PHP30NQ15T,127
PHP30NQ15T,127
    NEXPERIA(安世)
    SOT78
    MOSFET N-CH 150V 29A TO220AB
PHP30NQ15T,127 数据手册
PHP30NQ15T N-channel TrenchMOS standard level FET Rev. 03 — 3 March 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Low conduction losses due to low on-state resistance „ Suitable for high frequency applications due to fast switching characteristics 1.3 Applications „ DC-to-DC convertors „ Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 150 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 and 2 - - 29 A Ptot total power dissipation Tmb = 25 °C; see Figure 3 - - 150 W VGS = 10 V; ID = 30 A; VDS = 120 V; Tj = 25 °C; see Figure 13 - 20 27 nC VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 11 and 12 - 60 63 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain Simplified outline Graphic symbol mb 3 S source mb D mounting base; connected to drain D G mbb076 S 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number PHP30NQ15T PHP30NQ15T_3 Product data sheet Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 150 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 150 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 25 °C; see Figure 1 and 2 - 29 A VGS = 10 V; Tmb = 100 °C; see Figure 1 - 20 A - 116 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 2 Ptot total power dissipation Tmb = 25 °C; see Figure 3 - 150 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 29 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 116 A - 502 mJ - 29 A Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 26 A; Vsup ≤ 25 V; drain-source avalanche unclamped; RGS = 50 Ω; tp = 0.2 ms; see Figure 4 energy IAS non-repetitive avalanche current Vsup ≤ 25 V; VGS = 10 V; Tj(init) = 25 °C; RGS = 50 Ω; unclamped; see Figure 4 03aa24 120 003aaa055 103 ID (A) Ider (%) RDSon = VDS/ ID 102 tp = 10 μs 80 100 μs 10 1 ms D.C. 40 10 ms 100 ms 1 10−1 0 0 50 100 150 1 200 10 102 VDS (V) Tmb (°C) Fig 1. Normalized continuous drain current as a function of mounting base temperature PHP30NQ15T_3 Product data sheet Fig 2. 103 Safe operating area; continuous and peak drain currents as a function of drain-source voltage All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 03aa16 120 003aaa054 102 Pder (%) IAS (A) 80 10 40 1 25 °C Tj prior to avalanche = 150 °C 10−1 10−3 0 0 50 100 150 200 10−2 10−1 1 Fig 3. 10 tp (ms) Tmb (°C) Normalized total power dissipation as a function of mounting base temperature Fig 4. Non-repetitive avalanche ruggedness current as a function of pulse duration 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) Rth(j-a) Conditions Min Typ Max Unit thermal resistance from see Figure 5 junction to mounting base - - 1 K/W thermal resistance from vertical in still air junction to ambient - 60 - K/W 003aaa056 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10−1 0.05 0.02 P δ= Single Pulse 10−2 t tp 10−3 10−6 Fig 5. tp T T 10−5 10−4 10−3 10−2 10−1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PHP30NQ15T_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 150 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 8 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 8 1 - - V VDS = 150 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VDS = 150 V; VGS = 0 V; Tj = 175 °C - - 500 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 0.02 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 0.02 100 nA VGS = 10 V; ID = 15 A; Tj = 175 °C; see Figure 11 and 12 - - 176 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C; see Figure 11 and 12 - 60 63 mΩ ID = 30 A; VDS = 120 V; VGS = 10 V; Tj = 25 °C; see Figure 13 - 55 - nC - 10 - nC - 20 27 nC - 2390 - pF - 240 - pF - 98 - pF - 14 - ns - 50 - ns IDSS drain leakage current IGSS gate leakage current RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 48 - ns tf fall time - 38 - ns VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 14 VDS = 75 V; RL = 2.7 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 15 - 0.9 1.2 V trr reverse recovery time 105 - ns recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - Qr - 0.55 - µC PHP30NQ15T_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 003aaa057 35 ID (A) VGS = 10 V 003aaa062 30 ID (A) 8V 30 25 6V 25 20 20 Tj = 175 °C 5.4 V 15 15 5.2 V Tj = 25 °C 10 10 5.0 V 4.8 V 5 0 Fig 6. 5 4.6 V 4.4 V 0 0.4 0.8 1.2 0 1.6 2.0 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 0 Fig 7. 003aaa023 4.5 4 VGS(th) (V) 3.5 2 3 4 5 6 7 8 9 VGS (V) 10 Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aaa024 10−2 ID (A) max 1 10−3 min 3 10−4 typ typ 2.5 max 2 10−5 min 1.5 10−6 1 0.5 0 −60 Fig 8. −20 20 60 100 140 Tj (°C) 180 Product data sheet 1 2 3 5 4 VGS (V) Gate-source threshold voltage as a function of junction temperature PHP30NQ15T_3 10−7 Fig 9. Sub-threshold drain current as a function of gate-source voltage All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET gfs (S) 003aaa063 40 003aaa061 0.20 4.4 V RDSon (Ω) 35 Tj = 25 °C 5.0 V 4.6 V 0.16 30 5.2 V 4.8 V 25 0.12 Tj = 175 °C 5.4 V 20 8.0 V 0.06 15 6.0 V 10 VGS = 10 V 0.04 5 0 0 5 10 15 20 Fig 10. Forward transconductance as a function of drain current; typical values 0 5 10 15 20 25 2.8 Fig 11. Drain-source on-state resistance as a function of drain current; typical values 003aaa066 VGS (V) 2.6 2.4 2.2 30 ID (A) 003aaa064 3.0 a 0 25 30 ID (A) 14 12 10 VDD = 30 V 2.0 8 1.8 1.6 VDD = 120 V 6 1.4 1.2 4 1.0 2 0.8 0.6 −40 0 40 80 0 120 160 Tj (°C) Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature PHP30NQ15T_3 Product data sheet 0 10 20 30 40 50 60 QG (nC) Fig 13. Gate-source voltage as a function of gate charge; typical values All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 003aaa065 104 003aaa067 30 IS (A) Ciss, Coss, Crss (pF) 25 Ciss 103 20 Tj = 175 °C 15 Coss Tj = 25 °C 102 10 Crss 5 10 10−1 1 102 10 0 0 0.2 0.4 0.6 0.8 1.0 1.2 VSD (V) VDS (V) Fig 14. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PHP30NQ15T_3 Product data sheet Fig 15. Source current as a function of source-drain voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 16. Package outline SOT78 (TO-220AB) PHP30NQ15T_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 9 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHP30NQ15T_3 20100303 Product data sheet - PHB_PHP30NQ15T-02 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Typenumber PHP30NQ15T separated from data sheet PHB_PHP30NQ15T-02. PHB_PHP30NQ15T-02 (9397 750 08037) 20010312 Product specification - PHB_PHP30NQ15T_1 PHB_PHP30NQ15T_1 19990801 Product specification - - PHP30NQ15T_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 10 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PHP30NQ15T_3 Product data sheet Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 11 of 13 PHP30NQ15T Nexperia N-channel TrenchMOS standard level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PHP30NQ15T_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 3 March 2010 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia PHP30NQ15T N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 March 2010
PHP30NQ15T,127 价格&库存
很抱歉,暂时无法提供与“PHP30NQ15T,127”相匹配的价格&库存,您可以联系我们找货
