = 10 V; ID = 25 A;
Tj = 25 °C; see Figure 12 and
13
Avalanche ruggedness
EDS(AL)S non-repetitive
ID = 45 A; Vsup ≤ 75 V;
drain-source avalanche RGS = 50 Ω; VGS = 10 V;
energy
Tj(init) = 25 °C; unclamped
inductive load
[1]
Capped at 45 A due to bondwire.
BUK7226-75A
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Symbol
Description
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
D
mb
G
mbb076
S
2
1
3
SOT428 (DPAK)
3. Ordering information
Table 3.
Type number
BUK7226-75A
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads (one lead
cropped)
SOT428
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
VDS
75
V
VDGR
drain-gate voltage
RGS = 20 kΩ
75
V
VGS
gate-source voltage
-20
V
ID
drain current
45
A
Tmb = 100 °C; VGS = 10 V; see Figure 1
38
A
215
A
Tmb = 25 °C; VGS = 10 V; see Figure 1 and 4
[1]
IDM
peak drain current
Tmb = 25 °C; tp ≤ 10 μs; pulsed; see Figure 4
Ptot
158
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
215
mJ
J
45
A
215
A
energy
ID = 45 A; Vsup ≤ 75 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
inductive load
EDS(AL)R repetitive drain-source
avalanche energy
see Figure 3
[2][3]
[4]
Source-drain diode
IS
source current
Tmb = 25 °C
ISM
peak source current
tp ≤ 10 μs; pulsed; Tmb = 25 °C
[1]
[1]
BUK7226-75A_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
BUK7226-75A
Nexperia
[2]
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
[3]
Repetitive avalanche rating limited by an average junction temperature of 170 °C.
[4]
Refer to application note AN10273 for further information.
003aac178
60
03aa16
120
ID
(A)
Pder
(1)
40
80
100
150
Tmb (°C)
VGS 10V
50
P der =
(1) Capped at 45 A due to bondwire.
Fig 1. Continuous drain current as a function of
mounting base temperature
P tot
P tot (25°C )
100
150
Tmb (°C)
200
× 100 %
Fig 2. Normalized total power dissipation as a
function of mounting base temperature
003aac181
102
IAV
(A)
(1)
10
(2)
(3)
1
10-1
10-3
10-2
10-1
1
tAV (ms)
10
(1) Singleípulse;T j = 25 °C.
(2) Singleípulse;T j = 150 °C.
(3) Repetitive.
Fig 3. Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time
BUK7226-75A_2
Product data sheet
3 of 13
BUK7226-75A
Nexperia
003aac179
103
ID
(A)
10 μs
Limit RDSon = VDS / ID
10
2
100 μs
(1)
1 ms
10
10 ms
DC
1
10-1
1
100 ms
102
10
103
VDS (V)
Tmb = 25 °C; IDM is single pulse
Fig 4. Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-a)
thermal resistance
from junction to
ambient
minimum footprint; FR4 board
70
K/W
Rth(j-mb)
thermal resistance
from junction to
mounting base
see Figure 5
1
K/W
BUK7226-75A_2
Product data sheet
4 of 13
BUK7226-75A
Nexperia
003aac180
1
δ = 0.5
Zth(j-mb)
(K/W) 0.2
10-1
0.1
0.05
0.02
δ=
P
10-2
tp
T
single shot
t
tp
T
10-3
10-6
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Fig 5. Transient thermal impedance from junction to mounting base as a function of pulse duration
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 0.25 mA; VGS = 0 V;
Tj = -55 °C
70
V
Tj = 25 °C
75
V
1
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 11
2
3
4
V
Tj = -55 °C; see Figure 11
4.4
V
VDS = 75 V; VGS = 0 V; Tj = 25 °C
0.05
10
μA
Tj = 175 °C
500
μA
VDS = 0 V; VGS = 20 V; Tj = 25 °C
2
100
nA
VDS = 0 V; VGS = -20 V;
Tj = 25 °C
2
100
nA
Tj = 175 °C; see Figure 12 and
13
54
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 12 and 13
22
26
mΩ
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 16
0.85
1.2
V
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold ID = 1 mA; VDS = VGS;
voltage
Tj = 175 °C; see Figure 11
drain leakage current
gate leakage current
resistance
Source-drain diode
VSD
source-drain voltage
BUK7226-75A_2
Product data sheet
5 of 13
BUK7226-75A
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
trr
reverse recovery time IS = 20 A; dIS/dt = -100 A/μs;
VGS = -10 V; VDS = 30 V;
recovered charge
Tj = 25 °C
Qr
Conditions
Min
Typ
Max
Unit
53
ns
144
nC
48
nC
7.5
nC
17
nC
1789
2385
pF
382
458
pF
219
300
pF
14
ns
66
ns
61
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
ID = 25 A; VDS = 60 V;
VGS = 10 V; see Figure 14
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
tf
fall time
41
ns
LD
internal drain
inductance
measured from drain lead from
package to center of die;
Tj = 25 °C
2.5
nH
LS
internal source
inductance
measured from source lead from
package to source bond pad;
Tj = 25 °C
7.5
nH
VGS = 0 V; VDS = 25 V;
f = 1 MHz; Tj = 25 °C;
see Figure 15
VDS = 30 V; RL = 1.2 Ω;
VGS = 10 V; RG(ext) = 10 Ω;
Tj = 25 °C
03nb06
200
VGS (V) = 20
ID
(A)
10
9
160
03nb05
28
RDSon
(mΩ)
24
8
120
7
6
16
40
5
4
6
8
10
VDS (V)
T j = 25 °C; t p = 300 ȝs
5
15
VGS (V)
T j = 25 °C; ID = 25 A
Fig 6. Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 7. Drain-source on-state resistance as a function
of gate-source voltage; typical values
BUK7226-75A_2
Product data sheet
10
6 of 13
BUK7226-75A
Nexperia
03aa35
10−1
ID
(A)
min
10−2
typ
03nb03
40
gfs
(S)
max
30
10−3
10−4
10
10−5
10−6
4
60
80
ID (A)
VGS (V)
T j = 25 °C;VDS = VGS
T j = 25 °C;VDS = 25V
Fig 8. Sub-threshold drain current as a function of
gate-source voltage
03nb04
50
Fig 9. Forward transconductance as a function of
drain current; typical values
03aa32
5
VGS(th)
(V)
ID
(A)
40
4
30
3
max
typ
2
min
Tj = 175 °C
1
10
Tj = 25 °C
4
6
−60
120
VDS = 25V
ID = 1 m A;VDS = VGS
Fig 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
Fig 11. Gate-source threshold voltage as a function of
BUK7226-75A_2
Product data sheet
180
Tj (°C)
VGS (V)
7 of 13
BUK7226-75A
Nexperia
03nb07
60
RDSon
(mΩ)
6
7
8
03nb25
2.4
9 10
VGS (V) = 5
a
50
1.6
40
30
0.8
100
150
−60
200
ID (A)
T j = 25 °C
a=
Fig 12. Drain-source on-state resistance as a function
of drain current; typical values
03nb02
10
VGS
(V)
120
180
Tj (°C)
R DSon
R DSon (25°C )
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature
03nb08
3000
C
(pF)
8
Ciss
2000
VDS = 14 V
6
VDS = 60 V
Coss
4
1000
Crss
2
60
10−2
10−1
1
VDS (V)
VGS = 0V ; f = 1 M H z
Fig 14. Gate-source voltage as a function of turn-on
gate charge; typical values
Fig 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK7226-75A_2
Product data sheet
102
10
QG (nC)
8 of 13
BUK7226-75A
Nexperia
03nb01
80
IS
(A)
60
40
Tj = 175 °C
Tj = 25 °C
0.8
1.2
VSD (V)
VGS = 0V
Fig 16. Reverse diode current; typical values
BUK7226-75A_2
Product data sheet
9 of 13
BUK7226-75A
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L
L2
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig 17. Package outline SOT428 (DPAK)
BUK7226-75A_2
Product data sheet
10 of 13
BUK7226-75A
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7226-75A_2
20080222
Product data sheet
BUK7226_75A-01
Modifications:
BUK7226_75A-01
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20001009
Product specification; initial version
BUK7226-75A_2
Product data sheet
11 of 13
BUK7226-75A
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
BUK7226-75A_2
Product data sheet
12 of 13
Nexperia
BUK7226-75A
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
11
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 February 2008
很抱歉,暂时无法提供与“BUK7226-75A,118”相匹配的价格&库存,您可以联系我们找货
