BUK7907-55AIE,127
BUK7907-55AIE,127
    NEXPERIA(安世)
    TO-220-5
    MOSFET N-CH 55V 75A TO220AB
BUK7907-55AIE,127 数据手册
BUK7907-55AIE N-channel TrenchPLUS standard level FET Rev. 02 — 9 February 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. The devices include TrenchPLUS current sensing and diodes for ElectroStatic Discharge (ESD) protection. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Electrostatically robust due to integrated protection diodes „ Reduced component count due to integrated current sensor „ Low conduction losses due to low on-state resistance „ Suitable for standard level gate drive sources „ Q101 compliant 1.3 Applications „ Electrical Power Assisted Steering (EPAS) „ Variable Valve Timing for engines 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 2; see Figure 3 [1] Min Typ Max Unit - - 55 V - - 140 A mΩ Static characteristics RDSon drain-source on-state resistance VGS = 10 V; ID = 50 A; Tj = 25 °C; see Figure 7; see Figure 8 - 5.8 7 ID/Isense ratio of drain current to sense current Tj > -55 °C; Tj < 175 °C; VGS > 10 V 450 500 550 [1] Current is limited by power dissipation chip rating. BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 ISENSE Sense current 3 D drain 4 KS Kelvin source 5 S source mb D mounting base; connected to drain Graphic symbol d mb g Isense MBL368 s Kelvin source 12 3 4 5 SOT263B (TO-220) 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BUK7907-55AIE TO-220 plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead SOT263B TO-220 © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 2 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 55 V VGS gate-source voltage ID drain current -20 20 V Tmb = 25 °C; VGS = 10 V; see Figure 2; see Figure 3; [1] - 140 A [2] - 75 A Tmb = 100 °C; VGS = 10 V; see Figure 2 [2] - 75 A IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 - 560 A Ptot total power dissipation Tmb = 25 °C; see Figure 1 - 272 W IGS(CL) gate-source clamping current continuous - 10 mA pulsed; tp = 5 ms; δ = 0.01 - 50 mA Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C VDGS drain-gate voltage - 55 V IDG = 250 µA Source-drain diode IS ISM source current peak source current Tmb = 25 °C; [1] - 140 A Tmb = 25 °C; [2] - 75 A - 560 A - 460 mJ - 6 kV tp ≤ 10 µs; pulsed; Tmb = 25 °C Avalanche ruggedness EDS(AL)S non-repetitive ID = 68 A; Vsup ≤ 55 V; RGS = 50 Ω; VGS = 10 V; drain-source avalanche Tj(init) = 25 °C; unclamped energy Electrostatic Discharge Vesd electrostatic discharge voltage HBM; C = 100 pF; R = 1.5 kΩ [1] Current is limited by power dissipation chip rating. [2] Continuous current is limited by package. © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 3 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 03na19 120 03ni63 160 ID (A) Pder (%) 120 80 80 40 Capped at 75A due to package 40 0 0 0 50 100 150 200 0 Tmb (°C) Fig 2. Fig 1. Normalized total power dissipation as a function of mounting base temperature 50 100 150 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature 03nf55 103 ID (A) Limit RDSon = VDS/ID tp = 10 μs 102 100 μs Capped at 75 A due to package 1 ms DC 10 ms 10 100 ms 1 1 102 10 VDS (V) Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 4 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-mb) Conditions Min Typ Max Unit thermal resistance from vertical in still air junction to ambient - 60 - K/W thermal resistance from see Figure 4 junction to mounting base - - 0.55 K/W 03ni29 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10−1 0.1 0.05 0.02 10−2 δ= P tp T single shot t tp T 10−3 10−6 10−5 10−4 10−3 10−2 10−1 1 10 tp (s) Fig 4. Transient thermal impedance from junction to mounting base as a function of pulse duration © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 5 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 55 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 50 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 9 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 - - 4.4 V VDS = 55 V; VGS = 0 V; Tj = 25 °C - 0.1 10 µA VDS = 55 V; VGS = 0 V; Tj = 175 °C - - 250 µA 20 22 - V IG = -1 mA; VDS = 0 V; Tj < 175 °C; Tj > -55 °C 20 22 - V VDS = 0 V; VGS = 10 V; Tj = 25 °C - 22 1000 nA VDS = 0 V; VGS = -10 V; Tj = 25 °C - 22 1000 nA VDS = 0 V; VGS = 10 V; Tj = 175 °C - - 10 µA VDS = 0 V; VGS = -10 V; Tj = 175 °C - - 10 µA VGS = 10 V; ID = 50 A; Tj = 25 °C; see Figure 7; see Figure 8 - 5.8 7 mΩ VGS = 10 V; ID = 50 A; Tj = 175 °C; see Figure 7; see Figure 8 - - 14 mΩ VGS > 10 V; Tj > -55 °C; Tj < 175 °C 450 500 550 ID = 25 A; VDS = 44 V; VGS = 10 V; Tj = 25 °C; see Figure 14 - 116 - nC - 19 - nC - 50 - nC Static characteristics V(BR)DSS VGS(th) IDSS V(BR)GSS IGSS RDSon ID/Isense drain leakage current gate-source breakdown IG = 1 mA; VDS = 0 V; Tj < 175 °C; voltage Tj > -55 °C gate leakage current drain-source on-state resistance ratio of drain current to sense current Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 12 VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω; Tj = 25 °C - 4500 - pF - 960 - pF - 510 - pF - 36 - ns - 115 - ns turn-off delay time - 159 - ns tf fall time - 111 - ns LD internal drain inductance from upper edge of drain mounting base to centre of die; Tj = 25 °C - 2.5 - nH LS internal source inductance from source lead to source bond pad; Tj = 25 °C - 7.5 - nH td(on) turn-on delay time tr rise time td(off) © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 6 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 16 - 0.85 1.2 V trr reverse recovery time - 80 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C - 200 - nC 03ni66 8 03ni65 400 10 12 ID 8.5 RDSon (mΩ ) (A) 7 8 20 300 VGS (V) = 7.5 6 7 200 6.5 5 6 100 5.5 4 4.5 4 5 0 0 2 4 6 8 Output characteristics: drain current as a function of drain-source voltage; typical values VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values © BUK7907-55AIE_2 Product data sheet 15 10 VDS (V) Fig 6. Fig 5. 10 Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 7 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 03ne89 2 03ni67 12 RDSon (mΩ) 10 a VGS (V) = 5.5 1.5 6 6.5 8 7 1 8 10 6 4 0.5 2 0 -60 0 0 Fig 7. 20 40 60 80 60 120 Tj (°C) 180 100 120 ID (A) Drain-source on-state resistance as a function of drain current; typical values 03aa32 5 Fig 8. Normalized drain-source on-state resistance factor as a function of junction temperature 03aa35 10−1 ID (A) VGS(th) (V) 4 10−5 10−6 0 60 120 180 0 2 4 6 Tj (°C) VGS (V) Gate-source threshold voltage as a function of junction temperature Fig 10. Sub-threshold drain current as a function of gate-source voltage © BUK7907-55AIE_2 Product data sheet max 10−4 min 1 0 −60 typ 10−3 typ 2 min 10−2 max 3 Fig 9. 0 Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 8 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 03ni68 80 gfs (S) 03ni69 8000 C (pF) C iss 6000 60 4000 Coss Crss 40 2000 20 0 10-2 10-1 10 V 102 DS (V) 1 0 0 20 40 60 80 I (A) 100 D Fig 11. Forward transconductance as a function of drain current; typical values 03nf25 10 VGS 03ni70 120 ID (A) 100 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values (V) 8 VDS = 14 V 6 80 VDS = 44 V 60 4 40 175 °C 2 Tj = 25 °C 20 0 0 0 0 2 4 VGS (V) 80 QG (nC) 120 6 Fig 13. Transfer characteristics: drain current as a function of gate-source voltage; typical values Fig 14. Gate-source voltage as a function of turn-on gate charge; typical values © BUK7907-55AIE_2 Product data sheet 40 Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 9 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 03nj27 600 03ni72 100 ID/Isense IS (A) 80 550 60 500 40 450 175 °C 20 Tj = 25 °C 400 4 8 12 16 VGS (V) 20 0 0.0 Fig 15. Drain-sense current as a function of gate-source voltage; typical values 0.4 0.6 0.8 1.0 VSD (V) Fig 16. Reverse diode current as a function of reverse diode voltage; typical values © BUK7907-55AIE_2 Product data sheet 0.2 Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 10 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead TO-220 SOT263B E p1 A ∅p A1 q D1 mounting base D L1 Q L2 m L 1 5 e b c w M 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D D1 E e L mm 4.5 4.1 1.39 1.27 0.85 0.70 0.7 0.4 15.8 15.2 6.4 5.9 10.3 9.7 1.7 15.0 13.5 L1 (1) 2.4 1.6 L2 (2) 0.5 m ∅p p1 q Q w 0.8 0.6 3.8 3.6 4.3 4.1 3.0 2.7 2.6 2.2 0.4 Notes 1. Terminal dimensions are uncontrolled in this zone. 2. Positional accuracy of the terminals is controlled in this zone. OUTLINE VERSION SOT263B REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 01-01-11 5-lead TO-220 Fig 17. Package outline SOT263B (TO-220) © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 11 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK7907-55AIE_2 20090209 Product data sheet - BUK71_7907_55AIE-01 Modifications: BUK71_7907_55AIE-01 (9397 750 09877) • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK7907-55AIE separated from data sheet BUK71_7907_55AIE-01. 20020812 Product data sheet - © BUK7907-55AIE_2 Product data sheet - Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 12 of 14 BUK7907-55AIE Nexperia N-channel TrenchPLUS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © BUK7907-55AIE_2 Product data sheet Rev. 02 — 9 February 2009 Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia BUK7907-55AIE N-channel TrenchPLUS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Contact information. . . . . . . . . . . . . . . . . . . . . .13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 February 2009
BUK7907-55AIE,127 价格&库存
很抱歉,暂时无法提供与“BUK7907-55AIE,127”相匹配的价格&库存,您可以联系我们找货
